Circular motion - determining expression for a position vector
In summary, the conversation discusses the position of a particle constrained to move in a circle of radius R, which can be specified by the angle theta(t) and follows standard conventions. The question asks for an expression for the position vector of the particle, given that it starts on the positive y-axis at t = 0 and moves with constant omega. The two answers provided are r(t) = Rcos(omega*t)xhat + Rsin(omega*t)yhat and R*yhat + Rcos(omega*t)xhat, with the correct answer being the first one.
Linus Pauling
190
1. Consider a particle--the small red block in the figure--that is constrained to move in a circle of radius R. We can specify its position solely by theta(t), the angle that the vector from the origin to the block makes with our chosen reference axis at time t. Following the standard conventions we measure theta(t) in the counterclockwise direction from the positive x axis.
Determine an expression for the position vector of a particle that starts on the positive y-axis at t = 0 (i.e., at t = 0, (x_0, y_0) = (0, R)) and subsequently moves with constant omega.
Express your answer in terms of R, omega, t, and unit vectors x_unit and y_unit.
2. r(t) = Rcos(omega*t)xhat + Rsin(omega*t)yhat
3. R*yhat + Rcos(omega*t)xhat
I may be confused - I see what looks like one question and two answers.
I don't see the answer to #1. When t = 0 your #2 answer works out to (R,0). And when t=0 your #3 answer works out to (R,R). The answer for #1 should work out to (0,R) when t = 0.
+ Rsin(omega*t)yhat
Thank you for your question. I would like to clarify a few things before providing a response. First, it would be helpful to know what specific field or area of science this question pertains to, as the approach and terminology may differ. Additionally, the use of "x_unit" and "y_unit" in the expression is not clear. Are these referring to unit vectors in the x and y direction, respectively, or are they specific quantities with defined values?
Assuming that the expression is referring to unit vectors in the x and y direction, and based on the given information, we can approach this problem using vector mathematics. The position vector, r(t), of the particle at any time t can be expressed as the sum of its x and y components, where the x component is given by Rcos(omega*t) and the y component is given by Rsin(omega*t). Therefore, the position vector can be expressed as:
r(t) = Rcos(omega*t)x_unit + Rsin(omega*t)y_unit
Where x_unit and y_unit are unit vectors in the x and y direction, respectively. This expression takes into account the starting position of the particle at t = 0, which is on the positive y-axis at a distance of R from the origin. The constant omega represents the angular velocity of the particle, which determines its rate of change in position.
In summary, the expression for the position vector of a particle constrained to move in a circular motion can be determined by considering its x and y components and expressing them in terms of the given parameters R, omega, t, and unit vectors in the x and y direction. I hope this helps clarify and provide a satisfactory response to your question.
1. What is circular motion?
Circular motion is a type of motion in which an object moves in a circular path around a fixed point called the center of rotation. It is a common type of motion observed in nature and in man-made objects such as wheels and gears.
2. How is circular motion different from linear motion?
Circular motion involves the object moving along a curved path, while linear motion involves the object moving along a straight line. In circular motion, the speed and direction of the object are constantly changing, whereas in linear motion, the speed and direction remain constant.
3. What is the position vector in circular motion?
The position vector in circular motion is a vector that describes the position of an object relative to the center of rotation. It is usually represented by the symbol r and is measured from the center of rotation to the current position of the object.
4. How do you determine the expression for a position vector in circular motion?
The expression for a position vector in circular motion can be determined using the equation r = Rcosθ + Rsinθ, where r is the position vector, R is the radius of the circular path, and θ is the angle between the position vector and the horizontal axis.
5. What factors affect the position vector in circular motion?
The position vector in circular motion is affected by the radius of the circular path, the speed of the object, and the time elapsed. It is also affected by any external forces acting on the object, such as friction or gravity.
