- #1
MrSponge
- 20
- 0
Hi,
I was wanting to insert 1 inch foam balls inside a container of ferrofluid, causing the foam ball to float.
A normal one-way water valve would not let the ball through without any leakage (I believe), therefore I think that If i can build a valvue that consists of a ring of neodynium magnets with the pole that repulzes the ferrofluid pointing towards the centre with the attractive pole hidden. Fitted at an angle pointing towards the ferroufluid and away from the feed tube of foam balls.
I believe that this valve with just over 1 inch in diametre would be sufficient enought to allow the foam ball through ( and break surface tension) and to be absorbed into the liquid which will then float up. Without allowing ferrofliud to flow into the feed pipe.
Thankyou and I hope this is clear
