Finding Instantaneous UL and iL After Commutation for Transients (LC) Physics
  • Thread starter builder_user
  • Tags
    Physics
In summary: Closed. So these are the initial conditions for after the switch is closed.You should be able to calculate the steady state value of the voltage on the capacitor, and the steady state current flowing through the inductor before the switch is closed.These are going to serve as initial conditions for after the switch is closed.In summary, before the switch is closed in the given circuit, the capacitor will have a charged constant voltage and no current will flow through it, while the inductor will have a constant current and no voltage drop. After the switch is closed, the circuit will be modified and the capacitor will still retain its initial voltage, while the inductor will still have its initial current. These initial conditions will serve as starting points for the
  • #36
All values are the same
Ur3 will be iL*R3=7.68 after commutation?
  • #37
Ur3 will be iL*R3 after commutation?
Right. The inductor maintains the same current as before the switch closes (at least for a brief instant).
So after the switch closes the circuit looks as in the attached figure, keeping in mind that C1 and L1 have their initial conditions. The idea now will be to develop the differential equations for the circuit. The current supply J and resistor R2 could be converted to a Thevenin equivalent, leaving two loops for KVL. Or you might try using a KCL approach.
A good approach might be to write the equations in differential form, convert to Laplace (allowing you to insert initial conditions), then solve for the desired variable.
  • #38
i2=i1+i3
i2*R2+Uc=E
i3*R3+Ldi/dt=0
and Uc=3.84?
But UL=-3.84?
  • #39
That's fine. Keep in mind that UL and UC are initial conditions that will go into the s-domain (Laplace transformed) equations.
  • #40
I forgot Uc in my third equatation.
Why I need two previous equatations at all?
I think one will be enough
this one
i3*R3+Ldi3/dt+Uc=0
  • #41
The voltage on the capacitor is not going to stay at Uc indefinitely; it's only an initial condition. If you want to find UL(t), then you'll have to solve the equations.
You should be able to notice that there are R L and C components in the circuit, so you should expect a second order system. There will be a decaying oscillation if the damping is low, or a smooth decay if the system is overdamped.
  • #42
My result
i(t)=-Uc/L+e^((-r3/L)*t)*C
Uc=3.84
I think it's wrong.
  • #43
How to do it correct?
  • #44
Using whatever is your choice of circuit analysis technique you need to write out the equations for the loops (or nodes). Convert to Laplace form (s-domain) including the initial conditions, then solve.
I have not taken the time to write them out and solve them at this point, and what equations are written will depend upon your choice of analysis method. Perhaps you should post your equation attempt so that we can look at it.
  • #45
I have already posted them
I use this equatation to find i(t)
i3*R3+Ldi3/dt+Uc=0
  • #46
I've solved it correct, but It seems strange to me that equatation...System must have and i(t)=Cdu/dt and Ldi/dt
The problem is to make correct system of equatation
If I find correct equatation to solve i'll can transform it in Laplas form
At the mail problem is that I need to have my work done today
  • #47
Well, I'm glad that you've solved it. Congratulations.
I don't find it surprising that the equations will involve changing values on both the capacitor and inductor; it's a second order system, and the configuration is capable of producing oscillations (ringing) or other "excursions" when its perturbed (like the throwing of the switch does). The precise response depends upon the component values (damping).
  • #48
I make new equatation and solve for transformed scheme
J2=(J*1/sC+L*i0-U/s)/(R3+s*L+1/s*C)
Here my result.Is it correct now?
i(t)=(1.9-34464*j)*e^((-1428+1421j)*t)+(34464-1.9j)*e^((-1428-14211*j)*t)*i
u(t)=L*di/dt=(342835-34469*j)*e^((-1428+14211)*jt)+(342835+34469*j)*e^(-1428+14211j)t
  • #49
I'm not understanding how you arrived at your equation for J2 (is that the current for the inductor?). There are two loops so there should be two loop equations. In your figure, is J/p meant to be a current source in series with resistor R2? How did you get from the original circuit with a current source in parallel with Rs to one with it in series? I see that you've drawn in the s-domain sources associated with the initial conditions. That's good.
If I plug t = 0 into your u(t) solution the answer I see looks a bit large. Is it scaled somehow?
  • #50
But there is only one variable.---J2(on resistor R3).Besides if I make 2 equatations Mathcad can't find J2
  • #51
But there are two loops that interact. You only need to solve for the current in the second loop, but the first loop still plays a part!
  • #52
So,I do not need first loop as equatation to solve?
  • #53
You need the first loop equation in order to eliminate its current (say, i1) from the second loop's equation. But you don't have to solve for i1.
You have solved circuits with two loops before. You know that the loop currents in both loops affect each other in the solution. So you have to write the equations for both loop currents (i1, i2), and eliminate i1 from the the loop 2 equation. Solve for i2.
  • #54
But I know J - so it's i1?
  • #55
I don't believe that your circuit with J in series with R2 is correct. The original circuit (with the switch closed) has J in parallel with R2 and in parallel with C1. I don't see how you could go from there to having J in series with R2.
If J were a voltage source, then yes, I would agree. Then you would have the Thevenin equivalent of J and R2.
  • #56
Correct result is sth like this.(I've only changed direction of Uc. It was mistake but it wasn't a big problem)
i(t)=7.3*e^(-2863t)-3.89*e^2.73t*cos⁡(133t)-0.4175*e^2.73t*sin⁡(133t)
