Lunar lander in orbit around the moon and how much work the thrusters do
In summary, the problem involves a 6000 kg lunar lander needing to move from an 80 km-high orbit to a 200 km-high orbit to link up with the mother ship. The calculation involves finding the work done by the thrusters, using the equations v=sqrt(GM/r) and W=change in KE. After making some initial errors with units and calculations, the correct answer is found to be 5.01 x10^8 J.
kerbyjonsonjr
34
A 6000 kg lunar lander is in orbit 80 km above the surface of the moon. It needs to move out to a 200 km -high orbit in order to link up with the mother ship that will take the astronauts home.
How much work must the thrusters do?
v=[tex]\sqrt{}GM/r[/tex]
W=[tex]\Delta[/tex]KE
G=6.67 x10-11
Radius of moon= 1,737.4 km
Mass of moon=7.36 x1022
Since W=change in KE I figured I would just find the velocity before and after then plug it in. I used v=sqrt GM/r so sqrt 6.67 x10-22* 7.36 x1022/(1737.4+80) and got 51,972.9 m/s and then I did that again with the radius being 1,737.4+200 and got v= 50,337.7 m/s
Then I solved for change in KE=1/2mv2 so 1/2(6000)(50377.72) -1/2(6000)(51972.92) and got -5.02 x1011
I am not sure where I messed up but I know my answer is wrong. Any help would really be great.
Think about what that negative value means. If it were true, things would not stay in orbit. They would instead spiral outward.
You need to calculate the change in total energy, not just the change in kinetic energy.
Alright, so would I solve for change in E by saying KEf + Uf -(KEi + Ui) ? Is U equal to GMm/r?
Wrong sign.
D H said:
Wrong sign.
Is the rest of the setup though because I am still getting an incorrect answer
I have KEf-GMm/r +(KE2 - GMm/r)
So I put in 1/2(6000)(50,3372) - 6.67 x10^-11(7.36 x10^22)(6000)/(1937)= -7.6 x10^12
Then the other half is 1/2(6000)(519732) -6.67 x10^-11(7.36 x10^22)(6000)/(1817)= -8.1 x10^12
So then that becomes -7.6 x10^12 + 8.1 x10^12 = 5 x10^11
Where did I go wrong?
Units! Don't just plug in numbers. You have to make sure that the terms in your expression have consistent units.
Would it be the radius that needs to be in meters? Or is it something else?
Yes, the radius needs to be in meters.
It would seem as though I am still doing something wrong because I am now getting a negative value again.
I plugged in the value for r in meters my change in energy ended up being
7.58 x10^12 - 8.07 x10^12 which is a negative number. The only thing I did different was plug in the new r values.
Show your work, with units, not just numbers.
The final energy: 1/2(6000 kg)(503772 m/s) - 6.67 x 10^-11 (7.36 x10^22 kg)(6000 kg)/(1937000 m) = 7.6 x10^12 - 1.52 x10^10= 7.59 x 10^12
The initial energy: 1/2(6000 kg)(519732 m/s) -6.67 x10^-11 (7.36 x10^22 kg)(6000 kg)/(1817000m)= 8.1 x10^12 - 1.62 x10^10 = 8.08 x10^12
Then I would subtract 7.59 x10^12 - 8.08 x10^12= -4.9 x10^11. I am not sure if I am putting something in incorrectly on my calculator or if I have an error with my units.
Your velocities are wrong. Show your work, and once again watch your units.
I finally got it. I forgot to use m for the radius when I calculated the velocities. I redid it and finally got the correct answer of 5.01 x10^8 J. Thank you so much for taking the trouble to help me. I really appreciate it.
Thanks.
Lesson learned, I hope: Don't just throw numbers around. Always work with units.
1. How does a lunar lander stay in orbit around the moon?
A lunar lander stays in orbit around the moon by using its thrusters to counteract the downward pull of gravity. By constantly adjusting its speed and direction, the lander can maintain a stable orbit.
2. How much work do the thrusters on a lunar lander do?
The amount of work the thrusters on a lunar lander do depends on various factors such as the size and weight of the lander, the desired orbit, and the duration of the mission. It is calculated by multiplying the force exerted by the thrusters by the distance traveled.
3. What type of fuel do the thrusters on a lunar lander use?
The thrusters on a lunar lander typically use a liquid fuel, such as liquid hydrogen or liquid oxygen. These fuels are chosen for their high energy density and efficient combustion, allowing for longer and more precise maneuvers.
4. How do the thrusters on a lunar lander differ from those on a spacecraft?
The thrusters on a lunar lander differ from those on a spacecraft in several ways. Lunar lander thrusters are typically smaller and more precise, as they need to make subtle adjustments to maintain orbit. They also have a shorter burn time, as they are only used for landing and orbit maintenance, whereas spacecraft thrusters may need to be fired for longer periods of time.
5. Can the thrusters on a lunar lander be used to take off from the moon?
Yes, the thrusters on a lunar lander can be used for takeoff from the moon. They are designed to have enough power to overcome the moon's gravitational pull and lift the lander off the surface. However, once the lander is in orbit, a different set of thrusters may be used for maneuvers and course corrections.
