Is Mass Transport the Same as Forced Convection in Thermal Engineering?
  • Thread starter svishal03
  • Tags
    Thermal
In summary, convection and mass transfer are two different concepts in heat transfer. Convection refers to heat transfer at the boundary between a solid and a fluid, while mass transfer involves the transport of internal energy caused by the motion of the fluid. While both involve the movement of atoms and molecules, mass transfer is related to the global motion of the fluid while convection is related to the local motion of individual atoms and molecules.
svishal03
129
Hi All,
I'm looking at the fundamental aspects of heat transfer - as I'm not a mechanical/thermal engineer but soon to undergo a project wherein I need to deal with some aspects of thermal engioneering.
In the text, which I've been reading (for finite element analysis), it talks of mass transport wherein the medium of interest is a flowing fluid.
In such a case, heat flows by conduction, convection, and via motion of the
media. The last effect, referred to as mass transport.
My question is 'mass transport' same as forced convection? I guess it is because in forced convection aslo the fluid is in motion and so is in mass transport.
Can anyone throw some light please??
Vishal
Science news on Phys.org
No, they are two different things.
In most thermal models, the motion of any fluids is assumed to be known, not calculated as part of the model.
So convection usually refers to heat transfer at the boundary between a solid and a fluid. This is often modeled by Newton's law of cooling, using a heat transfer coefficient that is an empirical function of the fluid flow (where the function has been validated by experiment). The formula for the HTC usually depends on several dimensionless fluid dynamics parameters including Reynolds number, and the depedence on Re accounts for the effect of the fluid velocity on the rate of heat transfer.
Mass transfer is the transport of internal energy (i.e. temperature) caused by the motion of the fluid (e.g. flow through a pipe in a heat exchanger) and does not involve any other "flow" of heat energy such as conduction or convection. Of course in a "real life" situation, conduction, convection and mass transfer often all occur simultaneously.
Modelling the actual convective flow pattern of the fluid caused by the heat transfer (e.g. the way convection currents might develop in a pan full of water if you heat it on a stove) is much more complicated, and irequires solving some form of the Navier Stokes equations, not just the usual heat transfer (or diffusion) equation. That type of model is ot usually classified as a heat transfer problem, even through heat transfer forms part of it. Because of the existence of turbulence, often there isn't reallly a unique solution to that type of problem, and more assumptions need to be made to get a useful solution that "averages out" the turbulence in some way.
Does it mean that convection refers to a body sorrounded by a STATIONARY fluid whilst mass transfer deals with a moving fluid?
Vishal
Mass transfer only deals with moving fluids, by definition.
Convection can refer to fluids that are moving or at rest.
Mass transfer is only relevant when the finite element model contains some elements that represent the fluid explicitly. Often, the only thing in a thermal model that represents "convection" is the boundary conditions between a solid and a fluid (Newton's law of cooling).
Thanks a lot, but what is the difference between convection and mass transfer conceptually?
Because, convectionn occurs wherein there is movement of the atoms and molecules in a liquid (whereas conduction in solid is due to the vibration of attoms and moelecules and movement of electrons).
So, in both convection and moving fluid we have movement of atoms and m,olecules.Then how is convection different from mass transfer in this aspect (of movement of atoms and molecules).
Vishal
You can split the motion of the atoms and molecules into two components.
1. Mass transfer is related to the "global" motion of the fluid. For example if fluid is being pumped through a pipe, the flow velocity and the mass flow rate along the pipe does not depend on the fluid temperature, but only on the pump.
2. Convection is related to the "local" motion of individual atoms and molecules in the fluid, where according to the kinetic theory of heat, the temperature is a measure of the internal kinetic energy of the atoms or molecules in the fluid.
What is thermal analysis and why is it important?
Thermal analysis is a set of techniques used to study the physical and chemical properties of materials as a function of temperature. It is important because it provides valuable information about the behavior of materials under different temperature conditions, which is crucial in various fields such as materials science, chemistry, and engineering.
What are the different types of thermal analysis techniques?
The most commonly used thermal analysis techniques are differential scanning calorimetry (DSC), thermal gravimetric analysis (TGA), thermogravimetric analysis (TGA), and thermal mechanical analysis (TMA). Each technique has its own advantages and is suitable for different types of materials and temperature ranges.
What is the principle behind thermal analysis?
The principle of thermal analysis is based on the fact that material properties, such as heat capacity, thermal conductivity, and thermal expansion, are affected by changes in temperature. By measuring these properties as a function of temperature, we can gain insights into the behavior of materials and their thermal stability.
What are the applications of thermal analysis?
Thermal analysis has a wide range of applications in various industries, including pharmaceuticals, polymers, ceramics, and metals. It is used to study the thermal stability of materials, determine phase transitions, and analyze the effects of temperature on chemical reactions and physical properties.
What are the factors that can affect the accuracy of thermal analysis results?
The accuracy of thermal analysis results can be affected by factors such as sample preparation, instrument calibration, and environmental conditions (e.g. humidity). It is important to carefully control these factors to ensure reliable and accurate results.
  • Thermodynamics
12K
  • Thermodynamics
