kai_sikorski
I have a PDE that can be interpreted as basically an exit time problem for a certain stochastic process. I would like to use this to verify an analytical solution I've found. If I start the stochastic process at (x,y), then the average exit time from a certain region will be equal to the value of the solution of the PDE I care about at (x,y).
I could divide up my region into a discrete set of points and find the average for each of those. However that wastes some of the data because, say I start the process at x0, y0. During the next time step the position is x1, y1, and so if the total exit time is T then not only do I have the data point
x0, y0, T
but also
x1, y1, T - dt
However x1, y1 is probably not exactly one of any predefined start points I defined.
So what I would like to do is take the whole list of data
{ { x0, y0, T}, {x1, y1, T-dt}, {x2, y2, T- 2 dt}, ... }
And apply a moving average filter. Is there a built in method for doing this in Matlab or Mathematica? I can find documentation for things like the filter2 command in Matlab, this seems to apply more to a case where your data is indexed by a discrete sets of points so that you can arrange it in for example a matrix. That's not the case here where the data is basically indexed by floats.
x0, y0, T
but also
x1, y1, T - dt
