Problem solving a separable differential equation for u
In summary, the problem is to solve the separable differential equation du/dt = e^(5u+2t) with the initial condition u(0)=13. The attempt at a solution involved taking the natural log of both sides, but the person got stuck and considered dividing both sides by e^(5u+2t). A hint was given to use the laws of exponents to split e^(5u+2t).
mesa
38
Solve the separable differential equation for u
du/dt=e^(5u+2t)
Use the following initial condition: u(0)=13
Honestly I didn't get very far on this one. I took the natural log of both sides,
ln du/dt = 5u+2t
And now I am stuck. Should I divide both sides first by our e^(5u+2t) instead of taking the ln?
du/dt=e^(5u+2t)
ln du/dt = 5u+2t
Hint: Use the laws of exponents to split e5u + 2t.
Likes 1 person
Damn it...
Thank you, its been a long night.
What is a separable differential equation?
A separable differential equation is a type of differential equation where the variables can be separated into two functions that can be integrated separately. This allows for a simpler solution to the equation.
How do you solve a separable differential equation?
To solve a separable differential equation, you must first separate the variables into two functions. Then, you can integrate both sides of the equation separately. This will give you a general solution, which can be further simplified by applying initial conditions.
What are the steps involved in solving a separable differential equation?
The steps involved in solving a separable differential equation are:
  1. Separate the variables into two functions.
  2. Integrate both sides of the equation separately.
  3. Simplify the resulting equation, if possible.
  4. Apply any initial conditions to find a specific solution.
What are the applications of solving separable differential equations?
Solving separable differential equations is useful in many areas of science, engineering, and economics. It can be used to model population growth, radioactive decay, chemical reactions, and many other phenomena.
What are the challenges of solving a separable differential equation?
The main challenge of solving a separable differential equation is identifying the correct method to separate the variables and finding a solution that satisfies any given initial conditions. This can be difficult for more complex equations and may require advanced mathematical techniques.
