Can my digital camera function at -20 degrees Celcius?
In summary, the Canon Digital IXUS 400 has given in after 5 loyal years and may not be able to be fixed. The battery and lubricants in the motors/gears are the first to die. If it's kept warm, it may still be usable.
LennoxLewis
129
After 5 loyal years, my Canon Digital IXUS 400 has given in... i can take pictures, but there are red stripes all over them. Maybe it is something fixable, but I've been meaning to replace the thing anyway.
So, i put it in a plastic sealed bag in the freezer, which the thermometer indicates is at -21 degrees Celsius. What will die first? The accu? Will it overcome the powers of nature and keep functioning?
The camera will probably be fine, the only parts that will suffer are the batteries and any lubricants in motors/gears.
Are you sure it's -21, that's cold for a domestic freezer
Liquid crystal display?
'liquid' being the important part.
Could be -20 as well, it's only a 1,50 euro thermometer that's hard to read because it immediately rises in temperature if you pick it up to get a good read. But i turned the fridge power to maximum so this is probably why it's so cold.. i really want to push the limit of this fine camera. Indeed it is the battery that gives out first. Every 5 or so minutes i checked if it still worked, and it's actually pretty strong. But once the surface temperature of the camera got below -5 C(this is just an estimate), the battery failed before the lens-system could coil out completely, and after cooling it even further, it didn't move the lens-system at all; all it says was "replace battery".
After having the thing gradually warm up to room temperature, it functions exactly as it did, though. The battery capacity could've deteriorated in the process, but so far it seems no big irreversible damage occurred. Pretty amazing if you consider what vulnerable electronics is inside.
I'm not going to try for safety reasons, but anyone care to take a gander if it can function at, say , 80 degrees Celcius? (by heat oven or whatever, no liquid-warming of course)
If they didn't work at -21, they sure wouldn't sell in Alberta. That's a moderate winter temperature here. Still, it's a good idea to keep it warm until you need to shoot. Batteries do indeed tend to give out first upon prolonged exposure. Cheaper units might also have sealing issues that could allow condensation to build up inside.
I've used my digital camera in weather as low as about -15 C, but it simply will not function if the battery is allowed to get that cold. I have to keep it in an interior pocket and can only use it for a minute or two at a time before the battery can no longer produce enough electricity to power it.
I have had a similar experience. A cold battery doesn't work well, if at all.
I have manual cameras get sluggish in cold weather.
I would recommend against freezing the camera, and I'd recommend contacting the manufacturer. There could be sensitive components that should not be used when cold, and the other part is any humidity in the camera will freeze and could perhaps damage sensitive parts when thawing or condensing. Make sure to put a bag of silica gel in with the camera to absorb moisture.
Capacitor electrolytes aren't going to function normally if they freeze, I'd think.
1. Can my digital camera survive in extreme temperatures?
Many digital cameras are designed to function within a specific range of temperatures, typically between 0 to 40 degrees Celcius. However, some cameras are specifically designed to withstand extreme temperatures, such as -20 degrees Celcius.
2. Will my camera's battery still work in -20 degrees Celcius?
The battery life of your camera may be affected by extreme temperatures. In colder temperatures, the battery may drain faster than normal. It is recommended to keep a spare battery on hand and to keep them both warm until you are ready to use them.
3. Can I take high-quality photos in -20 degrees Celcius?
The quality of your photos may be affected by extreme temperatures. In colder temperatures, the camera's sensor may not perform as well, resulting in lower quality images. It is important to keep the camera as warm as possible and avoid sudden temperature changes to ensure the best photo quality.
4. What precautions should I take when using my camera in -20 degrees Celcius?
It is important to protect your camera from extreme temperatures. Make sure to keep it in a waterproof and insulated bag when not in use. Avoid exposing it to sudden temperature changes, and be careful not to bring it from a cold environment to a warm one too quickly, as this can cause condensation to form inside the camera.
5. Will using my camera in -20 degrees Celcius void the warranty?
Most camera manufacturers do not cover damages caused by extreme temperatures under their warranty. It is important to check your camera's manual or contact the manufacturer to see if your specific model is designed to function in -20 degrees Celcius and if any warranty will be voided by using it in these conditions.
