dE_logics
- 742
I developed a propulsion system...a propulsion system which has no interactions from the environment...i.e the force in completely internal.
The principle that I used was that when you propel a mass (suppose a ball) on a heavy body and make it hit the heavy body, the impulse that was given to the ball will be transferred to the heavy body. Though the momentum from the ball will be completely transfered, since the body is very heavy, the momentum will be more by virtue of mass...since K.E has an exponential square relationship with velocity, we can say that despite all the momentum getting transferred to the heavy body, most of the energy is still left...this is seen in the form of a recoil on the ball.
Diagrammaticality -
O--------------------------------------------------------------------------------------------------------->|
Ball Propelled and made to collide the heavy body it rests on Wall
Since the the ball is very much lighter than the body, and it possesses the momentum by virtue of velocity, the K.E in it will be much higher...and so we can say that most of the energy will go to the recoil of the ball.
<----------------------------------O |
Ball recoils after hitting the wall
So now...after the collision, since the ball in moving in the opposite direction as before, and if we slowly make it retard (de-accelerate) on the body itself (for e.g using magnets attached on the body and making the ball out of iron), this time, all the K.E that the ball possesses will be given to the body...that means, a much higher velocity attained in the opposite (or desired) direction...and finally for the first time a propulsion without interaction from the surroundings.
Magnet to stop the ball before it collides.
___
<-------------------|___|-----------------------------O
Ball moving in this direction on the heavy bodyIn fact, since the ball is made to propel INSIDE the body, it will initially attain a velocity in the opposite direction, this will also aid the motion in the desired direction (although after collision, the body will again flip velocity).
BUT this is not working ...I mean, I tried it. So the laws are wrong...it's clear. It should have been successful.
Though the conditions were not ideal...I mean, I was using friction to stop the ball (on the body)...but it should have worked!...I was using a ball of a few grams on a ~8KG body on water!
And was throwing the ball by hand.
Diagrammaticality -
___
