Mathematica - automatically change function name in for loop
In summary, the conversation was about a person trying to call different functions in a loop to calculate something, and they were looking for a way to replace an arbitrary sign with a variable in order to call the functions N0, N1, etc. with different values for time. The solution involved using a loop and the ToExpression function to define 27 functions x[0] to x[26] with the desired values. Another person suggested using a table and map instead of a loop.
drmetal
Hi folks,
i just want to call different functions which are solutions of set of rate equations from s= NDSolve in a loop to calculate something.
For[k = 0, k < 27, k++,
x[k] = N#[time] /. s;
# is just an arbitrary sign. i just want to replace # with k so i call
N0[time]
N1[time]
...how do i do that ?
i use mathematica 7
thanks
Heiko
ToExpression[StringJoin["N", ToString[k]]][time] /. s
might work
Are you are trying to fill a table with 27 results. If so then perhaps something like this.
time=1;s=p->q;x=Table[0,{26}];
For[k=1,k<27,k++,
x[[k]]=ToExpression[StringJoin["N", ToString[k]]][time] /. s;
x
which gives
Out[6]={N1[1],N2[1],N3[1],N4[1],N5[1],N6[1],N7[1],N8[1],N9[1],N10[1],N11[1],N12[1],N13[1],N14[1],N15[1],N16[1],N17[1],N18[1],N19[1],N20[1],N21[1],N22[1],N23[1],N24[1],N25[1],N26[1]}
Are you are trying to define 27 "functions" x[0], x[1],...x[26] then something like this.
time=1;s=p->q;
For[k=0,k<27,k++,
x[k]=ToExpression[StringJoin["N",ToString[k]]][time]/.s;
?x
which gives
x[0] = N0[1],
x[1] = N1[1],
x[26] = N26[1]
Do you even need a loop? can't it be done with table and map?
thanks. that was exactly what i was looking for. it works
1. How can I change the name of a function automatically in a for loop in Mathematica?
In order to automatically change the name of a function in a for loop in Mathematica, you can use the ReplaceAll function. This allows you to specify a pattern to match and a replacement expression. For example, if you have a function named f[x] and you want to change the name to g[x] in a for loop, you can use f[x] /. f -> g within the loop.
2. Can I use a variable as the name of a function in a for loop in Mathematica?
Yes, in Mathematica, you can use a variable as the name of a function. This is known as a "symbolic function." To create a symbolic function, you can use the syntax function[x_]:= expression. This will create a function named function that takes in an argument x and evaluates the expression.
3. How do I change the name of a function in a for loop based on a condition in Mathematica?
To change the name of a function in a for loop based on a condition, you can use an If statement. For example, if you want to change the name of a function to g[x] if x is greater than 5, you can use If[x>5, f[x] /. f -> g, f[x]] within the for loop.
4. Is it possible to automatically create and name functions within a for loop in Mathematica?
Yes, it is possible to automatically create and name functions within a for loop in Mathematica. You can use the Do or Table functions to generate a list of functions with different names, and then use MapThread to apply a different expression to each function in the list.
5. Can I use a function as an argument to change the name of another function in a for loop in Mathematica?
Yes, you can use a function as an argument to change the name of another function in a for loop in Mathematica. This can be done by using the Map or MapIndexed functions. These functions allow you to apply a function to each element in a list, and you can specify the function to change the name of another function as the argument.
