Register to reply
Digitally Controlled Audio Splitter Switch
by preston8
Tags: audio, controlled, digitally, splitter, switch
Share this thread:
preston8
#1
Aug4-14, 08:12 PM
P: 16
Hello,
I'm needing to send an intercom signal from a lobby to one of eight different rooms. I am creating a touch-screen interface with a Raspberry Pi under the hood that acts as an intercom. The user needs to be able to select any room they wish to speak to (even all of them at the same time). The receiving end is a LE-D Airphone intercom substation:
Manual
http://www.aiphone.com/home/assets/U...DA%20Instr.pdf
I'm going to use the Raspberry Pi to accept and amplify a microphone signal before sending the signal out through the 3.5mm output port to a splitter of some sort.
Are there any devices I can make or buy that would do this?
Phys.Org News Partner Engineering news on Phys.org
Philips introduces BlueTouch, PulseRelief control for pain relief
3-D printing leads to another advance in make-it-yourself lab equipment
Nanoscience makes your wine better
cpscdave
#2
Aug5-14, 07:43 AM
P: 138
Could you use the GPIO pins on the Pi to send out your signals?
You could either to DtoA on the pi and then amplify the signals to the rooms or run the pins to an AtoD chip and then do the amplification.
Register to reply
Related Discussions
Combining two audio sources, digitally Electrical Engineering 14
Finding/Implementing a digitally-controlled high-voltage switch Electrical Engineering 4
Computer Controlled switch Electrical Engineering 24
Audio-controlled LEDs Electrical Engineering 6
Audio-controlled LED Electrical Engineering 7
