Gauge invariance of stress-energy tensor for EM field
In summary, the stress-energy tensor in a free EM field can be redefined by adding an arbitrary function to it and still maintain gauge invariance. This is due to the arbitrariness in the definitions of local fluxes of energy and momentum. In naive field theory, the Lagrangian and energy-momentum tensor are not unique, but their integral, the total energy and momentum of the field, is well-defined. In general relativity, the energy-momentum tensor is defined as the source of the gravitational field and is unique and automatically symmetric. It is recommended to use this definition for the correct answer.
Trave11er
71
For free EM field:
L=-[itex]\frac{1}{4}[/itex]FabFab
Then the stress-energy tensor is given by:
Tmn=-FmlvAl+[itex]\frac{1}{4}[/itex]gmnFabFab
The author then redefines Tmn - he adds ∂lΩlmn to it,
where Ωlmn=-Ωmln.
The redefined tensor is:
Tmn=-FmlFvl+gmv[itex]\frac{1}{4}[/itex]FabFab
It is gauge invariant and still satisfies ∂mTmn=0.
The question: is why the addition is allowed? - to my uneducated mind the procedure seems like changing the energy-momentum tensor arbitrarily.
It comes from the fact that the whole theory is gauge-invariant, i.e. the 4-potential is unique up to a sp-time derivative of an arbitrary function epsilon. It follows that the energy-momentum is also arbitrary so we can add arbitray functions to it to have it the way we want it, conserved and gauge-invariant. The de n A l in the original formulation spoils gauge invariance.
But in case with four-potential gauge invariance leaves the fields intact as well as the EM field tensor, whereas the components of stress-energy tensor have physical meaning as energy density, flux etc.
The original stress-energy tensor is not symmetric; you can fix the arbitrariness in it by demanding that it be symmetric, and this also renders it gauge invariant.
So this is all due to initial arbitrariness in Lagrangian?
No, it's due to arbitrariness in definitions of local fluxes of energy and momentum.
Pardon, but I don't understand. Aren't the fluxes of energy and momentum physical things. I mean, if you have a value for 1 kg*m/s for a bullet in x-direction, then you have some value for a the stress energy tensor of a field in some small volume - how can you redefine that?
Yes. And No. :smile:
In naive field theory, no. It is always possible to add a four-divergence to the Lagrangian density without changing the physical content of the theory. Thus the Lagrangian is not unique, and neither is the energy-momentum tensor. But its integral, the total energy and momentum of the field, is a well-defined and unique quantity. (Note that this is unrelated to electromagnetic gauge invariance, as the same argument applies to other fields as well.)
When you go on to look at the angular momentum density, you find it will not even be conserved unless the energy-momentum tensor is symmetric, which the canonical form is not. So you must, by hand, symmetrize it.
In general relativity, yes. The energy-momentum tensor is defined as the source of the gravitational field: Tμν ≡ 2δL/δgμν, and is unique, and automatically symmetric. The moral is: use this definition and get the correct answer at once, even if you're not doing general relativity.
Thank you a lot Bill_K. This is an greatly insightful answer. I appreciate your help very much.
1. What is gauge invariance in the context of the stress-energy tensor for EM field?
Gauge invariance refers to the property that the stress-energy tensor for the electromagnetic (EM) field remains unchanged under a change in the gauge of the EM field. This means that the physical predictions and equations of motion for the EM field remain the same, regardless of the particular gauge chosen.
2. Why is gauge invariance important for the stress-energy tensor of the EM field?
Gauge invariance is important because it ensures that the physical laws and predictions of the EM field are independent of the specific mathematical formalism used to describe it. This allows for a more consistent and reliable understanding of the behavior of the EM field.
3. How is gauge invariance related to the conservation of energy and momentum in the EM field?
Gauge invariance is directly related to the conservation of energy and momentum in the EM field. This is because the stress-energy tensor is a mathematical representation of the energy-momentum density and flux in the EM field, and its gauge invariance ensures that these quantities are conserved.
4. Can gauge invariance be violated in the stress-energy tensor for the EM field?
Yes, gauge invariance can be violated in certain situations, such as in the presence of certain boundary conditions or when considering more complex systems. However, in most cases, gauge invariance holds true and is an important principle in the study of the EM field.
5. Are there any practical applications of gauge invariance for the stress-energy tensor of the EM field?
Yes, there are practical applications of gauge invariance, particularly in the fields of electromagnetism and quantum field theory. It allows for the development of consistent and accurate mathematical models for the behavior of the EM field, which in turn can be used to make predictions and guide experimental research.
  • Quantum Physics
  • Quantum Physics
