New Reply
Capacitor Equation
Share Thread Thread Tools
Jan20-13, 09:09 PM   #1
Capacitor Equation
1. The problem statement, all variables and given/known data
Derive a relationship for Cs for a two capacitor series circuit with a resistor. Start by showing that the same charge separation q is present across the capacitor and each of the capacitors in series and that the voltage across Cs is equal to the sum of the potential differences across each capacitor.
2. Relevant equations
1/Cs=(1/C1)+(1/C2)
3. The attempt at a solution
not sure how to approach this
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jan21-13, 03:07 AM   #2
If they are all in series what does that say about the current?
What is the definition of current?
Jan21-13, 07:57 AM   #3
I tried to work it out and i was wondering if this was the correct way to show wht the question is asking for
q1=C1V and q2=C2V
q=q1+q2=(C1+C2)V
CsV=q=(C1+C2)V
Cs=C1+C2
Jan21-13, 08:32 AM   #4
mfb
Mentor
Capacitor Equation
Quote by maulucci View Post
q1=C1V and q2=C2V
q=q1+q2=(C1+C2)V
CsV=q=(C1+C2)V
Cs=C1+C2
This would apply to parallel capacitors, but not to capacitors in series.
The approach CWatters suggested gives you the correct equations for the charge.
Jan21-13, 08:33 AM   #5
Recognitions:
Homework Helper Homework Help
q1=C1V and q2=C2V
q=q1+q2=(C1+C2)V <----
CsV=q=(C1+C2)V
Cs=C1+C2
It is a series circuit, and as the problem states, "...the same charge separation q is present across the capacitor and each of the capacitors". But writing q = q1 + q2 not only assumes that the charges are different, but that the current can be different in different components of a series circuit!
First you should argue why the charge separation should be the same on both capacitors. Then you can use that fact and the q = C*V relationship to work out the rest.
{Note: If you happen to have a knowledge of calculus you could write the KVL equation for the circuit (Integral version) and answer all the questions of the problem from its characteristics}
Jan21-13, 09:11 AM   #6
To show that they are equal charges q1=q2
And
q=Cs^-1V
q=(C1^-1+C2^-1)V
(C1^-1+C2^-1)V=Cs^-1V
Cs^-1=C1^-1+C2^-1
Jan21-13, 09:14 AM   #7
mfb
Mentor
You did not show it, you just assumed it.
q=Cs^-1V
Why ^(-1)?
q=(C1^-1+C2^-1)V
How did you get that?
Your solution will need V1, V2 in some way...
Jan21-13, 10:03 AM   #8
Ok
V=q/C
V=V1+V2
q/C=q/C1+q/C2
C^-1=C1^-1+C2^-1
Jan21-13, 10:48 AM   #9
mfb
Mentor
That is correct. You can argue that q1=q2 to satisfy charge conservation, or something similar.
Jan21-13, 11:38 AM   #10
Ok thank you
New Reply
Thread Tools
Similar Threads for: Capacitor Equation
Thread Forum Replies
Discharging capacitor, the differential equation Introductory Physics Homework 4
Derive equation for voltage across a capacitor Introductory Physics Homework 5
Help me solve this differential equation (Capacitor Charging) Calculus & Beyond Homework 1
Capacitor breakdown equation... High Energy, Nuclear, Particle Physics 0
Equation for dissipation of a capacitor Electrical Engineering 13
