Question about supercooling
  • Thread starter kelvin490
In summary: The driving force is the difference in free energy between the two phases, which is minimized at the equilibrium temperature.
kelvin490
During the cooling of a liquid, if no impurity of site of nuclearation, an appreciable solidification will begin only after the temperature has been lowered to below the equilibrium solidification (or melting) temperature. This phenomenon is termed supercooling. My question is, if supercooling is necessary, what is the meaning of "equilibrium" solidification (or melting) temperature (e.g. 0oC for water)?
Another question is, at precisely equilibrium temperature, will liquid becomes a mixture of solid and liquid or nothing will change? Some may say solid and liquid co-exist but what is the driving force if it is not energetically favorable for either side at exact equilibrium temperature? What determines the portion of liquid and solid at this temperature if they really co-exist?
At the instant when the solidification starts, the temperature shoots back up to the solidification temperature. For instance, while you can have liquid water below 0°C, it will only make ice while exactly at 0°C.
You can have any proportion of liquid and solid, in constant equilibrium, when exactly at the temperature of the phase transition. To actually convert liquid water to ice, additional heat must be extracted from the water. Usually, the liquid will exchanging heat with an environment below the transition temperature (such as a freezer at -18°C).
You could imagine an ideal environment for which you could control the temperature exactly. Setting it to 0°C, you would cool down the water to zero without forming any ice. Then reducing the temperature an infinitessimal degree below 0°C, some ice would start forming (assuming no supercooling), and bringing back the temperature to exactly 0°C would stop the crystallization process and maintain the proportion of solid over liquid.
1. What is supercooling?
Supercooling is a phenomenon in which a liquid is cooled below its freezing point without solidifying. This can occur when the liquid is not disturbed and does not contain any impurities or nucleation points, which are needed for ice crystals to form.
2. How is supercooling achieved?
Supercooling can be achieved by rapidly cooling a liquid or by reducing its pressure. It can also occur naturally in some substances, such as water at high altitudes.
3. What are the practical applications of supercooling?
Supercooling has several practical applications, such as preserving biological samples, storing perishable food items, and creating specialized materials with unique properties.
4. What are the risks of supercooling?
The main risk of supercooling is that the liquid may rapidly solidify if disturbed or if a nucleation point is introduced. This can cause the liquid to freeze suddenly and potentially damage equipment or containers.
5. Can supercooling occur in all liquids?
No, not all liquids can be supercooled. Liquids with high impurities or those that are highly viscous are less likely to supercool. Additionally, some substances have a lower supercooling limit, meaning they cannot be cooled below a certain temperature before solidifying.
  • Thermodynamics
  • Materials and Chemical Engineering
  • Atomic and Condensed Matter
  • Classical Physics
  • General Math
