Motion of mass constrained to rail
In summary: The force between rod and rail is internal.You have ##KE=\frac{1}{2} m v^2 + \frac{1}{2} I \omega^2## during the curve. From that you can do a little algebra to get:v=\frac{2\sqrt{3}R}{\sqrt{L^2+12 R^2}}v_0In summary, the velocity is lower, but goes back to the initial value once the rod leaves the curve - this is a result of energy conservation.
  • #71
A.T. said:
This seems to be the root of the confusion:
The force of constraint does no net work, so the total KE (linear + angular) doesn't change.
But the force of constraint can do negative linear work, and the same amount of positive angular work, so linear KE is converted to angular KE.
Still, you have the problem to explain where the linear force parallel to the rail should be coming from. All forces of constraint here act only perpendicular to the rail.
  • #72
Fantasist said:
##R## should be infinite before the curve? ##R## is the radius vector from the origin of the coordinate system to the center of mass of the rod.
No, R is the radius of curvature of the path, sorry I wasn't clear about that. A straight path has an infinite radius of curvature, a curved path has a finite radius of curvature. Therefore R goes from infinite before the curve to finite on the curve.
  • #73
As mentioned in a previous post, using a rod as the example object, the forces are perpendicular to the rail, but not perpendicular to the velocity (the path) of the center of mass of the rod.
  • #74
But they cannot act exactly at the mass center, because then the rod couldn't start rotating. In the curved part, off center forces acting perpendicular to the rail have a component parallel to the rail at the mass center.
  • #75
Why are you getting so wound up about 'practical details' here? The OP os about an ideal situation that assumes such practicalities have been taken care of. It's all taken care of by the word "constrained". Of course, you couldn't build the apparatus in the OP - it doesn't existt. But why pick out this one example of where strict theory demands impossible conditions but where the theory still predicts the result of a practical implementation. Physics is full of this sort of approach. Lens calculations, interference, impacts, all electrical circuit calculations etc. etc.
  • #76
I'm not getting wound up in anything. Just responding directly to a question.
  • #77
Why bother to respond then? It just adds fuel to the nonsense element of a thread that was, for a few posts, quite interesting and fundamental.
  • #78
##R## is only the radius of curvature if the path is in fact a circle around the origin.
The general expression for the linear kinetic energy in plane polar coordinates ##R,\Theta## is
$$\frac{m}{2}v^2 = \frac{m}{2}\dot{R}^2 + \frac{l^2}{2mR^2}$$
with ##\vec{l}=m \vec{R}\times \vec{v} = mR^2\dot{\Theta}## the angular momentum.
This expression is identical whether you have a mass wth velocity ##v## in a circular orbit with radius ##R##, or whether you have a mass with velocity ##v## on a linear trajectory that happens to be at the point where its trajectory touches the circle with radius ##R## (in both cases will the radial velocity be ##\dot{R}=0## and ##R## and ##l## be identical, hence also the kinetic energy).
  • #79
But the velocity of the center of mass has only a component parallel to the rail.
  • #80
The rotation is caused by a torque around the center of mass. And a pure torque doesn't affect the motion of the center of mass (see diagram below).
  • #81
I don't know why you are saying the apparatus couldn't be built. It shouldn't be too difficult to demonstrate this. You might even be able to use your model railway for it. The motor would take care of the friction. Just put a straight and circular section of track together, mount some rod (with a suitable mass) to the train and see whether the speed changes when it hits the point where the track curvature changes (ufortunately, I am personally not in a position to do it myself).
This isn't a practical problem but just a theoretical issue (namely how to correctly handle the fact that the rotational motion is rigidly constrained to the linear motion).
  • #82
Which means that in this case the constraint forces cannot exert a pure torque.
Fantasist said:
The above picture would violate conservation of KE, as I explained in post #54:
You need more KE to accelerate by Δv, than you gain by slowing down the same mass from the same v by the same Δv. You can consider the uniform rod as a collection of such symmetrical point mass pairs.
  • #83
No, the radius of curvature is the inverse of the curvature:
http://en.wikipedia.org/wiki/Radius_of_curvature_(mathematics)
http://en.wikipedia.org/wiki/Curvature
It is defined for arbitrary paths in arbitrary dimensions and is in no way restricted to a circle about the origin.
Again, R in the equations I posted above is not a coordinate (neither a generalized coordinate nor a polar coordinate). It is the radius of curvature of the path, a parameter of the path which changes along the path from infinite to finite.
  • #84
So what? Then it isn't a pure torque. Your constraints constrained the motion, they did not constrain the forces or torques. The forces and torques are whatever are required to produce the specified motion.
Again, you cannot both constrain the motion and constrain the forces. Once you specify one the other is determined. In this case, you specified the constraints on the motion, so the forces are whatever is needed to satisfy your specified constraints. You are attempting to add additional constraints (on the forces and torques) which are incompatible with your original constraints (on the translation and rotation).
  • #85
Fantasist said:
It shouldn't be too difficult to demonstrate this... unfortunately, I am personally not in a position to do it myself.
You should at least be able to draw a free body diagram of the simplest possible practical constraint mechanism required for this. When you analyze it at the transition, you will get a force that changes the linear speed of the rod center.
  • #86
That is completely missing the point. Of course you could analyze a physically realistic situation in enough detail to predict the outcome.
But the question as given in your OP is not physically realistic, assuming we take words like "rod" to mean what they usually mean in idealized questions about mechanical systems.
You can ignore the unreality and get a solution using energy methods (though for some reason you refuse to accept that strategy). That could be a good way to make a simple model of a realistic situation and use it to get a useful approximate result. But if you insist on the view that the situation in the OP is realistic, we might as well have a debate about what would happen in the track were shaped like a square circle.
  • #87
A circle with an infinite radius is still a circle, not a straight line ('infinite radius' just means 'for arbitrarily large finite radii').
Your equation for the kinetic energy of a point mass
[tex]\frac{m}{2}v^2 = \frac{m}{2} R^2 \omega^2[/tex]
only holds for a circular motion. The correct equation should contain a radial kinetic energy as well
$$\frac{m}{2}v^2 = \frac{m}{2}\dot{R}^2 + \frac{m}{2} R^2 \omega^2$$
And as I mentioned before, the ##R## in the angular momentum ##\vec{l}=m \vec{R}\times \vec{v}## has to be consistent with the ##R## in the above equations, and if it would suddenly go from finite to infinite or vice versa it would violate angular momentum conservation.
  • #88
The square circle is a completely inappropriate comparison. There no kinks in the path here, Everything is smooth (differentiable). Only the second derivative of the path has a discontinuity. But this isn't a practical problem.
  • #89
This thread got completely pointless.
Fantasist, we gave more than enough different methods and multiple descriptions how to solve the problem. If you continue to ignore them and stick to your errors, more repetitions won't help.
  • #90
I derived the correct equation above.
I already rebutted this argument. Again, the rod's momentum is obviously not conserved in this problem since it is not free from external forces.
  • Mechanics
  • Mechanics
  • Quantum Physics
