New Reply
Finding the average value given the graph of the derivative
Share Thread Thread Tools
Jan25-13, 04:20 PM   #1
1. The problem statement, all variables and given/known data
Since there is a graph and many things, I will post the link of my question.
http://ibhl1-bccalculus.wikispaces.c...rson+text).pdf
Please scroll down to the last page (page 16) and my question is 6c.
2. Relevant equations
g(x)=3+∫(2,x)f(t)dt
3. The attempt at a solution
Here is what I attempt to do: I try to take the integral of g(x) from 2 to 6 and then divide the solution by 4 to find the average value. However, I need to do a double integration on f(t), which I haven't learn yet. I think my approach is too complicated, so is there another way to do the problem? I also think the answer key provided in the link is wrong, can anybody tell me if it is?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Jan25-13, 04:56 PM   #2
Homework Helper 2012
Recognitions:
Homework Helper Homework Help
Quote by fireblasting View Post
g(x)=3+∫(2,x)f(t)dt
Yes, it's wrong. The smallest value of g in [2,6] is g(4)=3-pi/2. The given answer (5-pi)/4 is smaller than that. The average can't be smaller than the minimum of the function. As you say, they should be integrating g, looks like they are sort of integrating f and doing a bad job of it.
Jan25-13, 05:25 PM   #3
Quote by Dick View Post
Can you tell me how to integrate g, though, I have trouble with that.
Jan25-13, 05:51 PM   #4
Recognitions:
You can't just read it off the graph. You'd need to actually write down a formula for f(x) on each interval and integrate it. The circle part makes it hard. f(x) on [2,4] is given by -sqrt(1-(x-3)^2). You'd need to integrate that to get g(x) which takes a trig substitution that gives an answer involving arcsins and sqrts. The you need to integrate that to get the average. It looks pretty nasty to me. If it were just line segments it would be manageable. I don't think you would be expected to do this.
Jan25-13, 06:23 PM   #5
I did that before, but I can only integrate the first part because the second part is pretty complex for my level. I am wondering if there is another way to do this problem. I also seek help from another forum before and the helper tells me the following:
The mean of g(x) between x=2 and x=6 is = 3 + mean of f(x)
f(x) has negative value between 2 and 4 with area = (1/2).pi x 1^2
= pi/2
f(x) is positive between 4 and 6 and area (1/2) x 2 x 2 = 2
Total area between 2 and 6 = 2 - pi/2 = 0.4292
Mean of f(x) = 0.4292/4 = 0.1073
Mean of g(x) = 3 + 0.1073 = 3.1073 <------
Yet, I still don't think it is right. Can you please tell if what he did is right?
Jan25-13, 06:38 PM   #6
Recognitions:
= pi/2
Try it out on a simpler example. Let's skip the 3 part. Suppose f(x)=x for x in [0,1]. The average of f(x) in [0,1] is 1/2. g(x)=x^2/2. Check that the average of g(x) is 1/6. Not equal to the average of f(x).
Jan25-13, 08:54 PM   #7
I just have this thought right now. Is it right if I add all the values from g(2) to g(6) and then divide it by 5 to find the average value?
Jan25-13, 10:54 PM   #8
Recognitions:
They goofed up. They know less about the correct way to solve the problem than you do. You were right, you need to integrate twice. I don't see any easy way to solve this problem. You can approximate the answer by finding some points on g(x) and averaging them. The more points you average the better the approximation, but that still not the real answer. I would move on.
Jan26-13, 01:17 PM   #9
I managed to do the double integral yesterday and got (56-3pi)/24, which is about 1.94, as the final average. Thank you for all your help.
Jan26-13, 02:50 PM   #10
Recognitions:
Hmm. I got 10/3-3pi/8. About 2.16. But I had to correct a few mistakes while I was doing it. Could still be a few left.
New Reply
Tags
average value, calculus ab
Thread Tools
Similar Threads for: Finding the average value given the graph of the derivative
Thread Forum Replies
finding average speed on a velocity vs time graph Introductory Physics Homework 6
Finding Where F is concave up/down using the graph of the first derivative Calculus & Beyond Homework 2
Stuck with finding function from graph of its derivative. Calculus & Beyond Homework 4
Finding average velocity from a velocity-time graph Introductory Physics Homework 1
Finding average acceleration from data points of a velocity time graph? Introductory Physics Homework 2
