At what position is the net electric field equal to zero?
In summary, the net electric field is the overall electric force and direction experienced by a charged particle at a given point, calculated by adding all individual electric fields vectorially. It is equal to zero when the sum of all electric fields at a given point is zero, which can occur when the magnitudes of the fields cancel or when they are directed in opposite directions. The net electric field is only zero at the center of a charge distribution if it is symmetric and the electric fields cancel. However, it can also be zero at other points within the distribution if the conditions for cancellation are met.
laxwarrior
Two charges are separated by 1.0 m. Q1 has a negative charge of 4.2 µC and Q2 has a positive charge of 1.4 µC. At what position is the net electric field that is produced by both Q1 and Q2 equal to zero?
Extra Credit: If a +5.0 µC charge is placed at this position, what force would act on it as a result of Q1 and Q2?
You need to show your attempt at this question before we can help.
The net electric field will be equal to zero at a position equidistant from both Q1 and Q2. This position can be found by using the equation E = kQ/r^2, where E is the electric field, k is the Coulomb's constant, Q is the charge, and r is the distance between the charges. In this case, the charges are separated by 1.0 m, so the net electric field will be equal to zero at a distance of 0.5 m from each charge.
If a +5.0 µC charge is placed at this position, it will experience a force due to both Q1 and Q2. The force can be calculated using the equation F = kQ1Q2/r^2. Plugging in the values for Q1, Q2, and r, we get a force of 1.4 x 10^-4 N, directed towards Q1. This shows that the force on the +5.0 µC charge is repulsive, as expected since Q1 and Q2 have opposite charges. The direction and magnitude of the force can also be determined by using the principles of vector addition.
1. What is the concept of "net electric field"?
The net electric field is the sum of all the individual electric fields at a given point in space. It represents the overall electric force and direction experienced by a charged particle at that point.
2. How is the net electric field calculated?
The net electric field is calculated by adding all the individual electric fields at a given point vectorially. This means taking into account both the magnitude and direction of each field.
3. When does the net electric field equal zero?
The net electric field is equal to zero when the sum of all the individual electric fields at a given point is equal to zero. This can occur when the magnitudes of the electric fields cancel each other out, or when the fields are directed in opposite directions.
4. Is the net electric field always zero at the center of a charge distribution?
No, the net electric field at the center of a charge distribution is only zero if the distribution is symmetric and the magnitudes of the electric fields from each charge cancel each other out.
5. Can the net electric field be zero at any other point besides the center of a charge distribution?
Yes, the net electric field can be zero at any point where the sum of all the individual electric fields is equal to zero. This can occur in other locations within a charge distribution if the conditions for cancellation are met.
