Solving an Integral with 17sin^3(cos^5)d(theta) Using Trigonometric Substitution
  • Thread starter tangibleLime
  • Tags
    Integral
In summary, to solve the given problem of \int 17sin^3(\theta)cos^5(\theta)d\theta, you can pull out the constant and break up the sin^3. Then, use a trig identity to replace the sin^2 and a u-substitution to get rid of the other sin. From there, you can solve the integral and substitute back in for u to get the final answer of 17[\frac{cos^6\theta}{6}-\frac{cos^8\theta}{8}]. However, make sure to use the correct substitution (du = -sin(\theta)d\theta) to avoid errors.
tangibleLime
71
[tex]\int 17sin^3(\theta)cos^5(\theta)d\theta[/tex]
Pulling out constant, breaking up the sin^3.
[tex]17 \int sin^2(\theta)cos^5(\theta)sin(\theta)d\theta[/tex]
Using the trig identity to replace the sin^2
[tex]17 \int (1-cos^2(\theta))cos^5(\theta)sin(\theta)d\theta[/tex]
Using u-subs to get rid of the other sin.
[tex]u = cos(\theta), du = sin(\theta)d\theta[/tex]
[tex]17 \int (1-u^2)u^5 du[/tex]
[tex]17 \int u^5-u^7 du[/tex]
[tex]17[\frac{u^6}{6}-\frac{u^8}{8}][/tex]
Subbing back in for u.
[tex]17[\frac{cos^6\theta}{6}-\frac{cos^8\theta}{8}][/tex]
Homework software says incorrect. Any hints would be great!
du = -sinx not sinx :-)
Cripes, thanks. 0_0
np :-)
1. What is an extremely simple integral?
An extremely simple integral is a type of mathematical calculation that involves finding the area under a curve on a graph. It is considered "extremely simple" because it can be solved using basic algebra or by using a simple formula.
2. How do you solve an extremely simple integral?
To solve an extremely simple integral, you can use either the basic algebraic method or the formula method. In the algebraic method, you need to rearrange the equation to make it easier to integrate. In the formula method, you can use a known formula to solve the integral.
3. What is the purpose of solving an extremely simple integral?
The purpose of solving an extremely simple integral is to find the area under a curve on a graph. This can be useful in various fields such as physics, engineering, and economics, where finding the total value or quantity represented by a graph is important.
4. What are some common examples of extremely simple integrals?
Some common examples of extremely simple integrals include finding the area of a rectangle, triangle, or circle on a graph. Another example is calculating the displacement of an object given its velocity over time.
5. Are there any tips for solving extremely simple integrals?
Yes, there are a few tips that can help with solving extremely simple integrals. These include understanding the problem and choosing the appropriate method, being familiar with basic algebra and integration rules, and practicing solving different types of integrals to improve your skills.
