amaresh92
- 163
what will be the gravitational force inside a hollow cylinder at the center?
if it is zero than explain why?
above thanks
above thanks
The formula for calculating the gravitational force inside a hollow cylinder is F = G(m1m2)/r^2, where F is the force, G is the gravitational constant, m1 and m2 are the masses of the objects, and r is the distance between the objects.
The mass distribution inside the hollow cylinder does not affect the gravitational force, as long as the total mass of the objects inside remains the same. The force is dependent on the distance between the objects, not the distribution of mass.
No, the gravitational force inside the hollow cylinder will not change if the cylinder is rotated. As long as the distance between the objects remains the same, the force will remain constant.
The gravitational force inside the hollow cylinder is inversely proportional to the square of the radius. This means that as the radius increases, the force decreases, and vice versa.
No, the gravitational force inside the hollow cylinder cannot be negative. It is always a positive value, representing the attractive force between the objects inside.
