Can Photons interact with Quantum Vacuum Fluctuations?
In summary, Photons can interact with and be absorbed by Quantum Vacuum Fluctuations. This can potentially cause an imbalance between particles, resulting in the apparent disappearance of a photon and the appearance of a sub-atomic particle. These interactions are rare and more likely to occur with high energy photons. The Heisenberg-Euler Lagrangian and high intensity lasers have been used in studying Photon-Photon scattering, and it is believed that these interactions may contribute to the excess photon emission in the cosmic microwave background radiation. However, the sky remains dark due to the finite speed of light and age of the universe.
sdf156
Can Photons interact with or be absorbed by Quantum Vacuum Fluctuations?
Would it be possible for a photon traveling in space interact with a particle from a quantum vacuum fluctuation?
Say you have a particle antiparticle pair arise at just the right moment and the right frequency that one half of the pair absorbs a passing photon.
Would that cause an imbalance between the two particles enough to cause the photon to seem to disappear and a sub-atomic particle to apprear in its place?
Can it be possible to then detect particles (probably very very few) scattering from a laser beam?
I would imagine that if this is possible, the particles that would arise from such interactions, would be really light-weight, such as neutrinos, or lighter.
If they were neutrinos then we would have no reliable way of detecting them. If the photons were very high energy, then you would, and do expect to see particles produced.
Nice topic. In fact I'm thinking of doing my master thesis project about Photon-Photon scattering.
I would really appreciate some good links/references about Photon-Photon scattering in general, and the following subjects in particular:
*The Heisenberg-Euler Lagrangian, and the resulting nonlinear corrections to Maxwell's vacuum equations.
*Suggested Photon-Photon scattering detectors.
*High intensity lasers in general.
*Ultra-short intense lasers (chirped pulse amplification).
*Free electron laser (FEL).
According to Olbers's Paradox, if there should be a star wherever you may look, then the sky should be awash with light and heat.
Now it was Edgar Allen Poe who then gave the answer that is accepted, saying that if the speed of light is finite, and the age of the Universe is finite, then the sky can be dark even in a spatially infinite Universe.
Ok, good answer, but think about it, isn't it true that if you had the most powerful telescope, and pointed it in any random direction, you would find clusters and clusters of galaxies?
So at least, why isn't the sky glowing a soft red? ( it does glow in microwaves though, but softly)
I think that if Photon-vaccum interactons occur, an interaction would be a very rare event, it would have to take place when a photon of light of the right polarization and energy, meets up with a particle anti-particle pair of the right energy and polarization, so that the photon is able to kick up the energy level of one of the particles.
Now photons of a given radiation, such as x-rays, or even gamma, would have a much better chance at interacting, because the energy borrowed from the vacuum would be more likely in the shorter wavelengths, but still, there is a probabbility, albeit small, that energy on the spectrum between ultraviolet to infrared, may be manifested.
At least, this may still result in an excess photon being emitted when the two particles pay back Mr. Heisenberg, who may dutifully return the change.
A while back, as part of a discussion, I googled on photon-photon and also two photon. A number of research sites came up. There's a good deal out there. My impression was that photon-photon interactions only happen in situations of high energy, because they require some almost real pair production as an intermediate.
Welcome to Physics Forums sdf156!
Just to address your comment about Olber's Paradox: yes, in any direction that you look, you will 'see' the cosmic microwave background radiation. As you know, it's spectral energy distribution follows the 2.73K black body curve almost exactly.
However, when the Hubble Space Telescope looked http://hubblesite.org/newscenter/newsdesk/archive/releases/2004/07/ it saw a great deal of black sky. It's likely that it detected proto-galaxies, among the first to be formed in the early universe. We also know what the faint outer extensions of the closer galaxies in the image will look like, when even deeper images are taken. Hence we could, now, simulate an image of the same piece of sky as if taken by a diffraction-limited 100m space telescope, integrating for 100 million seconds (and when we get around, finally, to taking such a picture, it won't look much different from our simulation). What would such an image - which would consume more disk space than that on all PF members' hard drives, combined - look like? Lots and lots of black sky. In other words, very few lines of sight to the edge of the universe actually intersect with the surface of a star; the night sky is, truly, dark.
selfAdjoint said:
... My impression was that photon-photon interactions only happen in situations of high energy, because they require some almost real pair production as an intermediate.
Floyd Stecker has some discussion of this and links in his survey
(in the "Rovelli's program" reference collection of links)
there is an energy threshold level for gamma rays above which
the spectrum of gamma rays is expected to be influenced by
scattering
between the original gamma radiation and (of all things) CMB photons
IIRC it acts as a cutoff, because of photonphoton scattering between
gamma and CMB we don't expect to observe gamma above a certain energy
(Nereid may already have discussed this in some other thread)
this cutoff energy level has a name, which I forget, and there is
quite a bit of discussion about exactly where it ought to be and
whether it has already been observed or will soon be observed
anyway photonphoton scattering is beginning to play a real (if minor)
role in observational astronomy
somebody observed that this is a good thread topic and I agree!
Floyd Stecker's paper "Cosmic Physics: the High Energy Frontier"
is just one possible survey which IIRC mentions this, there may be better
Nereid said:
... Lots and lots of black sky. In other words, very few lines of sight to the edge of the universe actually intersect with the surface of a star; the night sky is, truly, dark.
the point I guess being that most lines of sight go clear back to a time when there wasnt any stars
lines of sight apparently don't go back any further than redshift z = 1100
which corresponds to when the universe was full of hot plasma
which scatters lines of sight---it's opaque like the surface of the sun
and that hot plasma of maybe 3000 kelvin now looks like 2.73 kelvin because of the z = 1100 redshift, so it is virtually black
an object at 2.73 kelvin glows hardly at all, it is very dark
the mathematics of why the sky is dark seems to boil down to
observing that
3000 divided by 1100 is around 2.73
Good point marcus, my reply was kinda sloppy.
In terms of Olber, the sky is "dark" in the sense that few lines of sight hit a star (or a cloud of gas & dust, which, following Olber, would be heated up to the temperature of the surface of a star). However, it is not 'black', because there are those microwaves.
I should also have said 'the edge of the *observable* universe', which is the CMBR today ... when we develop cool neutrino telescopes (pun intended :eek: ) we will be able to 'see' further.
Yes!
today's neutrino telescopes can only see the comparatively warm or hot neutrinos----what a thought.
but to be able to see neutrinos around 2 or 3 kelvin!
At some point in each day I always am wondering why we are
not all astronomers. why doesn't everybody study astronomy?
i didnt notice any sloppiness, was only corroborating and elaborating
as usual
The Polarisation of a vacuum is described as follows . A photon traveling through space , undergoes transformation into a ‘virtual’ electron-positron pair , which undergo annihilation giving rise to a photon . And so on. The reason that they are able to do so is because a vacuum is thought to contain infinite energy as a result of the Heisenberg Uncertainty Principle . How in view of this statement , can there be any doubt that a photon does interact with the vacuum ? The Vacuum might be taken as being all pervading , occupying the whole of space. It follows that photons are propagated through space through interactions with the vacuum. Being annihilated and giving rise in the process to new photons. This is similar to the manner inb which photons are propagated through a solid and is the whole point of QED.
Explain how a photn interacts with quantum vacuum
Can someone explain in full how a photon will interact with a quantum vacuum. The previous entries do not explain how 'exactly' a photon will 'interact' to become a virtual (electron-positron) pair.
Can someone explain this please.
Does anyone have a reference book or internet which explains this in detail?
Many thanks.
If by interaction of HE single photon with clear vacuum (zero point energy of QM noise,without any thermodynamics of cosmic background radiation) is meant production of REAL electron positron pair -this is not going to happen.On other hand,two HE photons can interact and produce real pairs particle-antiparticle.Higher the energy higher the probability that to happen.
Photon-photon colliders :approve:
This might interest you:
http://focus.aps.org/story/v8/st21
Then click on the enclosed physical review article
Creator :approve:
(TeV) Thanks for your entry and explanation about two photons being able to create a real pair (particle and anti-particle).
Can anyone also explain whether it is possible for a single photon in a quantum vacuum to react with a temporary virtual/real pair (either with the particle or anti-particle (electron or positron)). If so what happens?
Many thanks.
A photon crossing the vacuum has no time to interact with anything, because its proper time is zero. Photons in the presence of matter (massive particles) can interact with the vacuum.
Creator :approve:
Thanks for your help. Actually my supervisor will be one of the authors!
Do you mean that photons can't interact with vacuum or...? Don´t think I get you?
We discussed this a few weeks ago. Photon-photon scattering is a real effect, and is important for certain highly energetic cosmic phenomena.
Its a second order effect in the e/m sector (primarly via the box diagram) and is measurable (in fact it has been measured).
If the interaction goes via graviton exchange, you get some cool predicted effects as well (though its completely swamped in practise).
The below quote (from selfAdjoint) does not make sense (perhaps?) - surely if a single photon travels through a quantum vacuum it will take a certain amount of time to travel.
selfAdjoint: A photon crossing the vacuum has no time to interact with anything, because its proper time is zero. Photons in the presence of matter (massive particles) can interact with the vacuum.
Does anyone know what happens when:
1) a single photon reacts with an electron from the real pair (of electron and positron) in the quantum vacuum?
2) a single photon reacts with a positron from the real pair (of electron and positron) in the quantum vacuum?
Many thanks
Many thanks
Does anyone have an answer to the above two questions? Please let me know if anyone has answered them previously but it appears as if they have not been answered...?
if i understood the questions 1 and 2 right than the straightforward answer is :yes ,photon interacts with charged real particles such as electrons or positrons.Basic staff of electromagnetism.I don't know what seems to be problem about that.
cheers
P.S. read once again your private message inbox folder.I remember I have answered your question regarding photon and virtual pairs as well.
The one question was "surely the photon takes some time...?" No. In relativity anything traveling at the speed of light accumulates no proper time (its own elsapsed time) and has no rest frame. So to the photon, the moment when it is emitted is immediately succeeded by the moment when it is absorbed. This is a standard prediction from relativity and has been discussed a lot on the Relativity board in the PF forum.
As far as the two questions about interacting with a virtual pair are concerned, I repeat there is not time for that to happen on what appears to us to be the photon's path through space. Pair production happens when there is othe energy around than just the photon, specifically real (observable) massive particles. When pair production does happen, the photon ceases to exist, as all its energy goes into the masses and momenta of the two new particles.
Now I'm getting confused. According to QED, photon-photon scattering is an effect arising due to interaction between photons and virtual electron-positron pairs in vacuum. Are you saying this is not true, or do I just not get you?
It appears thta SelfAdjoint is suggesting that the photon accumulates no proper time (its own elapsed time) from the prediction of Relativity - this is clear as the it is traveling at the speed of light but of course it is traveling through a vacuum and will 'relatively' take time to travel through this 'relative' quantum vacuum space. Therefore SelfAdjoint says that the photon has no (own elapsed time) to interact with the quantum vacuum, but does interact with the quantum vacuum because it travels through the quantum vacuum and this will take time 'relative' to the quantum vacuum.
TeV also says that ''yes ,photon interacts with charged real particles such as electrons or positrons.Basic stuff of electromagnetism.''
So is it correct to say that the photon which will take time 'relative' to the quantum vacuum, can then in this time interact with the charged real particles such as electrons or positrons that emerge in the quantun vacuum due to the uncertainty principle?
If this is correct - then the photon will deflect the electrons and positrons in the quantum vacuum, as indicated in the 'basic stuff of electromagnetism', and therefore the photon DOES interact with the quantum vacuum.
Can someone please confirm if this is what happens, and if so will the delflected electrons or positrons attract of deflect future photons traveling through the quantum vacuum.
Thanks.
1. Can photons interact with quantum vacuum fluctuations?
Yes, photons can interact with quantum vacuum fluctuations. In fact, they are constantly interacting with the fluctuations in the quantum vacuum, which is the state of lowest possible energy in a vacuum.
2. How do photons interact with quantum vacuum fluctuations?
Photons interact with quantum vacuum fluctuations through virtual particle interactions. Virtual particles can pop in and out of existence in the vacuum, and photons are able to interact with these virtual particles.
3. What is the significance of photons interacting with quantum vacuum fluctuations?
The interaction between photons and quantum vacuum fluctuations is important in understanding the fundamental nature of light and the vacuum. It also has implications in areas such as quantum field theory and cosmology.
4. Can we observe the interaction between photons and quantum vacuum fluctuations?
No, we cannot directly observe the interaction between photons and quantum vacuum fluctuations because the fluctuations occur at a subatomic level and are constantly changing. However, we can indirectly study their effects through experiments and theoretical models.
5. Are there any practical applications of understanding the interaction between photons and quantum vacuum fluctuations?
Currently, there are no immediate practical applications of this interaction. However, further research in this area could potentially lead to developments in quantum technologies and advanced understanding of the universe.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
