What's the difference between a superlattice, lattice and sublattice?
In summary, a superlattice is a type of lattice arrangement in which different atoms occupy specific sites in a solid solution. It is often used in semiconductor structures for specific electronic and photonic properties. A lattice refers to a regular array of atoms in a crystalline solid, while a sublattice refers to the lattice of a specific element in a compound. A crystal is a solid with a repetitive arrangement of atoms, and its unit cell forms a space lattice.
asdf1
734
Superlattice:
A lattice arrangement in which solute and solvent atoms of a solid solution occupy different preferred sites in the array. (from About.com)
(solid-state physics) An ordered arrangement of atoms in a solid solution which forms a lattice superimposed on the normal solid solution lattice. Also known as artificial crystal; artificially layered structure; superstructure. (from Answers.com)
semiconductor structure comprising of several ultra-thin layers (atomic layers) engineered to obtain specific electronic and photonic properties; slight modifications of chemical composition of each layer result in slight variations of energy bandgap from layer to layer: bandgap engineering; fabrication of superlattices requires high-precision heteroepitaxial deposition methods such as MBE and MOCVD; typically involves III-V semiconductors. ( http://semiconductorglossary.com/default.asp?searchterm=superlattice )
Generally, a superlattice denotes a structure (material) with periodically interchanging solid layers. Such structures possesses additional periodicity on a scale larger than atomic. (from Wikipedia)
The Wikipedia definition is reasonable.
Lattice - regular structural array (ordered structure) of atoms in a crystalline solid.
Sublattice - refers to the lattice/array of atoms of a particular element in a compound or alloy. For example, the U or O sublattices in UO2. Ostensibly, it could refer to secondary phases (e.g. intermetallic compounds) in a primary phase (crystal structure).
From the ASM's Metals Handbook Desk Edition - "A space lattice can be viewed as a three-dimensional network of straight lines. The intersections of the lines (called lattice points) represent locations in space for the same kind of atom or group of atoms of identical composition, arrangement, and orientation."
Also from ASM's Handbook - "A crystal is a solid consisting of atoms or molecules arranged in a pattern that is repetitive in three dimensions. The arrangement of the atoms or molecules in the interior of a crystal is called its crystal structure. The unit cell of a crystal is the smallest pattern of arrangement that can be contained in a parallelepiped, the edges of which form the a, b, and c axes of the crystal. The three-dimensional aggregation of unit cells in the crystal forms a space lattice, or Bravais lattice."
thank you very much!
1. What is a superlattice?
A superlattice is a periodic arrangement of two or more different materials on a nanoscale level. This creates a new material with unique properties that are different from the individual materials used.
2. What is a lattice?
A lattice is a regular, repeating arrangement of atoms or molecules in a crystal structure. It forms the basic building block of a crystal and determines its physical properties such as strength and electrical conductivity.
3. What is a sublattice?
A sublattice is a portion of a larger lattice structure that is made up of a specific type of atom or molecule. It is used to describe the arrangement of atoms or molecules within a crystal lattice and can help determine the overall symmetry of the crystal.
4. How are superlattices, lattices, and sublattices related?
A superlattice is made up of multiple sublattices, each with its own unique arrangement of atoms or molecules. The overall structure of a superlattice is determined by the arrangement of these sublattices within it. A lattice, on the other hand, is the basic building block of a crystal and can be made up of multiple sublattices.
5. What are the applications of superlattices, lattices, and sublattices?
Superlattices have a wide range of applications in electronics, optoelectronics, and energy harvesting. They can be used to create new materials with enhanced properties such as increased conductivity or improved light absorption. Lattices are important in the study of crystal structures and can help determine the physical and chemical properties of materials. Sublattices are useful for understanding the symmetry and arrangement of atoms within a crystal lattice, which can be applied in various fields such as materials science and mineralogy.
  • Linear and Abstract Algebra
  • Atomic and Condensed Matter
  • Nuclear Engineering
