| New Reply |
Significant Figures |
Share Thread | Thread Tools |
| Nov22-12, 11:34 PM | #1 |
Significant Figures
Why are zeroes following a non-zero number in the decimal area considered significant?
2.34000 <-- Like this, why are the three zeroes after the four considered significant? |
| Nov23-12, 12:07 AM | #2 |
Significant figures are usually needed for lab measurements.
Suppose you have a weight balance that can measure grams to 5 decimal places. The amount of decimals that your weight balance can accurately measure are all considered significant. So if you had 2.34001g, that would be significant. But since your weight balance can measure that accurately, if the balance says 2.34000g, then all of those digits are significant because your balance can measure it. |
| Nov23-12, 08:08 AM | #3 |
The final "0"s do not add anything to saying what the value of the number is- mathematically, 2.34= 2.340= 2.3400= 2.34000. So the only purpose the "0"s can have is to tell us the accuracy- they are "significant figures".
| Nov23-12, 08:19 PM | #4 |
Significant Figures
What do you mean tell us the accuracy? Isn't 2.34 already accurate enough?
If I'm getting this right. The extra zeroes just tells me the capabilities of the instrument. |
| Nov23-12, 09:02 PM | #5 |
Recognitions:
| Nov23-12, 10:20 PM | #6 |
I still don't get it.
| Nov23-12, 10:55 PM | #7 |
Recognitions:
A guy who reports a measurement of 2.3100 does not leave that possibility open. |
| Nov24-12, 12:43 AM | #8 |
Recognitions:
Here's another example.
A person steps on a scale and it shows he weighs 154 pounds. He does NOT know if he really weighs 153.98 pounds, or 153.610 pounds, or 154.2 pounds, or 154.1 pounds, or 154.43 pounds or 154.0009 pounds. This scale only reads to the nearest whole pound. The scale or dial does not indicate to the nearest fraction of a pound; the dial or scale cannot be reliably read between whole pound values and no markings are shown between whole pound values. This scale gives reading, if over 99 pound value, to THREE SIGNIFICANT FIGURES. |
| Nov24-12, 12:52 AM | #9 |
Well, it depends on what you are doing. 2.34 might be accurate enough. Then again, maybe not. Maybe you need 2.34000. 2.34001 would be too much and 2.33999 too little. |
| Nov24-12, 03:34 AM | #10 |
Admin
I think you are just confused by the fact these digits are zeros.
You feel like 2.34 and 2.3400 mean the same... OK, now is there a difference between 1.06 and 1.0614? Sure there is. Trick is, it is exactly the same thing. 2.34 (2.3400) is a weight in pounds, 1.06 (1.0614) is a weight of the same object given in kg. It is just obvious 14 means something. |
| Nov24-12, 04:07 AM | #11 |
Recognitions:
If we have 2.34 and add to it 0.0001, then we still have 2.34. Does that also help? |
| Nov24-12, 03:36 PM | #12 |
Second guy, I read in a book that the zeroes are significant. But what I keep getting is that the extra zeroes after the decimal are significant to show that those digits are indeed zero, not some other number; it removes the possibility of a different number. If that is true, then there can be an infinite number of significant numbers that are zero? |
| Nov24-12, 04:58 PM | #13 |
| New Reply |
| Thread Tools | |
Similar Threads for: Significant Figures
| Thread | Forum | Replies | ||
| Significant Figures | Introductory Physics Homework | 1 | ||
| significant figures | Introductory Physics Homework | 4 | ||
| Significant figures in 0 | General Physics | 21 | ||
| Significant figures | Introductory Physics Homework | 4 | ||
