Explore Geometry of Symmetric Spaces & Lie Groups on PF
In summary: This is a great starting point. What about other manifolds?What other manifolds are there?You mention SU(2). What is the geometry of a SU(2) Lie group?I think this is a great place to start. We'll need to discuss more examples and see how they generalize.
  • #71
What is the website of your quaternion publications
  • #73
the Killing vector fields corresponding to the right action of the su(2) Lie generators will take me a while... I have no idea about how to do... but you say that Joe almost got them ?
post me here Joe answer ... I will try to study it and after doing some research in internet maybe I will be able to understand how a Killing vector fields could be defined from a group (SU(2))... maybe we have to define the agebra... and the adjoint representation... Lie bracket... all my post now will be related to this question... I hope that it will not take me too much time...;)
  • #74
... ok... what follow could be a good start...
the matrix expression for a SU(2) element as a function of SU(2) manifold coordinates is
[tex]g(x) = e^{x^i T_i} = \cos(r) + x^i T_i \frac{\sin(r)}{r}[/tex]
[tex]g^- = \cos(r) - x^i T_i \frac{\sin(r)}{r}[/tex]
[tex]\xi_A{}^i \partial_i g = g T_A[/tex]
[tex]g(T_A T_B - T_B T_A) = g ( \xi_A{}^i \partial_i \xi_B{}^j \partial_j - \xi_B{}^i \partial_i \xi_A{}^j \partial_j ) [/tex]
[tex]\xi_A{}^i ( \partial_i g^- ) g = T_A[/tex]
[tex]( \partial_i g^- ) g = \xi^-_i{}^A T_A[/tex]
to be continued tomorrow ... :)
  • #75
Garrett calculated the Left Invariant inverse killing vector field:
garrett said:
So, the correct expression for the inverse Killing vector field should be
[tex]
\xi^-_i{}^B = - < \left( (T_i - x^i) \frac{\sin(r)}{r} + x^i x^j T_j ( \frac{\cos(r)}{r^2} - \frac{\sin(r)}{r^3}) \right) \left( \cos(r) - x^k T_k \frac{\sin(r)}{r} \right) T_B >
[/tex]
[tex]
= \delta_{iB} \frac{\sin(r)\cos(r)}{r} + x^i x^B ( \frac{1}{r^2} - \frac{\sin(r)\cos(r)}{r^3} ) + \epsilon_{ikB} x^k \frac{\sin^2(r)}{r^2}
[/tex]
And the Right Invariant inverse killing field is:
[tex]
\xi'^-_i{}^B = - < \left( \cos(r) - x^k T_k \frac{\sin(r)}{r} \right) \left( (T_i - x^i) \frac{\sin(r)}{r} + x^i x^j T_j ( \frac{\cos(r)}{r^2} - \frac{\sin(r)}{r^3}) \right) T_B >
[/tex]
[tex]
= \delta_{iB} \frac{\sin(r)\cos(r)}{r} + x^i x^B ( \frac{1}{r^2} - \frac{\sin(r)\cos(r)}{r^3} ) - \epsilon_{ikB} x^k \frac{\sin^2(r)}{r^2}
[/tex]
which we invert to find the Right Invariant Killing vector field,
[tex]
\xi_B{}^i = \delta_{Bi} \frac{r \cos(r)}{\sin(r)} + x^B x^i ( \frac{1}{r^2} - \frac{\cos(r)}{r \sin(r)} ) - \epsilon_{Bik} x^k
[/tex]
  • #76
OK, this is great Mehdi. I've laid out everything you need to do starting with the beginning of this thread. With links to the wiki to help out. It's going to take a while to understand everything that's happened, and be able to work it out yourself -- but I think that's the best way to learn stuff. That's what this thread has been for. :)
Also, as you try to solve this, please do not post about it here on this thread, as I think everything is laid out already. Feel free to email me privately if you get stuck. And, of course, you can make a celebratory post when you get everything. ;) Once you can do this, which may take a while, you should be able to understand this next stuff we'll do too.
To check you answer for this vector field, you can compare it with the one Joe just posted -- which is the correct one. :)
  • #77
Alright, so let's put things together so far. We have two sets of three vector fields over our SU(2) group manifold. The first set corresponds to the Lie algebra generators acting on group elements from the left,
[tex]
\xi_A{}^i \partial_i g = T_A g
[/tex]
and, just to confuse things, that's called a "right invariant" vector field since the g acts on T_A from the right. The second set corresponds to the generators acting from the right (and is called a "left invariant" vector field),
[tex]
\xi'_A{}^i \partial_i g = g T_A
[/tex]
Using our explicit expression for g in terms of our group manifold coordinates, we were able to explicitly calculate expressions for these two sets of vector fields:
[tex]
\xi_B{}^i = \delta_{Bi} \frac{r \cos(r)}{\sin(r)} + x^B x^i ( \frac{1}{r^2} - \frac{\cos(r)}{r \sin(r)} ) + \epsilon_{Bik} x^k
[/tex]
[tex]
\xi'_B{}^i = \delta_{Bi} \frac{r \cos(r)}{\sin(r)} + x^B x^i ( \frac{1}{r^2} - \frac{\cos(r)}{r \sin(r)} ) - \epsilon_{Bik} x^k
[/tex]
Each of these six vector fields represents a continuous symmetry of the group manifold -- a way to flow the points of the manifold such that the shape stays the same. (But we don't really know the shape yet, since we haven't said what the metric is. We'll do this next.) We also know a neat trick for calculating the Lie derivative of one vector field with respect to another (the "Lie bracket"):
[tex]
( L_{\vec{\xi_A}} \vec{\xi_B} ) \underrightarrow{d} g = ( \xi_A{}^i \partial_i \xi_B{}^j \partial_j - \xi_B{}^i \partial_i \xi_A{}^j \partial_j ) g
[/tex]
[tex]
= (T_A T_B - T_B T_A) g = C_{ABC} T_C g
= C_{ABC} \vec{\xi_C} \underrightarrow{d} g
[/tex]
that implies the Lie bracket of two "right invariant" vector fields gives exactly the Lie algebra structure constants for our group:
[tex]
L_{\vec{\xi_A}} \vec{\xi_B} = C_{ABC} \vec{\xi_C} = -2 \epsilon_{ABC} \vec{\xi_C}
[/tex]
This is exactly as it should be. The composition of two flows induced by two symmetries gives us a flow equal to another symmetry, related by the structure constants between the symmetry generators. We could have calculated the Lie brackets between the vector fields explicitly and gotten the same answer, but it would have been a lot more work. We've basically exploited group theory to save us a lot of calculational work -- something theorists do a lot, to great satisfaction. OK, so what about the Lie brackets between the "left invariant" vector fields? The same trick gives
[tex]
( L_{\vec{\xi'_A}} \vec{\xi'_B} ) \underrightarrow{d} g = ( \xi'_A{}^i \partial_i \xi'_B{}^j \partial_j - \xi'_B{}^i \partial_i \xi'_A{}^j \partial_j ) g
[/tex]
[tex]
= g (T_B T_A - T_A T_B) = - C_{ABC} g T_C
= - C_{ABC} \vec{\xi'_C} \underrightarrow{d} g
[/tex]
that implies the Lie bracket of two "left invariant" vector fields gives MINUS the Lie algebra structure constants for our group:
[tex]
L_{\vec{\xi'_A}} \vec{\xi'_B} = -C_{ABC} \vec{\xi'_C} = 2 \epsilon_{ABC} \vec{\xi'_C}
[/tex]
So, these "left invariant" vector fields don't have the same structure as our Lie algebra, but the structure related by this minus sign.
I'll stop here and give the remaining symmetry relationship as a quick "homework" problem:
What's the Lie derivative of one of the "left invariant" vector fields with respect to one of the "right invariant" vector fields?
[tex]
L_{\vec{\xi_A}} \vec{\xi'_B} = ?
[/tex]
  • #78
Garrett my guess is:
[tex]
L_{\vec{\xi_A}} \vec{\xi'_B} = C_{ABC} \vec{\xi'_C} = -2 \epsilon_{ABC} \vec{\xi'_C}
[/tex]
and
[tex]
L_{\vec{\xi'_A}} \vec{\xi_B} = -C_{ABC} \vec{\xi_C} = 2 \epsilon_{ABC} \vec{\xi_C}
[/tex]
Now let's take even more risks (of doing false statements) postulating that...
[tex]
L_{\vec{\xi_A}} \vec{\xi'_B} = [{\vec{\xi_A}}, \vec{\xi'_B}]
[/tex]
Could we say then that the adjoint representation and the lie bracket are actually the same thing (homomorphic) ?!
[tex]
L_{\vec{\xi_A}} \vec{\xi'_B} = [{\vec{\xi_A}}, \vec{\xi'_B}]=ad({\vec{\xi_A})(\vec{\xi'_B})={ad_{\vec{\xi_A}}{\vec{\xi'_B}}
[/tex]
[itex]ad_{\vec{\xi_A}}[/itex] could be interpreted as a linear transformation of the vector field [itex]\vec{\xi_A}[/itex] that preserves a Lie bracket, [itex][{\vec{\xi_A}}, \vec{\xi'_B}][/itex] in this case.
Question 1: Is it true that the adjoint representation of su(2) is so(3)... and that the adjoint representation of su(2) give the structure constants which are also the matrix element of so(3). How so ?!
Question 2: What is the signification of 2 and -2 in [itex]-2 \epsilon_{ABC} \vec{\xi'_C}[/itex] and [itex]2 \epsilon_{ABC} \vec{\xi_C}[/itex] ?
They are probably structure constants coefficients but are they matrix element... of which matrix ?
  • #79
Hey Garrett, I need to clarify your notation a little more :),
garrett said:
[tex]
\vec{\xi_A} \underrightarrow{d} g = \xi_A{}^i \partial_i g
[/tex]
What does [itex] \underrightarrow{d} [/itex] mean? There's an ambiguity here; this is not the one-form [itex] d_i \underrightarrow{dx^i} [/itex] with components [itex]d_i[/itex], it's the exterior derivative operator, [itex] \underrightarrow{d} = \underrightarrow{dx^i} \frac{\partial}{\partial x^i}[/itex]. Ideally one would use a bold d to distinguish between the two.
  • #80
Yes, it's the exterior derivative operator,
[tex] \underrightarrow{d} = \underrightarrow{dx^i} \frac{\partial}{\partial x^i}[/tex]
I wrote it simply as d in order to be familiar, but you're right that it's a little confusing that way. In my last paper and in the wiki I write it instead as
[tex] \underrightarrow{\partial} = \underrightarrow{dx^i} \frac{\partial}{\partial x^i} = \underrightarrow{dx^i} \partial_i[/tex]
which is clearer, but non-standard. But, let's go ahead and write it that way from now on. :)
Hey, would you like to offer up the correct answer to the last question about the commutation relations between the two sets of Killing vector fields?
  • #81
Sure :). Working on it now.
In the mean time another notation question that comes up when one expands the Lie bracket of two vector fields,
[tex]
({\cal L}_{\vec{X}} \vec{Y}) f = (\vec{X} \vec{Y} f -\vec{X} \vec{Y} f)
[/tex]
Taking the first term,
[tex]
\vec{X} \vec{Y} f = \vec{X} (Y^i \vec{\partial i} f)
[/tex]
What's [itex] \vec{\partial i} f [/itex] and how does it relate to [itex]\partial i f[/itex], that is what is the result of a vector acting on a scalar?
(In the lie bracket expansion in our exercise we act with the lie derivative on [itex]\underrightarrow{\partial}g[/itex], but this same problem comes up when we act with the second vector field).
  • #82
Ah, yes, mathematicians often write a vector operating on a function as [itex]\vec{v}f = v^i \partial_i f[/itex]. I do not write it that way. Instead, I would write the same thing as
[tex]
\vec{v} \underrightarrow{\partial} f = v^i \partial_i f
[/tex]
I like to have conservation of arrows in my notation. :)
  • #83
[tex]
[/tex]
Oooh, so vectors act on scalars the same as vectors act on one-forms?
So how would you conserve the arrows in:
[tex]
[/tex]
  • #84
Yes, after all, a scalar is just a 0-form.
[tex]
[/tex]
That would be
[tex]
({\cal L}_{\vec{X}} \vec{Y}) \underrightarrow{\partial} f
(( \vec{X} \underrightarrow{\partial} )( \vec{Y} \underrightarrow{\partial} ) - ( \vec{Y} \underrightarrow{\partial} )( \vec{X} \underrightarrow{\partial} )) f
[/tex]
And, you know, since the Lie derivative of one vector field with respect to another is just another vector field, this just comes from
[tex]
( \vec{X} \underrightarrow{\partial} ) \vec{Y} - ( \vec{Y} \underrightarrow{\partial} ) \vec{X}
[/tex]
  • #85
I know that :wink:. I meant to say that vectors act on 1-forms and produce a 0-form (by contraction), and visa-versa. However here we have a vector acting on a 0-form also producing a 0-form; that seems strange to me; after all a 0-form acting (multiplying) a vector doesn't produce a 0-form. What am I missing? (I imagine the answer is to do with the abstract nature of tangent vectors, which act on a function - how fundamental is this? i.e. this doesn't happen in, say, geometric algebra.)
  • #86
[tex]
[/tex]
Ok, I'm sure I've not got the arrows in the right places :), but it looks like they commute, and the Lie derivate of one set of invariant fields with respect to the other is zero.
Here's my reasoning:
[tex]
\begin{align*}
(L_{\vec{\xi_A}} \vec{\xi'_B}) \; \underrightarrow{\partial} g
& = \vec{\xi_A} (\vec{\xi'_B} \; \underrightarrow{\partial} g) - \vec{\xi'_B} (\vec{\xi_B} \; \underrightarrow{\partial} g) \\
& = \vec{\xi_A} \; \underrightarrow{\partial} (g T_B) - \vec{\xi'_B} \; \underrightarrow{\partial} (T_A g) \\
& = T_A (g T_B) - (T_A g) T_B \\
& = 0
\end{align}
[/tex]
with the last step following by associativity of the matrix product.
BTW, I'm still mega-worried about this over/under arrow convention, and the way that vectors act on 1-forms and 0-forms; ok, mainly the latter, not so much the former. Also, the argument so far seems to depend upon [itex]g[/itex] being a 0-form, however if instead of using a matrix representation of the [itex]T_A[/itex]s we use a bi-vector representation, then [itex]g[/itex] becomes a multi-grade (scalar + bi-vector) object, and then these vector fields don't act on them in the same way. I guess in that case we need to go back to the beginning and redefine the killing vector fields in a different way.
  • #87
Don't freak out Joe, everything works just fine. These vectors do not act on scalars or Clifford elements like in some math notation you've seen -- they commute with them. The vectors only act on forms, and the exterior derivative is a special form that acts on other forms as a derivative, including 0-form scalars and Clifford coefficients. So
[tex]
\vec{v} \underrightarrow{\partial} g =
v^i \vec{\partial_i} \underrightarrow{dx^j} \partial_j g
= v^i \partial_i g
[/tex]
is the equivalent way to get the derivative of a function or Clifford field along a vector.
Just keep in mind that vector and form basis elements ALWAYS commute with scalars and Clifford basis elements.
Zero is the right answer, for the reason you said. But can you go clean up the arrows above and put in partial derivatives where needed now? You only need to insert two [itex]\underrightarrow{\partial}[/itex]'s, then all your equations are perfect.
  • #88
garrett said:
Don't freak out Joe, everything works just fine...
Awww, I like to get a good freak on from time to time o:) Thanks for the clarification.
Ok, so it must be this (with a previous typo in this post fixed),
[tex]
\begin{align*}
& = \vec{\xi_A} \underrightarrow{\partial} (\vec{\xi'_B} \; \underrightarrow{\partial} g) -
\vec{\xi'_B} \underrightarrow{\partial} (\vec{\xi_A} \; \underrightarrow{\partial} g) \\
& = 0
\end{align}
[/tex]
  • #89
Yep, that's it -- except for the extra B buzzing around, A?
I'm going to go have dinner, then come back and talk about what this zero answer means.
  • #90
OK, so at this point we've figured out quite a bit about our group manifold. We started with the three Lie algebra generators, [itex]T_A[/tex], and even cleverly identified them as Clifford algebra bivectors. Exponentiating these, multiplied by coordinates, we got all the group elements, parameterized by coordinates. This is our manifold, with each manifold point associated with coordinates. We then were able to calculate two sets of three vector fields over the manifold, one set corresponding to the left action of the generators on the group elements, and the other set corresponding to the right action of the generators. The Lie derivative (commutation) relations between the first set of vector fields gave exactly the structure constants for the Lie algebra, while the Lie derivative relations between the second set gave negative the structure constants. Also, the Lie derivative of an element of the second set with respect to an element from the first set is zero. These two independent sets of vector fields are associated with the group's symmetries -- and we've been calling them Killing vector fields, even though we haven't said what the metric is. Time to change that!
Recall that a vector field is Killing (and a "symmetry") if and only if it is associated with a flow of the manifold points that leaves the geometry unchanged. By geometry here is meant the shape of the manifold, and this is traditionally encoded by a metric. Mathematically, a vector field is Killing iff the Lie derivative of the metric with respect to the vector field is zero. But recall a few posts back in this thread that I would like to use the frame, or set of orthonormal basis vectors, instead of the metric. The relation between frame and metric, in components, was derived as
[tex]
g_{ij} = (e_i)^A (e_j)^B \delta_{AB}
[/tex]
and between orthonormal basis vectors and the inverse metric
[tex]
g^{ij} = (e^-_A)^i (e^-_B)^j \delta^{AB}
[/tex]
An important thing to notice about this relationship is that a set of orthonormal basis vectors gives the same metric as a set that is arbitrarily rotated. So, in terms of the frame, a vector field is Killing if and only if the Lie derivative of the orthonormal basis vectors is given by a rotation:
[tex]
{{\cal L}_\vec{\xi}} \, \vec{e_A} = B_C{}^D \vec{e_D}
[/tex]
with
[tex]
B_C{}^D = - B^D{}_C
[/tex]
antisymmetric in its indices iff [itex]\vec{\xi}[/itex] is Killing. This is even neater using Clifford algebra. Writing the set of three orthonormal basis vectors as a Clifford vector valued vector field,
[tex]
\vec{e} = \vec{e_A} \sigma^A = \sigma^A (e^-_A)^i \vec{\partial_i}
[/tex]
[tex]
{{\cal L}_\vec{\xi}} \, \vec{e} = B \times \vec{e}
[/tex]
for some Clifford bivector field, B.
Now, since we've said we have two sets of three vector fields which we've said are Killing, we need to pick a frame (and hence a metric) such that we weren't lying about that! A clear winner leaps out at us. Since, as you found,
[tex]
{{\cal L}_\vec{\xi_A}} \, \vec{\xi'_B} = 0
[/tex]
the best choice for a set of orthonormal basis vectors is simply the set of symmetry vectors that had the wrong sign for the commutation relations between them:
[tex]
\vec{e_B} = \vec{\xi'_B} = \vec{\partial_i} \left( \delta_{Bi} \frac{r \cos(r)}{\sin(r)} + x^B x^i ( \frac{1}{r^2} - \frac{\cos(r)}{r \sin(r)} ) - \epsilon_{Bik} x^k \right)
[/tex]
And, as a bonus, we already know the frame 1-forms corresponding to these vectors, since we calculated them first.
OK, once you believe all this, which may take a while, I'll have three "homework" questions for you:
1) Are the set of three [itex]\vec{\xi'_B}[/itex] also Killing, even though we've chosen them as our orthonormal basis vector fields? (Why?)
2) What is the metric, [itex]g_{ij}[/itex] corresponding to this choice of orhonormal basis vectors?
3) Would the metric have been different if we had chosen to use [itex]\vec{\xi_B}[/itex] as the orthonormal basis vectors?
  • #91
[tex]
[/tex]
I am a bit confused. I understand the desire to conserve arrows and the fact that a function is a 0-form but I would have expected you to write this as
[tex]
\vec{v} \underrightarrow{ f} = v^i \partial_i f
[/tex]
no?!:confused:
In the way you wrote it, what do you mean by [itex] {\vec v}[/itex] ? Normally one would write [itex]{\vec v} = v_i \partial_i [/itex] but your partial derivatives are part of the 0-form?!?
Thanks
  • #92
[tex]
[/tex]
no?!:confused:
Let me give you some of the cast of characters:
coordinate basis vectors:
[tex]
\vec{\partial_i}
[/tex]
coordinate basis 1-forms:
[tex]
[/tex]
partial derivative operator with respect to a coordinate:
[tex]
\partial_i
[/tex]
OK, with those guys, we can build vectors:
[tex]
\vec{v} = v^i \vec{\partial_i}
[/tex]
forms:
[tex]
\underrightarrow{f} = f_i \underrightarrow{dx^i}
[/tex]
and the exterior derivative operator:
[tex]
\underrightarrow{\partial} = \underrightarrow{dx^i} \partial_i
[/tex]
There is a contraction rule between basis vectors and basis forms:
[tex]
\vec{\partial_i} \underrightarrow{dx^j} = \delta_i^j
[/tex]
That's it!
Now, for some examples. A vector contracted with a 1-form:
[tex]
\vec{v} \underrightarrow{f} = v^i f_i
[/tex]
The exterior derivative of a 1-form:
[tex]
\underrightarrow{\partial} \underrightarrow{f} = \underrightarrow{dx^i} \underrightarrow{dx^j} \partial_i f_j
= \underrightarrow{\underrightarrow{F}}
[/tex]
And the derivative of a 1-form along a vector, obtained by first contracting the vector with the exterior derivative:
[tex]
( \vec{v} \underrightarrow{\partial} ) \underrightarrow{f}
= ( v^i \partial_i f_j ) \underrightarrow{dx^j}
[/tex]
Happy?
  • #93
... even though we haven't said what the metric is. Time to change that!
Can you explain how to talk about the metric in your notation?
The metric tends to be formulated as, [itex] g = g_{ij} dx^i \otimes dx^j[/itex], however your [itex]\underrightarrow{dx^i} [/itex] basis elements are antisymmetric, not symmetric. How do you define this?
Of course, operating on a scalar, the lie derivative is equivalent to the covariant derivative, reducing to the expression I mentioned early on, [itex] \xi_{i;j} + \xi_{j;i} = 0 [/itex]. Can you give me some hints as to how to derive the expression for the lie derivative acting on the viel-bein? (We've not mentioned covariant derivatives yet!).
  • #94
Taoy said:
Can you explain how to talk about the metric in your notation? The metric tends to be formulated as, [itex] g = g_{ij} dx^i \otimes dx^j[/itex], however your [itex]\underrightarrow{dx^i} [/itex] basis elements are antisymmetric, not symmetric. How do you define this?
Sure. From my point of view, the vielbein is more fundamental than the metric. The vielbein -- the set of orthonormal vectors defined at each point -- includes information about its orientation and about its scale. The metric is just a convenient way of describing just the scale information. It doesn't, by itself, exist as a well defined geometric object in my way of thinking, but just as a useful bit of scale information related to the vielbein. Here's how it pops up:
In order to compare two vectors at a point, one can map them into a local inertial frame using the frame (inverse vielbein) and then take their dot product. This is where defining the frame as a Clifford vector valued 1-form comes in, as we can write:
[tex]
(\vec{u}\underrightarrow{e}) \cdot (\vec{v}\underrightarrow{e})
= u^i (e_i)^\alpha v^j (e_j)^\beta \gamma_\alpha \cdot \gamma_\beta
= u^i v^j \left( (e_i)^\alpha (e_j)^\beta \eta_{\alpha \beta} \right)
= u^i v^j g_{ij}
[/tex]
which shows exactly how the metric pops up.
Well, the definition of the Lie derivative of a vielbein vector is
[tex]
{{\cal L}_\vec{\xi}} \, \vec{e_\alpha}
= (\vec{\xi} \underrightarrow{\partial}) \vec{e_\alpha} - ( \vec{e_\alpha} \underrightarrow{\partial}) \vec{\xi}
= (\xi^i \partial_i (e_\alpha)^j - (e_\alpha)^i \partial_i \xi^j) \vec{\partial_j}
[/tex]
And the Lie derivative of Clifford basis elements is zero. That let's you calculate the Lie derivative of [itex]\vec{e}[/itex]. If you'd like, I could derive why the Lie derivative is what it is, in terms of vector induced flows, but it's kind of involved. I'll work on putting that derivation up on the wiki though.
  • #95
[tex]
\vec{\partial_i}
[/tex]
[tex]
[/tex]
[tex]
\partial_i
[/tex]
[tex]
[/tex]
forms:
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
That's it!
[tex]
[/tex]
[tex]
[/tex]
[tex]
[/tex]
Happy?
Yes, it makes perfect sense. Sorry, I was not trying to be difficult. It is clear now and it's a nice notation (I had assumed that the single under arrow was for any n-form but now I see that there are n arrows for an n-form). It's the first time that I see explicitly the exterior derivative as being assign a specific symbol like your [itex] \underrightarrow{\partial} [/itex], in the conventional (but not as clear) notation, the "d" is always applied on something, the "d" is never presented on its own. But I do like your notation much more.
Thank you for the clarification. It's appreciated.
Patrick
  • #96
Garrett can you explain please what is the difference between a killing vector field and a killing form.
I mean how to use a killing form to find a killing vector field.
  • #97
They aren't directly related -- just named after the same guy.
A Killing vector field gives a flow on a manifold that preserves its geometric shape.
A Killing form comes from the classifications of Lie groups and their structure constants.
They're sort of related, but not directly, and it would take a lot of explaining and abstraction to get to Killing forms -- so I advise you not to worry about them yet.
  • #98
Glad you like it, Patrick. :)
  • #99
Hey Joe, you figure out the metric yet?
If not, I'll post it in the morning.
  • #100
Hey Garrett, no not yet; I'm off to Berlin today for a week (to the Marcel Grossman conference), so I won't get to post anything for a week or so. BUT I'm expecting to have it all worked out by next weekend :). Feel free to post the next bit though if you want; I'll catch up.
BTW, my last question was ill formed. What I meant to ask was how if a vector field is Killing iff the Lie derivative of the metric with respect to the vector field is zero, that leads to the condition on the lie derivative of the vielbein that you quoted. I've scratched my head, but not derived it yet. However, that doesn't mean that I can't derive it! :) (... but it's tricky then a hint would be helpful :).
Joe
  • #101
Hey Joe,
Wow, MG11 looks cool -- have fun. No hurry on the SU(2) metric, get to it when you feel like it.
The derivation of the version of Killing's equation using the frame or vielbein instead of the metric is pretty straightforward. Start with the expression for the Lie derivative of the metric components, then plug in the expression for the metric in terms of the frame components.
Here's what may be causing confusion though: there is no pretty (index free) way, using the notation I've described, to deal with the metric. So I choose to think of Killing's equation in terms of the Lie derivative of the vielbein as fundamental. The two expressions are equivalent, so it's a matter of taste.
(And, oops, I had an index wrong in a previous expression for Killing's equation. It should be:
[tex]
{{\cal L}_\vec{\xi}} \, \vec{e_C} = B_C{}^D \vec{e_D}
[/tex]
with
[tex]
B_C{}^D = - B^D{}_C
[/tex]
If you can't prove the equivalence of the two expressions for Killing's equation to your satisfaction, let me know and I'll go through it.
  • #102
Hey Garrett, finally found some wireless connectivity here at Freie University, Berlin; and for my sins I stayed up last night until I'd done my homework... yes; I'm coked up on coffee to make up for it :).
Ok, here's what I think.
I think that the answer is yes, because [itex] {\cal L}_{\vec{\xi'_A}} \vec{\xi'_B} = 2 \epsilon_{ABC} \vec{\xi'_C} [/itex], and for a fixed B, the right hand side is antisymmetric in A and C, and so like rotation - it therefore fulfils the requirement for a killing vector.
However, the [itex]\vec{\xi_A}[/itex] fields are non-killing vectors with respect to this metric; BUT we can also form a metric out of these other fields, and they are killing vectors with respect to that metric. We appear then to have two independant metrics that this manifold can support.
I believe it is,
[tex]
g'_{ij} = \frac{r^2}{\sin^2 r} \delta_{ij} + x_i x_j \left(\frac{1}{r^2} - \frac{1}{\sin^2 r} \right)
[/tex]
Apparently not. The difference in sign of the [itex]\epsilon[/itex] term doesn't contribute to a change in the form of [itex]g_{ij}[/itex] under the replacement of [itex]\vec{\xi'_A}[/itex] with [itex]\vec{\xi_A}[/itex].
  • #103
garrett said:
Hey Joe,
It should be. I'm primarily here because tomorrow David Hestenes is hosting a parallel session on Geometric Algebra and Gravity; Doran and Lasenby are here too apparently. I'm hoping to find some people who are into the conformal projective framework... I'll definitely let you know how it goes :).
  • #104
Well, you've certainly found the best bunch.
Make sure to talk with Chris Doran about black holes -- he's written a couple of especially clear papers on them in the past couple of years.
And, err, don't expect them to talk about differential forms. ;)
  • #105
Great.
OK, we'll see how that works out... ;)
For our set of three orthonormal vector fields, we choose
[tex]
\vec{e_A}=\vec{\xi'_A}
[/tex]
The first question was whether these vector fields are Killing with respect to the metric associated with this orthnormal basis.
Yes. Except your wording is funny. The relevant equation is:
[tex]
{\cal L}_{\vec{\xi'_A}} \vec{e_B} = 2 \epsilon_{ABC} \vec{e_C}
[/tex]
Each vector field, [itex]\vec{\xi'_A}[/itex], is Killing because it generates a rotation of the orthonormal basis -- [itex]2 \epsilon_{ABC}[/itex] is antisymmetric in B and C.
Nope, actually they are also Killing.
[tex]
{\cal L}_{\vec{\xi_A}} \vec{e_B} = 0
[/tex]
The Lie derivative of the orthonormal basis vectors with respect to these vectors vanishes. If you wish to be pedantic, note that 0 is technically antisymmetric in its indices, since 0=-0.
You answer this below -- both choices of orthonormal basis vectors produce the same metric.
I believe it is,
[tex]
[/tex]
Yes, this is what I got for the "inverse metric":
[tex]
g^{ij} = \frac{r^2}{\sin^2 r} \delta^{ij} + x^i x^j \left(\frac{1}{r^2} - \frac{1}{\sin^2 r} \right)
[/tex]
and for the metric I got
[tex]
g_{ij} = \frac{\sin^2 }{r^2} \delta_{ij} + x^i x^j \frac{1}{r^2} \left( 1 - \frac{\sin^2 r}{r^2} \right)
[/tex]
Correct! So, choosing either set of Killing vector fields to be the orthonormal basis vectors gives the same metric for SU(2). I like to choose [itex]\vec{e_A}=\vec{\xi'_A}[/itex] because they have the nice property that [itex]{\cal L}_{\vec{\xi_A}} \vec{e_B} = 0[/itex], and the [itex]\vec{\xi_A}[/itex] Killing vector fields have the same commutation relations as the su(2) generators, [itex]T_A[/itex].
One more quick question, when you get a chance:
What's the expression for the frame (vielbein) 1-form -- corresponding to the chosen orthonormal basis vectors?
[tex]
\underrightarrow{e}=?
[/tex]
  • Differential Geometry
  • Linear and Abstract Algebra
  • Poll
  • Science and Math Textbooks
