- #141
DaveC426913
- 6,168
Definitely overdesign.AlephZero said:If you want to everything to stay "rigid", you have two basic choices. Either you do a proper stress analysis, or you just overdesign everything.
I'm pretty sure it would deform by at least a mm or two. It could be mitigated by some internal bracing.AlephZero said:For a small scale experiment, I'm assuming a glass aquarium tank isn't going to deform much under the water pressure, otherwise the glass would crack. You could check that assumption with a measuring rod cut to fit accurately inside the tank when it is empty, and check the amount of clearance when it is full.
I think the danger is that what might work in a scale test will likely not scale up well. We're dealing with masses cubing as we scale. This will be an excellent demonstration of Galileo's square-cube law.AlephZero said:Designing experiments is often a matter of trial and error. Starting with something simple and cheap to find out what is really important in practice is often a good strategy.
