- #106
nikkkom
- 2,075
- 399
etudiant got it exactly right.
nikkkom said:This filter is a passive device. In Fukushima, to survive tsunami it would need to only be secured to the ground strongly enough to not float away.
nikkkom said:Nuclear plants are more strictly regulated because accidents can be much worse than on a natural gas plant, ...
LabratSR said:It seems that they should be planning for ALL scenarios, not just for what happened at Fukushima.
Most Curious said:Would filtered venting made a lot of difference at Fukushima ? When the hydrogen explosions occurred the nasty stuff bypassed the venting system anyway.
Hiddencamper said:As someone who works in a design department for a nuclear power plant, this type of modification is drastically more complex than it looks on the surface.
For one, you are extending containment to a location outside of the plant. You also have to add new penetrations to the containment which have a design to fail the containment in a controlled fashion. <SNIP>
westfield said:Of course there is some engineering to be done but don't the existing "Hardened Vent" lines on these plants already do exactly what you say would need to be done.
Are you saying these additional filter proposals are not going to be retrofitted to these existing 'Hardened Vent" lines or are you saying most plants of this type do not have existing "Hardened Vent" retrofits?
etudiant said:The venting system was not brought into play effectively, afaik, partly because the valves were inoperable without power. There were burst disks, but how well they performed is uncertain, some apparently did not.
The system was unable to relieve pressure because there was no safe vent option that was available. Partly because the vent that was built in was not designed to deal with emissions from a melting reactor, venting was not ever an attractive option for the operators.
If anyone has an English language timeline of the operator choices and options during the period between the quake and the explosions, it would be a real service to post it as a sticky.
The Melcor codes show that the reactors melt down within a half hour of losing cooling, so the ability to depressurize and inject water was understood to be crucial, yet it did not happen.
Hiddencamper said:Those opposed believe that the complex strategies for wet scrubbing during a severe accident are challenging and would take resources away from managing the core damaging event. In any case, managing the core damaging event directly reduces the amount of radioactive material being released in the first place, which everyone agrees on.
rmattila said:This argument is very difficult for me to follow, as the very idea behind the design in the 80's was to eliminate the need for unreliable decision-making in the case of a severe accident by enabling a completely passive initiation of venting. If your vent lines don't have filters, you probably want to keep the valves in the lines closed, and must count on the personnel to be able to open them at the right time.
gmax137 said:I agree that installing filters is the right approach, and the NEI efforts against the filters are misguided. But I still don't agree with characterizing this as a cheap or easy modification. And the filters aren't a silver bullet that solves all of the issues. Just my 2-cents.
etudiant said:... Is there any good reason, other than cost and regulatory uncertainty, why filters should not be added to the hardened vents?
gmax137 said:I think [strike]Exelon[/strike] NEI is standing on the principle that the regulator should establish requirements in measurable terms (such as, offsite dose or dose rate limits) and the licensee should do the engineering to design the features that result in those requirements being met. This is the essence of what "performance-based" means in nuke-speak. This principle has always been a source of tension within the regulating body (AEC or NRC), going back into the early 1960s. Also, the utility engineers still remember the costs associated with a number of the NRC-mandated post-TMI modifications that turned out to be pointless engineering and operational quagmires (e.g., H2 monitors in the large dry PWR containments, post-accident sampling systems, etc.). Whether the filters are a good place to take this stand is debatable in my mind, because (like you said) they seem to be such an obvious application of defense-in-depth (another long-standing principle which is sometimes forgotten).
a.ua. said:There are leaks in the containment of the reactor 1.
etudiant said:Since we are talking here about 'beyond design basis' accidents, is the NEI stance sensible?
If the Ramapo fault causes a serious failure at Indian Point and NYC gets the vented plume, it might impair nuclear industry shareholder value more substantially than any filter retrofit.
zapperzero said:The talk about re-aligning systems is over-optimistic for sure. Power might be out, places where valves are might be inaccessible for a reason or another. You need water and pumps and time, one or more of which might be lacking.
Generally speaking, you are telling us that active measures are as good as passive ones, which is simply not true.
With a pre-emplaced filter at the end of a hardened vent line, all the operators have to do, to vent safely, is exactly nothing - as compared to running around the plant in the dark, in unknown radiation field, to open valves and start-up pumps under time pressure, while lugging around gensets.
There's the matter of expertise too. To realign cooling systems and whatnot, you need to know the plant. To hook up a fire engine, you need to know exactly nothing, just find the right connector (big red pipe, conspicuously marked, by the side of the access road). All the operators could be dead (or evacuated, as was almost the case with Fukushima), and you'd still successfully flood the containment while the passive vent+filter keeps emissions down.
westfield said:Isn't that jumping to a conclusion?
Yes, Tepco say there is water coming out of one of the sandbed drain\s but the source of the water is unknown isn't it?
It could be a leak in the containment steel liner but it could be water finding its way down there on the outside of the liner between the liner and the concrete or it could be from some other source. There is a reason why the sand bed has drains in the first place.
It's interesting though.
Hiddencamper said:If you think during a severe accident that there's going to be some easy way to do ANYTHING you're going to have a bad time.
No matter what, it will take significant efforts by those at the plant to cope with a beyond design basis accident, with or without a filter.
