- #36
rcgldr
- 8,855
- 632
If there is a rope in involved then you have interaction with an external object, the point of appllication of force is upon the rope, and with constant power the rate of force will decrease with speed with respect to the rope according to the equation power = force x speed. This changes the situation from the rocket and its spent fuel, which is a closed internal interaction that increases kinetic energy of both rocket and fuel, but does not change the center of mass or the total momentum of the rocket and fuel system.Bob_for_short said:If an engine pulls the probe mass with a rope, then there is no exhaust. I am speaking of a general case.
In the rocket case, the point of application is between the engine and the remaining on-board fuel. Regardless of the speed of the rocket and onboard fuel relative to some frame of reference, the engine and onboard fuel always have zero relative speed. For a given engine at a specific throttle setting the mass flow, thrust, power, and terminal velocity of the spent fuel relative to the rocket is constant, and the kinetic energy of the total system of rocket and spent fuel increases linearly with respect to time, regardless of the frame of reference.
