Calculating Distance Between Double Slits Using the Double-Slit Equation
In summary: When a beam of light passes through a single slit it diffracts into a pattern on a screen located 8.0 m away. Determine the width of the central bright fringe.2. ΔX/L=sinθ= (ΔX-0.5)*λ/(d*Sinθ), where λ is the wavelength of the light, d is the distance between the slits, and Sinθ is the angle between the central maximum and the secondary maximum.ΔX/L=sinθ= [(ΔX-0.5)*λ/(d*Sinθ)]
  • #36
Hello..??
  • #37
ok so I used 2n+1 and got 0.60m, then i use (2n-1), and whteve value i get, i add 0.60 to it?
  • #38
single slit diffraction
pinkyjoshi65 said:
Oh..ok..thankz..:)..One more question..Light of wavelength 600 nm is incident upon a single slit with width 4.0 × 10-4 m. The figure shows the pattern observed on a screen positioned 2.0 m from the slits.Determine the distance s. see attached pic..
So here we have the wavelenght, w and L. Now since both the bright and the dark fringe is invloved do we have to cobine their equations??
like: (m+0.5)wave/w= X/L...Dont know how to proceed with this problem..
You just need to apply the condition for single slit diffraction. There's a simple formula to find the location of any dark fringe from the central maximum:
[tex]y = \frac{m\lambda D}{w}[/tex]
where D is the distance to the screen and w is the width of the slit.
  • #39
um..ok..and how did you derive this equation? Also could you also go through the solutions in posts 21 and 26..
  • #40
  • #41
Ok, thnkz for your help..really appreciate it. It would be nice if I could an answer by tomorrow..thnkz again..:)
  • #42
Hi, sorry got a question about the equation you gave me. Since we are supposed to find the distance between the centre of the max fringe to the DARK fringe, (m=2), so arent we supposed to use this equation:
(m+0.5)wavelength= wX/L, and find X?
  • #43
Don't confuse that equation (which is for the double slit pattern) with the formula that I gave you for single slit diffraction. The formulas are different.
  • #44
umm..but that equation is for single slit equations (constructive) The ones for the double slit equations are (n-0.5)wave= dX/L (destuctive)..
  • #45
I guess you could use it for that, but it's a bit bogus. There's no simple equation for finding the bright spots of a single slit pattern. There's an equation for finding the dark spots, which is the one I gave. You can estimate the positions of the bright spots by saying they are in the middle between two dark spots.
Note that you're being asked to find the position of a dark fringe, which is destructive interference.
  • #46
However in the image I have attached, it seems like they are asking us to find the distance from the centre to the CENTRE of the 2nd dark fringe..How can I use X=m*wave*L/w to find the distance till the CENTRE od the dark fringe?
  • #47
I'm not sure what else I can tell you: I gave you the formula to use; I gave you a link that discusses how the formula is derived; I told you why the other formula that you wanted to use is incorrect.
Don't get distracted by talk of the center of the fringe--whether it's a dark or a bright fringe, those simple formulas always give the position of the center of the fringe. (Don't confuse this with the position of the central maximum, which is at the center of every fringe pattern.)
  • #48
umm..ok..so i'll use X=m*wavelength*L/w..Thankz a lot..Will be waiting for your reply on the other posts.
  • #49
Sorry one more question, m is equal to 2 yes?
  • #50
um..
  • #51
Yes. In the formula for the single slit, the 2nd dark fringe corresponds to m = 2.
  • #52
double slit problems
pinkyjoshi65 said:
And here are solutions to some of the questions. Could you please just check my solutions.
1)Calculate the angle that will form between the centre maximum and the third-order dark fringe if the wavelength of the light that strikes two slits is 650 nm and the distance between the slits is 2.2 10-6 m.
1. n=3, λ=6.5* m, d=2.2* m
(n-0.5)λ= d*Sinθ
Sinθ= (n-0.5)*λ/d
= (3-0.5)6.5* /2.2*
= 2.5*6.5* /2.2
= 7.3863*0.1= 0.73863
Sinθ= 0.73863
θ= (0.73863)= 47.61 degrees
Careful: λ=650 nm (not 6.5 m); d = 2.2 10^-6 m (not 2.2 m).
Answer is correct.
2)In an experiment, blue light with a wavelength of 645 nm is shone through a double-slit and lands on a screen that is located 1.35 m from the slits. If the distance from the centre maximum to the 8th order bright fringe is 2.6 cm, calculate the distance between the two slits.
2. m=8, λ=6.45* m, L =1.35m, X=0.026m
X/L=mλ/d
d=Lmλ/X
d= 1.35*6.45* *8/0.026
=2.68* m
Correct formula, but the wavelength is 645 nm, not 6.45 m.
Answer is off by several factors of 10.
3)In an experiment, the distance from one slit to the third dark fringe is found to be 2.200 046 8 m. If the wavelength of the light being shone through the two slits is 590 nm, calculate the distance from the second slit to this same dark fringe.
3. n=3, PS1= 2.2000468m,λ=5.9* m
(n-0.5)λ=lPS1-PS2l
+/- (3-0.5)5.9* = 2.2000468-PS2
+/- 14.75* = 2.2000468-PS2
PS2= 2.2000468-14.75* OR 2.2000468+14.75*
PS2= 2.200045325m or 2.200048275m
I can't follow what you're doing here. What must be the difference in path length from slit to screen for the light from each slit to produce a dark fringe?
4)Two slits are separated by a distance of 2.00 10-5 m. They are illuminated by light of wavelength 5.60 10-7 m. If the distance from the slits to the screen is 6.00 m, what is the separation between the central bright fringe and the third dark fringe?
4. X/L= (2n+1)λ/2d
X= (2n+1)λL/2d= 42*5.60*10-6/4*10-5
= 58.8*10-2= 0.60m
Your formula is incorrect; compare with the correct formula that you used for problem 1. (You found the position of the 4th dark fringe, not the 3rd.)
  • #53
single slit problems
pinkyjoshi65 said:
Light of wavelength 625 nm shines through a single slit of width 0.32 mm and forms a diffraction pattern on a flat screen located 8.0 m away. Determine the distance between the middle of the central bright fringe and the first dark fringe
λ=6.25*〖10〗^(-7)m, w=0.32*〖10〗^(-3)m, L=8.0m
λ/w=X/L
X=Lλ/w= 8*6.25*〖10〗^(-7)/0.32*〖10〗^(-3)
= 156.25*10000
1.56*〖10〗^6m
Correct formula, but redo the arithmetic. (Keep track of those exponents.)
Light of 600.0 nm is incident on a single slit of width 6.5 mm. The resulting diffraction pattern is observed on a nearby screen and has a central maximum of width 3.5 m. What is the distance between the screen and the slit?
λ=6.00*〖10〗^(-7)m, w=6.5*〖10〗^(-3)m, 2X=3.5;X=1.75m
λ=wX/L
L=wX/λ= 6.5*1.75*〖10〗^(-3)/6*〖10〗^(-7)= 11.375*〖10〗^4/6 =2.00*〖10〗^4m
For some reason, you rounded off your answer. Your answer is OK given the data quoted, but I suspect that the central maximum width is not 3.5 m (more like 3.5 mm).
A monochromatic beam of microwaves with a wavelength of 0.052 m is directed at a rectangular opening of width 0.35 m. The resulting diffraction pattern is measured along a wall 8.0 m from the opening. What is the distance between the first- and second-order dark fringes?
. λ=0.052m, w=0.35m, L=8m
λ/w=X/L
X= Lλ/w= 8*0.052/0.35
= 1.18 m
OK.
Light from a red laser passes through a single slit to form a diffraction pattern. If the width of the slit is increased by a factor of two, what happens to the width of the central maximum?
λ1=wy1/L, y1= Lλ/w
λ2=2wy/L, y2= Lλ/2w
y2/y1= λ2L*w/2w*Lλ1
y2/y1= 0.5
y2=0.5y1
Good. The width of the central maximum decreases by a factor of two.
  • #54
umm..ok so for Q2 above, the asnwer is 2.67*10^-4 m. For question3 I used the formula (n-0.5)=wavelength= lPS1-PS2l (absolute value), where PS1 is the distance of the 1st slit to the fringe and PS2 is the distance of the 2nd slit to the same fringe. For Q4, this was the formula that rhbhat had given me. I will use (n-0.5)wave= dX/L for this question
  • #55
Good.
Now I see. Good.
Good. That's the one you need.
  • #56
Thankz a lot Doc Al! Really really appreciate it..:)
