Magnetic field of charge moving at constant velocity
In summary, the magnetic field of a single charge moving at a constant velocity can be described by using both the current and displacement current terms in Maxwell's equations. This is a problem that would have interested Maxwell, but there is no reference to it in his biography.
Shaw1950
Can anyone show me how to calculate the magnetic field of a single charge moving at a constant velocity - including both the current and displacement current terms?
Also, what is the significance if any of this result to Galilean vs Lorentz transformations? It seems like a problem that would have interested Maxwell and yet I cannot find any reference to it in his biographies.
Your idea of using Lorentz transformations is correct (using Galileo transformations is wrong of course).
The solution of the problem of a point charge at rest is of course the electric Coulomb field and vanishing magnetic field. Then you go to a reference frame, where the charge moves with a given velocity, by using a Lorentz boost, and you obtain the electromagnetic field. To that end you arrange the electric and vanishing magnetic field into the antisymmetric 2nd-rank field-strength tensor, which has well defined transformation properties or you introduce the four potential which transforms as a four vector (modulo gauge transformations).
The same holds for the four-dimensional current, which transforms as a four vector.
Thanks for your answer, but I hadn't asked my question clearly enough. What I wanted to know is what's the solution in a non-relativistic framework. In particular, is there a net magnetic field, or does the current "charge x speed" get canceled by the displacement current leaving zero field. It's of interest because in Maxwell's day this type of problem was known and I'm interested to know whether it would have produced "anomolous" results in the sense of a magnetic field appearing when speed goes from zero to constant.
The question is, what you mean by "non-relativistic framework". Maxwellian electromagnetics is a relativistic theory, and thus you have to modify it to make it consistent with Galilei invariance.
Such questions are addressed, e.g., here:
Le Bellac M and Levy-Leblond J M 1973 Galilean electromagnetism Nuov. Cim. B 14 217-233.
DOI:10.1007/BF02895715
By "non-relativistic" I mean the equations that Maxwell originally formulated rather than the re-formulation on a relativistic basis.
Getting back to my original question, which I'd love someone to answer, what is the magnetic field of a single charge moving at a constant velocity? It clearly has an electrostatic field E but does it or doesn't it have a field B?
To clarify this, there seem to be 3 distinct situations that are widely studied:
1) currents in wires - zero net charge, no electrostic field - Biot-Savart only
2) particle beam - net charge, field is static so no displacement - Biot-Savart only
3) moving charge - net charge, dynamic field, displacement current - so what's the solution?
A Google search on "magnetic field of a moving charge" leads to this as the first hit:
http://academic.mu.edu/phys/matthysd/web004/l0220.htm
Searching instead for "magnetic field of a moving point charge" leads to this as the first hit:
http://maxwell.ucdavis.edu/~electro/magnetic_field/pointcharge.html
These are for v << c (the non-relativistic limit). You can find the exact version, good for all v < c, at
http://farside.ph.utexas.edu/teaching/em/lectures/node125.html (equations 1538 and 1539)
Maxwell's equations as originally formulated are relativistic. Try doing a http://faculty.uml.edu/cbaird/95.658%282011%29/Lecture10.pdf" and it doesn't work.
Moving charges create magnetic fields, even if you have a single charge. If the charge is moving at a constant velocity, you will have a static magnetic field similar to that created by a very small length of wire carrying a current: the magnetic field will curl radially around the path the electron takes and the magnetic field strength will be proportional to the inverse square of the distance between the observation point and the charge.
For item (3), if the charge is moving with a constant velocity (or very close to constant) it will create an electrostatic field according to Coulomb's law and a magnetostatic field according the Bio-Savart law the two fields will be independent.
If the charge is has a non-constant velocity (is accelerated), then the electric and magnetic fields are non longer static, but change in time and couple to each other. You need all 4 Maxwell equations to describe this. The most intuitive approach is to reduce Maxwell's equations down to inhomogenous wave equations, which basically tells you that accelerating charges emit (and absorb) electromagnetic waves.
It does.
They are called the Lienard Wiechert potentials:
http://en.wikipedia.org/wiki/Liénard–Wiechert_potential
Also, vanhees71 and chrisbaird are correct, the Lienard Wiechert potentials come right from Maxwells equations and are fully relativistic. They work for any speed.
On Lorentz invariance I stand corrected, thanks all of you for putting me right.
Thank you also for drawing my attention to Lienard Wiechert which is very helpful for following through the calculation.
Can anyone give a simple explanation of why for the steadily moving particle, whose electric displacement is dynamic and therefore generating a displacement current (DP), nevertheless the contribution of the DP to the magnetic field B is zero, and the field B is entirely the Biot Savart field. Or is this answer simply a low-velocity approximation?
It is not a low velocity approximation.
I don't understand your displacement current comment. Why would you think it is zero?
Another way of asking the question is why, for a moving point charge, is the Lienard Wiechert solution to the two vector equations :
 x B = J + dE/dt and  x E = -dB/dt =>
=> B = Q VxR/4πrrr (rrr=r cubed as symbols are unavailable, please excuse the poor symbols, the best I could do)
the same result as the Biot Savart solution to Ampere's law on its own:
 x B = J =>
=> B = Q VxR/4πrrr
Is there an insightful explanation of this, or is it simply a coincidence?
The Biot-Savart law for a point charge at constant velocity must be the same as the Lienard Wiechert solution for a point charge at constant velocity. They are both derived from the same equations (Maxwell's equations) for the same boundary conditions.
Surely there is some significance that when you solve just Ampere's law with the point charge (and so just one equation  x B = J) you get the same answer as when you solve the full maxwell's equations (ie two vector equations  x B = J + dE/dt and  x E = -dB/dt). Why is the older formulation that pre-dates Maxwell (Biot-Savart was derived in 1820 on the basis of Ampere's simpler formulation) giving the same answer as Maxwell? After all the equations are different!
What strikes me as odd about the moving charge case is that in the Ampere's circuital equation there is no reference to an electric field and the magnetic field depends only on the charge-current.
Yet in the Maxwell formulation the Electric Field explicitly enters the equations, it is clearly changing so dE/dt is non-zero and yet the Electric Field does not effect the solution in any way; then also the Magnetic Field is changing too and so gives rise to curl x E. So in some sense the changing Electric Field coupled with the changing Magnetic Field ends up leaving the solution the same as if there had been no Electric Field, and I'm curious why this is.
If the equations are different then the answer is not the same. Perhaps you are thinking of the low-velocity approximation to Biot-Savart:
http://en.wikipedia.org/wiki/Biot–Savart_law#Point_charge_at_constant_velocity
which is not at all the same as the Lienard Wiechert potential:
http://en.wikipedia.org/wiki/Liénar...onding_values_of_electric_and_magnetic_fields
If you use the same equations you get the same answer. If you use different equations then you get different answers. You seem to be saying that you think you use different equations but get the same answer.
Ampere's law is:
[tex]B*2 \pi R=\frac{1}{c^2}\frac{d}{dt} \int \frac{q}{4 \pi \epsilon_0 r^2} \hat{e_r}\cdot d\vec{A} [/tex]
where if you imagine the charge moving along a line, and r is the point you want to calculate the field, then R is the perpendicular distance from r to the line. The surface of integration is a disc of radius R whose center goes through the line. Just to set it up a little bit more:
[tex]B*2 \pi R=\frac{1}{c^2}\frac{d}{dt} \int \frac{q}{4 \pi \epsilon_0 (L^2+x^2)} \frac{L}{\sqrt{L^2+x^2}} [2\pi x dx] [/tex]
where L is the distance to the point on the field you want to calculate along the line, the factor in [...] is the measure, and the factor next to that is the cosine the angle the field makes with the surface. The integral over x goes from 0 to R.
I just did this calculation with the help of an online integrator and differentiator (because I'm lazy), and you get the Biot-Savart magnetic field.
edit: just to be more clear, L=L(t), so when you take the timed derivative of L, you get the velocity v.
I agree. Now if you solve the multiple equations of Maxwell, you will also get Biot Savart. So two different sets of equations give you the same answer.
What I'm asking is not about solving equations (for the result could be a coincidence) but what is the deeper insight into why the two approaches give the same result. They don't for oscillating charges. So what is the general insight?
I don't understand what you mean by different approaches to solve for the full Maxwell equations. If you mean the Biot-Savart Law from magneto statics, of course it's not applicable to the magnetic field of accelerated charges since it works only in the special case of magnetostatics, i.e., stationary currents.
In any case, you get the right answer by using the retarded Green's function (Lienard-Wiechert potentials for an arbitrarily moving point charge). In the case of a uniformly moving charge you get the fields also from Lorentz boosting the Coulomb field for the charge at rest. Of course, both solutions must be identical since Maxwell's electromagnetics is a relativistically covariant classical field theory.
This is not correct, as shown by the links posted above.
I'm not sure I know the answer at the level you want it. This is kind of like the example you see in textbooks of charging a capacitor. If you form a loop around one of the wires leading up to the capacitor, and calculate the line integral of the magnetic field, then you get an answer if you use the current flowing through the loop to help you calculate this integral. But you can also make your surface go between the plates, and instead of current you'd have a changing electric flux. Both give you the same answers. Coincidence? That might be too strong of a word. It's reassuring - we expected that it'd give the same answer (and it did), and it is delightful because you don't think it'll give the same answer because electric fields are different from currents. If you want to think about it deeper that's cool. One thing though: there is such a thing as a polarization current, given by the partial derivative of the polarization vector with respect to time. The polarization vector is proportional to the electric field, for linear materials. So the partial derivative of the electric field with respect to time is like a polarization current, except not in a dielectric, but in a vacuum or ether. So in a way you can view the displacement current as a true current. I think physics might even say that the vacuum is a legitimate medium, as it contains stuff like electron/positron pairs that pop in and out of existence. and they can screen stuff, just as a dielectric screens stuff.
Dale, thanks for all your feedback, much appreciated. An issue remains for the low speed approximation. At low speeds there are still electrodynamic and magnetodynamic terms dE/dt and dB/dt in Maxwell and yet the solution is a magnetostatic. So why is the low speed solution magnetostatic? (1) are these dynamic terms simply both small at low speeds, or (2) do the effects of dE/dt and dB/dt cancel (and if they cancel, is there some insight about that)?
RedX, in terms of deeper insight, my suspicion is that the equations can be separated, perhaps Helmholtz decomposition, into parts that behave in different ways, and such a decomposition will explain the result. But I haven't figured out what that decomposition is yet.
It is (1). They are small at low speeds so you neglect them.
How would you think this specific result was viewed by Maxwell and his peers, if it was known? It surely would have seemed odd that in moving from a static particle to a frame at constant speed, a magnetic field mysteriously appeared yet the electric field was essentially the same. Did this get commented on?
Of course everyone believed in the Ether and absolute frames but I'm surprised that nobody noticed or commented on this odd effect. If they had and had investigated, maybe they would have scooped Einstein by 50 years!
Why? This kind of thing happens pretty often. For example, if you expand sin(x) and cos(x) to first order about x=0 then you get x and 1 respectively. The cos is "essentially the same" but the sin has "mysteriously appeared". I think you are trying to read more into this approximation than it warrants.
I'm not sure why you would need to decompose it. Assuming a Biot-Savart field, the flux through a circle whose center goes through the current carrying wire is zero, since the magnetic fields circle around the wire, so that they are always tangential to planes perpendicular to the direction of the current, hence no flux through such planes. From this you can show that a Biot-Savart field never creates an electric field that has a curl.
That is, [itex]\int E \cdot d\vec{l}=-\frac{d \Phi}{dt}=0 [/itex] since phi is zero.
Sorry to be a bore about this point, but can anybody demonstrate that? I’ve seen it done for currents in conductors but it never satisfies me.
(If needed, use an online calculator to get the maths out of the way that’s more than fine by me.)
Just some of my thoughts: I can see that you will be able to derive the relativistic equation for the electric field of a point charge, which is useful for high speed particles but I’m not sure about deriving its magnetic field and especially not its relativistic magnetic field. This last one always seems a “double up” effect to me since a magnetic field is in the first place understood as a result of relativity wrt moving charges.
This might have been given earlier in this thread, but the fields (from several textbooks) are given by
[tex]{\bf E}= \frac{q{\bf r}}
{\gamma^2[{\bf r}^2-({\bf v\times r})^2]^{\frac{3}{2}}}[/tex]
and
[tex]{\bf B}={\bf v\times E}
=\frac{q{\bf v\times r}}
And exactly what are you doing here?
Copy & paste, how clever!
Why couldn’t I think of that?
  • #31
See here:
(two methods, take your choice)
  • #32
Jtbell that paper your referring to doesn’t look like “ a Lorentz boosted coulomb field” to me. It looks a lot more complicated including a lot of maths and Greek. Oh well, someday someone will come up with something a bit more consumer friendly.
  • #33
I find the manuscript by Fitzpatrick excellent. It's also awailable as a textbook. I can only recommend to read his chapter on the fully relativistic treatment of electromagnetics. I never understood, why there is no textbook on classical electromagnetism that from the very beginning strictly uses the relativistic framework. Instead all authors copy more or less the classical textbooks of the first half of the 20th century (although there are excellent books among them, first of all Sommerfeld's Lectures on Theoretical Physics and Becker's book). The only exception is Landau-Lifgarbages in his vol. II, but in vol. VIII he treats the constitutive equations non-relativistic as usual. But that lamento becomes off-topic now...
  • #34
But that is exactly what it is.
  • #35
Thank you all for the comments and feedback it was most helpful and has spurred me on to do some of the maths for myself. One of my difficulties is that many textbooks "fudge" the solution by ignoring the fact that a point charge is essentially a delta distribution and they skip essential steps in the calculation. However, you all encouraged me to make the effort, after 40 years of abstinence. Thanks!
What is a magnetic field of a charge moving at constant velocity?
A magnetic field is a region in space where a magnetic force is exerted on charged particles. When a charged particle, such as an electron, moves at a constant velocity, it creates a magnetic field around it.
How is the direction of the magnetic field determined?
The direction of the magnetic field is determined by the direction of the velocity of the charged particle. The field lines of the magnetic field form circles around the path of the particle, with the direction of the field given by the right-hand rule.
What is the relationship between the strength of the magnetic field and the velocity of the charged particle?
The strength of the magnetic field is directly proportional to the velocity of the charged particle. This means that as the velocity increases, the strength of the magnetic field also increases.
Can a magnetic field be created without a charged particle moving at constant velocity?
Yes, a magnetic field can also be created by a current-carrying wire or a permanent magnet. In these cases, the magnetic field is created by the movement of electrons within the wire or the alignment of the magnetic domains in the magnet.
What are some practical applications of the magnetic field of a charge moving at constant velocity?
The magnetic field of a charge moving at constant velocity is used in many everyday devices, such as electric motors, generators, and transformers. It is also used in medical imaging technologies, such as MRI machines. Additionally, the Earth's magnetic field, created by the movement of charged particles in the Earth's core, plays a crucial role in navigation and communication systems.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
11K
