Fluid MechanicsUnderstanding Dim Analysis & Similarity
In summary: I guess I'll have to look into it more. Thanks for the tip.In summary, the Buckingham Pi theorem is a procedure for nondimensionalizing a function. It is based on the Pi theorem and allows for the determination of two non-dimensional parameters.
Saladsamurai
3,020
I have a question (maybe more than one) regarding the application of dimensional analysis/Buckingham Pi Theorem to compare a Model to a Prototype.
The premise of this theorem is more or less to nondimensionalize a function.
In short, the procedure is as follows: Let's say we have some function that contains five variables or
x1=f(x2,x3,x4,x5)
These variables are generally of the dimensions [M]=mass [T]=time [L]=length and sometimes [theta]=temp but I will omit this for simplicity.
So here we have m variables where m=5 and n dimensions where n=3, thus from the Pi theorem we have N=m-n=2 non-dimensional parameters that can be formed.The general procedure for finding these non-dimensional parameters is to arbitrarily choose n, 3 in this case, variables that cannot by themselves form a dimensionless power product. In this case we will say that x2,x3,x4 satisfy this condition. These are our "repeating parameters."
Now we find our 2 dimensionless parameters by finding the power product of our repeating variables with each of our remaining 2 variables such that
(x2ax3bx4c)x1=constant
and similarly
(x2ax3bx4c)x5=constant
Now here is the question. It seems that sometimes there is more than 1 choice of our 3 repeating variables. That is, there might be two sets of 3 variables whose power product is not dimensionless.
How do we choose? Does it matter? I think that it does not matter in theory, but in practice, some choices may yield more useful relationships than others.
Is that correct?
I am under the impression that if we were to be given values for let's say x2 and x3 for both the model and prototype, then these would be obvious choices for 2 of the 3 repeating variables.
Any thoughts?
Sorry for the lengthy post.
Thanks,
Casey
You are absolutely correct that there is no unique functional form of pi terms. The only unique thing is the number of pi terms you will have. In general, selection of Pi terms are made based on knowledge of the problem. You typically care about Mach number, Reynolds Number, and a few others depending on the type and nature of the flow.
For aerodynamics, we care about the Reynolds number and Mach Number most.
The Strouhal number comes in for unsteadiness, weber for surface tension, and others. Typically, you will know what the Pi terms are based on what you're doing.
Get yourself a copy of this book: Fundamentals of Fluid Mechanics (Okiishi, Young, Munson) and read the section on Pi terms (or the entire book if you want). It's a darn good book that explains concepts well.
Excellent. I had a feeling that this is just something that will come with practice and is a little hard to generalize.
I will definitely check out that book too Cyrus. My library probably has it. Thanks for the tip.
EDIT: Nope they don't. All of them are by Munson, Roy, et Al. I'll see if I can get it sent from another library.
Here is a fun real world experiment for you to work out. See if you can have dynamic similitude for a scale wind tunnel model using the Buckingham Pi theorem. You will find the answer to my question will give you a much better understanding of the Pi theorem in practical use: i.e., not just doing BS problems from a book which is what I am sure your instructor will have you do (they all do).
Hmm. I would like to do this, but I am not exactly what the question is. Maybe we have not covered the subject enough yet for me too. I am used to being given certain information and then asked a very specific question (the BS problems).
That is, are we looking at the power of the fan blade of this thing or something?
Thanks,
Casey
Just take an airplane (or car, or whatever 'thing' you want), and do dimensional analysis on it.
Given: A wind tunnel and a scale model
Find: The Pi Terms and what you would need for similitude.
That's the real world. Welcome to it.
Remember what I told you: (a) scale model (b) Reynolds number (c) Mach Number.
Those are your pi terms.
1. What is fluid mechanics?
Fluid mechanics is the branch of physics that studies the behavior of fluids, which include liquids, gases, and plasmas. It involves understanding how these fluids move and interact with their surroundings.
2. What is dimensional analysis?
Dimensional analysis is a mathematical technique used to analyze physical phenomena by examining the relationships between different physical quantities and their units. It allows scientists to simplify complex equations and understand the fundamental principles governing a system.
3. How is dimensional analysis used in fluid mechanics?
In fluid mechanics, dimensional analysis is used to determine the relationships between various physical quantities, such as velocity, pressure, and viscosity. It also helps in predicting the behavior of fluids in different conditions and scaling up or down experiments or models.
4. What is similarity in fluid mechanics?
In fluid mechanics, similarity refers to the ability to compare two different systems or experiments and make meaningful conclusions based on their similarities. This is achieved by using dimensionless quantities, such as Reynolds number, which can be used to compare the behavior of fluids in different flow conditions.
5. How is similarity used to solve fluid mechanics problems?
Similarity is used in fluid mechanics to simplify complex problems and make accurate predictions about fluid behavior. By using dimensionless quantities and analyzing the similarities between different systems, scientists can gain a better understanding of fluid dynamics and make practical applications, such as designing more efficient aircraft or predicting weather patterns.
  • Mechanical Engineering
  • Other Physics Topics
9K
