Does a particle have negative kinetic energy in delta function wall
In summary, the conversation discusses the concept of negative kinetic energy in quantum mechanics, specifically in the case of a delta function potential. The issue also arises for any binding potential, such as a potential barrier. While the expected value of kinetic energy is always positive, there is no kinetic energy function in standard quantum mechanics. However, a position-dependent function can be defined for any operator and wave function, which can be useful in understanding the classical limit of quantum mechanics. However, this function is not a part of the structure of quantum theory itself and cannot be used for formulating conservation laws or frame changes.
rar0308
56
E is finite and V is infinite, So T should be negative infinite
Can you please give more details about the situation you are contemplating? "delta function wall" is not very clear.
Well his question about negative kinetic energy applies to any kind of bound particle in the region with [itex]V(x) > E[/itex]. He's specifically talking about the case where [itex]V[/itex] is a delta-function potential, but the issue comes up for any binding potential.
For example, in the case of the potential
[itex]V(x) = 0[/itex] for [itex]-L < x < +L[/itex]
[itex]V(x) = V_0[/itex] for [itex]|x| > L[/itex]
the energy eigenfunctions look like this:
[itex]\Psi(x) = A cos(k x) + B sin(k x)[/itex] for [itex]-L < x < +L[/itex]
[itex]\Psi(x) = C e^{-K |x|}[/itex] for [itex]|x| > L[/itex]
where
[itex]k = \sqrt{2m E}/\hbar[/itex]
[itex]K = \sqrt{2m (V_0 - E)}/\hbar[/itex]
So in the region [itex]|x| > L[/itex], the kinetic energy operator [itex]-\frac{\hbar^2}{2m} \frac{\partial^2}{\partial x^2}[/itex] gives a negative number, [itex]-\frac{\hbar^2}{2m} K^2[/itex]
My first inclination is to say that the operator [itex]-\frac{\hbar^2}{2m} \frac{\partial^2}{\partial x^2}[/itex] doesn't actually mean kinetic energy except for unbound particles, but maybe there's something more to be said.
Yes, what stevendaryl said is exactly what I'm curious about.
But the question also doesn't make any sense. A "delta function" is something that is infinitely thin, meaning it doesn't have a width. So there's no "inside" for it to be in.
A delta function potential barrier is to illustrate the condition where a wavefunction can be continuous, but its derivative isn't! There is a derivative jump across the delta function. If you try to "rationalize" and try to analyze this problem beyond what is given, then you run into absurdities such as this.
Zz.
Yes, Kinetic energy can be negative in quantum mechanics which leads to penetration into a region that would be forbiden in classical mechanics allowing for instance for tunnel effect.
No. Kinetic energy is not a position dependent property. To be precise, the only sensible definition of kinetic energy is the quadratic form <psi|T|psi> for normalized |psi>. And such a state |psi> which is entirely contained within the region where you'd classically expect "negative kinetic energy" has an localization induced momentum uncertainty that makes the total kinetic energy positive.
There's a theorem which is not hard to prove that <psi|T|psi> is always >0 for states on the hilbert space of square integrable functions, because otherwise they could not be normalized.
Cheers,
Jazz
Cheers,
Jazz
We're not talking about exactly the same thing. The expected value will be positive. But the question is about the value of the function before the integration is performed to find the expected value. At least that's how a read it.
What function? There is no kinetic energy function is quantum theory. And the expectation value IS the kinetic energy.
Cheers,
Jazz
Cheers,
Jazz
Well, I would say that kinetic energy is an operator, not an expectation value.
As for a kinetic energy function, there isn't one in standard quantum mechanics. But we can define one (I only know of one case where this was ever done):
For any operator [itex]\hat{O}[/itex] and any wave function [itex]\Psi(x)[/itex], we can define a position-dependent (and time-dependent, if [itex]\Psi[/itex] is time-dependent) function [itex]O_Q(x)[/itex] via:
[itex]O_Q(x) = \dfrac{\hat{O} \Psi(x)}{\Psi(x)}[/itex]
If [itex]\Psi(x)[/itex] is an eigenstate of [itex]\hat{O}[/itex] then [itex]O_Q(x)[/itex] is the eigenvalue. Otherwise, [itex]O(x)[/itex] is in general a complex-valued function.
Defining such functions can be useful in seeing how QM approaches the classical limit. For example, for the special case of momentum, we have:
[itex]p_Q(x) = -i \hbar \frac{d}{dx} ln(\Psi(x))[/itex]
The corresponding classical "momentum function" is:
[itex]p_C(x) = \dfrac{\sqrt{2m (E - V(x))}}{\hbar}[/itex]
They both become pure imaginary in the "forbidden" region where [itex]E < V(x)[/itex]
Kinetic energy is a property of a state. Operators are not state dependent, so kinetic energy is the quadratic form of the operator. That's the quantity that enters conservations laws too.
That's only a sensible construction in the context of approximations (like WKB), but not as part of the structure of quantum theory itself. Specifically you cannot formulate conservation laws or frame changes coherently with such a function.
Cheers,
Jazz
Let's do a thought experiment. How might you measure the kinetic energy of an electron? Well, it's hard to measure a single electron, but you could measure the average energy of a stream of electrons. You could set up a probe with a retarding potential in front of a detector, and measure the rate of detections. Decrease the potential until the counts start to drop off exponentially, and that gives a measurement. Consider some electrons trapped in a potential well, and we stick the end of the probe in a region which is classically energetically inaccessible to the electrons. If we set the potential in the probe to a positive potential relative to the probe tip, then some electrons can tunnel through the wall into the probe into the detector. If we label the kinetic energy by the potential difference in the probe, then it seems like the kinetic energy is negative. Of course, you could say that this is an incorrect analysis of the probe. Or this is a peculiar definition of kinetic energy. Anyways, the physics are understood, it's just a matter of terminology.
The confusion of negative kinetic energy comes about in the following way. First, most physicists believe that the energy of the system described by the Hamiltonian eigenfunction ##\phi_n## corresponding to negative value ##E_n## is a definite number that has to be equal to ##E_n##. Then, since
(\hat T + \hat U) \phi_n = E_n \phi_n
one may be lead to believe on the grounds of energy conservation that
\hat T \phi_n = [ E_n - \hat U(q) ] \phi_n
implies that kinetic energy of the system at ##q## is ##E_n - \hat U(q)##. As U goes to zero at large distances, there is always region of configuration space where this number is negative.
However, from the definitino it is clear that the kinetic energy can have only positive values, so something is wrong.
The fallacy of the above derivation is that the kinetic energy of the system at ##q## is not necessarily ##E_n - \hat U(q)##, because the total energy of the system is not necessarily ##E_n##. ##E_n## is just an eigenvalue of the Hamiltonian.
If we believe in the validity of the momentum representation and derived probability distributions for momentum, it can be easily shown that the energy of the system can be larger than this value.
Take harmonic oscillator and let ##\psi## be the "ground state" function with eigenvalue ##E_0 = \frac{1}{2}\hbar \omega##. The kinetic energy alone can be larger than the eigenvalue ##E_0##, due to the following reason. The kinetic energy is a function of momentum, and in momentum representation the average value of the kinetic energy is
\langle T \rangle = \int_{-\infty}^{\infty} \frac{p^2}{2m} |\psi(p)|^2 dp.
Momentum ##p## takes only real values, so the kinetic energy assumes only values from ##\langle 0,\infty)##.
The probability distribution ##|\psi(p)|^2## is a Gaussian function non-zero even for ##p## so large that the corresponding kinetic energy ##p^2/2m## is greater than the eigenvalue ##E_0##. Since the potential energy is positive for all ##q##, the total energy may be larger than ##E_0##.
Since the kinetic energy cannot be negative, the total energy clearly is greater than ##E_0## for all ##q## for which ##U > E_0##, i.e. whenever the particle is far enough from the minimum of the potential.
I don't think that makes any sense, any more than saying that the position is a property of the state. In non-relativistic quantum mechanics, the position operator has the same sort of status as the kinetic energy.
The expectation value of kinetic energy, or position, or momentum, or whatever, is a property of the state. But those quantities themselves are not properties of the state.
My point is that there is a way to make sense of a position-dependent kinetic energy (or momentum, or whatever). It's useful for understanding the relationship between quantum mechanics and the classical limit.
Kinetic energy cannot be state independent (like being just the operator you suggested), instead, it must be a function of the state of the system. We know that kinetic energy is a sensible concept, even in quantum mechanics, because of the conservations laws that involve it. That makes it a property of the state. It doesn't mean that a state necessarily has to be in a kinetic energy eigenstate. It's the "expectation value" (which is really a misnomer, because it automatically implies you perform a measurement) for which the conservation law holds, so that is the proper definition of kinetic energy in a quantum context.
And my point is that this is highly misleading. Suggesting that there is any such property as kinetic energy that you can associate with position implies an underlying structure of some sort where the particle is actually located somewhere, in form of a single point, but we just don't know where. This is exactly the kind of comparison to classical physics that confuses the heck out of students and results in weird debates about the real meaning of quantum physics. It also implies a much too simplified and superficial transition from quantum to classical. But most importantly, there is no way to make sense of any such definition in terms of conservation laws.
Cheers,
Jazz
I don't understand what you're saying. Why is kinetic energy more of a "property of state" than position is?
How does having a position-dependent kinetic energy function imply such a thing, any more than having a position-dependent wave function [itex]\Psi(x)[/itex]?
I think avoiding confusing students is way over-rated. Confusion is an important stage in reaching understanding. I think for any given topic, such as quantum mechanics or relativity, or whatever, the more different ways you know how to think about it, the better.
What's the proof that there is no way to "make sense of any such definition in terms of conservation laws"?
Actually, understanding the classical limit using "momentum functions" was the topic of research done by my advisor years ago. I thought it was very interesting, even though not much came of it.
There is a conservation law for energy(-momentum), and that law holds independently from the system being in a corresponding eigenstate. The law specifically refers to the "expectation value" of the involved quantities, which makes them physically meaningful attributes of the state of the system. That's what I call a property.
For position you have no such conservation law, and it makes much less sense to talk about the expectation of position as a physically relevant quantity. In some situations however, it might make sense, but that's not really my point, as we're discussing energy and not position.
Specifically the operator of (kinetic) energy is not what you would call energy as such, because it does not depend on the state, which energy does. The operator is important for the mathematical formulation of energy, but it itself is not energy, it's quadratic form together with a state is.
The wave function is a state that you can expand in any basis that you like. The kinetic energy scalar you proposed does not have this property, it's not a vector in a linear space in any physically meaningful way.
But this is not a good or meaningful way to think about it, so it doesn't really help you to get a different perspective on things. But it does suggest a relationship between quantum physics and classical physics that does not exist on this level and it also suggests a classical hidden variable interpretation where the particle is at a single position, which you can use to construct classical energy quantities. This is misleading and undermining the very idea of having a theory that is agnostic of the choice of a basis and that, as we know today, does not have any classical explanation.
The proof is simply that the conservation law does not involve these quantities, and the formulation of energy conservation in quantum theory is unique.
Anyone can research whatever he wants. But whatever comes out, it will certainly not revolutionize our understanding of energy conservation in quantum theory or the quantum to classical transition.
Cheers,
Jazz
But kinetic energy by itself isn't conserved, so I'm not sure how it's relevant that total energy is conserved. They are two different operators.
We have: [itex]\hat{H} = \hat{K} + \hat{V}[/itex] where [itex]\hat{K}[/itex] is kinetic energy, and [itex]\hat{V}[/itex] is potential energy. It doesn't make any sense to me for you to say that the kinetic energy is a function of state, and the potential is not. But the potential is explicitly position-dependent, so it can't be a function of state.
Well, I think that what you are saying is not a good or meaningful way to think about it. So there.
You're making claims that are beyond what you actually know.
On the other hand, I DO know what I'm talking about, and I agree that nothing much came of Dr. Leacock's research. So you're right, but a guess doesn't count for much.
Hamilton-Jacobi Formulation of Quantum Mechanics
Robert Leacock's approach to quantum mechanics is a quantum version of the Hamilton-Jacobi formulation of classical mechanics. It's mentioned as one of the nine formulations of quantum mechanics in this review article:
https://www-physique.u-strasbg.fr/cours/l3/divers/meca_q_hervieux/Articles/Nine_form.pdf
The technique itself is described here:
http://siba.unipv.it/fisica/articoli/P/Physical%20Review%20D_vol.28_no.10_1983_pp.2491-2502.pdf
Going from total energy to kinetic energy is only a matter of fixing a frame, which I assumed to have happened.
That logic is flawed. Only because it doesn't usually make much sense to speak of the position of a state, the actual potential energy associated with a superposition thereof can very well be a valid and physically meaningful concept. The potential energy does NOT depend on the expectation value of position, which is what you're arguing about, it depends on the actual state expansion in position.
That's not just me, it's everyone who is investigating the structure of quantum theory.
Now that's a claim that is beyond your knowledge.
So what are you arguing about?
Cheers,
Jazz
I'm sorry, that doesn't make any sense. How does "fixing a frame" convert kinetic energy into total energy, or vice-versa? They are different things.
What you are saying doesn't seem to make any sense.
You clearly don't know anything about the topic of quantum momentum functions, or quantum hamilton-jacobi theory. It's an obscure topic, so almost nobody knows about it, but it's clear that you don't know anything about it. I actually do know something about it, since it was developed by an advisor of mine. I'm not saying this to put you down--it's perhaps deservedly an obscure topic--but it's a fact that you don't know anything about it.
Because you are saying incorrect things to argue about something that you don't know anything about. You don't know anything about Hamilton-Jacobi theory, but you are making pronouncements about how meaningless it is.
If that doesn't make sense to you then you might consider to refresh your knowledge on relativistic energy and the Poincaré group, not even specifically in quantum theory.
Please point out which of my statements was incorrect. The fact that you don't understand them doesn't prove anything. And claiming I don't understand Hamilton-Jacobi (which is almost entirely unrelated to what we're discussing here) is not really helpful. If this is the level you want to take this argument to, then I'm out. It sounds to me more like you're not wanting to admit that you might have been wrong and blaming me for that.
Cheers,
Jazz
Let me be a little more blunt: what you're saying is WRONG. We're not talking about relativistic quantum mechanics here, we're talking about nonrelativistic quantum mechanics. So that claim is at best a non-sequitur. But I don't see how it makes any sense from the point of view of relativistic quantum mechanics, either.
Except that quantum Hamilton-Jacobi equation is exactly what I am talking about. So it doesn't make a bit of sense for you to say that it is almost entirely unrelated. You're not making any sense.
So then, what exactly is wrong, and how? And what I said applies just as well to a nonrelativistic setting, but is not really harder to understand in a relativistic setting. So why should I restrict myself to making statement that could be refuted by a reference to relativity?
You really stopped discussing in this thread. I gave arguments and tried to explain the issues as good as I can. And you just accused me of writing nonsense without providing any real counter argument or asking constructive questions. So get back to arguments, point out where the problem is or leave it. My patience is nearly used up.
Cheers,
Jazz
stevendaryl said:
Except that the quantum Hamilton-Jacobi equation is exactly what I am talking about. So it doesn't make a bit of sense for you to say that it is almost entirely unrelated.
But it is not what I am arguing about. I was always referring to your statements long before you pointed to HJ. And what I said never applied to that either.
Cheers,
Jazz
I have pointed it out several times. Let's take an example of the harmonic oscillator: The Hamiltonian is:
[itex]H = -\frac{\hbar^2}{2m}\frac{d}{dx^2} + \frac{1}{2}k x^2[/itex]
The first term on the right is the kinetic energy operator, and the second term is the potential energy operator. The sum of the two is the total energy operator.
You said that "Going from total energy to kinetic energy is only a matter of fixing a frame."
That makes no sense whatsoever.
You said words. I wouldn't say you actually gave any arguments that made any sense.
I didn't say the words "Hamilton-Jacobi", but that's what I was talking about when I wrote down the definition:
[itex]p_Q(x) =−i\hbar \frac{d}{dx} ln(\Psi(x))[/itex]
This function [itex]p_Q(x)[/itex] obeys the "quantum Hamilton-Jacobi equation":
[itex]\frac{1}{2m}(p_Q^2 - i \hbar \frac{d}{dx} p_Q) + V(x) = E[/itex]
So I assumed that your response to me was about what I had written.
The first term on the left is the kinetic energy operator, and the second term is the potential energy operator. The sum of the two is the total energy operator.
No, you replied to my argument of why kinetic energy is a sensible physical property of a state, and I was never referring to the harmonic oscillator. The argument I used was using energy conservation, which is usually formulated for a free particle, and my statement referred to that. When you came up with potentials I explicitly stated that the potential energy of the particle is just as good a concept based on the expectation value and pointed out that your logic was flawed.
Right, and that's where the discussion ends for me.
Have fun,
Jazz
But the whole discussion has been about kinetic energy in the context of a potential function. When there's a potential function, the kinetic energy is not conserved. This is pretty basic stuff, and you seemed to be disputing it.
I cannot let this stand like that, so I'll add one more post just to point out how you have not even bothered reading what I wrote before. I've never claimed that kinetic energy isn't conserved. I said energy conservation in general contains one uniquely identifiable kinetic term (AFTER frame fixing) that is the kinetic energy. And this term is the quadratic form of the state over the kinetic energy operator. It doesn't matter if you add a potential to the energy conservation balance, it's still the same term. THIS is pretty basic, and it's YOU who is not getting it.
I'm out,
Jazz
1. What is a delta function wall?
A delta function wall is a theoretical construct in physics that represents an infinitely thin and infinitely high potential barrier. It is often used in quantum mechanics to model the behavior of particles in confined spaces.
2. Can a particle have negative kinetic energy in a delta function wall?
Yes, a particle can have negative kinetic energy in a delta function wall. This is because the delta function wall creates a potential energy barrier that can cause the particle to have a negative kinetic energy, meaning it is moving in the opposite direction of the barrier's force.
3. How does a particle's kinetic energy change in a delta function wall?
A particle's kinetic energy can change in a delta function wall due to the potential energy barrier. When the particle approaches the barrier, its kinetic energy decreases as it is repelled by the barrier's force. If the particle passes through the barrier, its kinetic energy may become negative.
4. Is negative kinetic energy in a delta function wall physically possible?
Yes, negative kinetic energy in a delta function wall is physically possible in the realm of quantum mechanics. However, it is not observed in classical mechanics, as it violates the principle of conservation of energy.
5. How does negative kinetic energy in a delta function wall affect the behavior of a particle?
The presence of negative kinetic energy in a delta function wall can significantly impact the behavior of a particle. It can cause the particle to reflect off the barrier, tunnel through it, or become trapped in a bound state. These effects are essential in understanding the behavior of particles in confined spaces and in the development of quantum mechanical models.
  • Quantum Physics
