New Reply
Control of RH and Temp of Air
Share Thread Thread Tools
Sep20-12, 06:59 PM   #1
Hi,
I am trying to provide a humid air stream along some ¼” tubing, where I can roughly control the relative humidity and temperature, this doesn't need to be exact.
I already have a compressed air tank, regulator and flow meter to provide the correct flow rate.
I need to find out whether bubbling air through water will result in 100% relative humidity and whether or not this depends on the the amount of water it is bubbled through?
If so I can heat the water to get the right amount of moisture in the air at 100% humidity and then heat the air further in the outlet pipe in order to lower the humidity to the level I require.
Please excuse my ignorance as I do not have an extensive knowledge of this subject, any help or guidance you can give me will be greatly appreciated.
Cheers,
Rob.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
New Reply
Thread Tools
Similar Threads for: Control of RH and Temp of Air
Thread Forum Replies
Temp to raise fluid temp inside a container - Heat transfer & thermodynamics Engineering, Comp Sci, & Technology Homework 7
Calculate refrigerant temp inside evaporator based on exit temp and pressure Classical Physics 0
PID temp control for distillation (was "Before i ask") Chemistry 8
Chemistry: 2 samples of the same liquid but different temp - final temp? Biology, Chemistry & Other Homework 9
