Who’s spin in the Einstein-Cartan theory? Source’s or test particle's?
In summary: See e.g. here:In summary, the spin in the Einstein-Cartan theory is the source's spin. The difference between the Einstein-Cartan theory and Gravitoelectromagnetism is that the spin in the Einstein-Cartan theory is always the source term for torsion.
mings6
Who’s “spin” is in the Einstein-Cartan theory? Source’s spin or the test particle’s spin?
I quantum mechanics, when we say spin orbit interaction, such as in hydrogen atom, it’s about the test particle's, the electron’s spin and the electron’s orbit interact to each other.
In the Einstein’s general relativity, with weak field condition, it can be described with Gravitoelectromagnetism, in which the source’s spin interacts with the test particles, that leads to the frame dragging and the Lense-Thirring effect.
Its said that “general relativity has one flaw that it cannot model spin-orbit coupling, so we need the Einstein-Cartan theory”. But who’s “spin” is here in the Einstein-Cartan theory? Source’s spin or the test particle’s spin?
From the relation,
(divergence of spin current) = P_{ab} – P_{ba} <> 0
it seems the spin is the source’s spin. Than what the difference between the Einstein-Cartan theory and Gravitoelectromagnetism? What happens if the test particle has spin?
I haven't seen any Einstein-Cartan equations for motion of spinning test particles; this would be something a "geodesic equation plus spin of the test particle".
In Einstein-Cartan theory the l.h.s. of the equations is always "geometry", the r.h.s. is "matter", just like ordinary GR. Therefore the spin current is always the source term for torsion.
In general the equation for matter would of course not be the equation for a test particle i.e. a "geodesic equation plus spin of the test particle", but a field equation for the matter field coupled to spacetime = curvature + torsion, for example the Dirac equation.
Thanks for reply. I still do not understand, if general relativity can not model spin-orbit coupling, then how can we have the Kerr metric that describes the geometry of spacetime around a rotating massive body? And also Gravitoelectromagnetism can do some jobs for frame dragging and the Lense-Thirring effect?
GR in standard metric formulation can describe orbital angular momentum, but not intrinsic spin. In order to do that you need at least the tetrad formalism. Doing that one observes that it seems to unnatural to restrict the geometry to vanishing torsion. Allowing torsion automatically means introducing spin currents.
1. Who's spin is considered in the Einstein-Cartan theory?
In the Einstein-Cartan theory, both the source and test particle's spin are taken into consideration.
2. What is the difference between the source's and test particle's spin in the theory?
The source's spin refers to the intrinsic angular momentum of the source object, while the test particle's spin refers to the angular momentum of a particle being tested in the presence of the source's gravitational field.
3. How does spin affect the curvature of spacetime in the Einstein-Cartan theory?
In the Einstein-Cartan theory, spin contributes to the curvature of spacetime through the spin tensor, which accounts for the torsion of spacetime.
4. Is spin the only factor that affects the curvature of spacetime in this theory?
No, in addition to spin, the energy and momentum of a source also contribute to the curvature of spacetime in the Einstein-Cartan theory.
5. Are there any experimental observations that support the inclusion of spin in the Einstein-Cartan theory?
Yes, there have been several experimental observations, such as the spin-orbit coupling in the atomic spectra and the precession of gyroscopes in a gravitational field, that support the inclusion of spin in the Einstein-Cartan theory.
  • Beyond the Standard Models
