People and earth pull on each other, so why do people fall?
In summary, Daniel's weight is 800 Newtons. According to Newton's Third Law, if the Earth pulls on Daniel with a force of 800 Newtons, then Daniel pulls on Earth with a force of 800 Newtons in the opposite direction. However, Daniel's mass is much smaller, so the force of 800 Newtons causes his acceleration to be considerably higher than the earth's, so much as to make him fall down.
Taharok
Daniel's weight is 800 Newtons. According to Newton's Third Law, if the Earth pulls on Daniel with a force of 800 Newtons, then Daniel pulls on Earth with a force of 800 Newtons in the opposite direction. Why then is Daniel able to trip and fall down to the ground?
None
Well, I've been stuck on this for a while now. I remember learning something about this with a leaf falling, but I can't remember/find it anymore.
I do have one theory, however. Even though I said there are no relevant equations, I believe I can use Newton's Second Law (F = ma) to figure out this problem. I need to rearrange this equation to solve for acceleration, as so: a = F / m. If force F is the same for both the Earth and for Daniel, then the only changing variable is m. The Earth has an extremely higher mass than Daniel, so the acceleration for the small force of 800 Newtons is so small, it's nearly nonexistent. However, Daniel's mass is much smaller, so the force of 800 Newtons causes his acceleration to be considerably higher than the earth's, so much as to make him fall down.
I think you've got the right idea.
But I wonder about the wording of the question. Intuitively, why would Daniel not fall down? i.e. Why would the mutual attraction of Earth and boy adversely affect his movement toward the Earth upon tripping?
Your reasoning is right. If Daniel trips, he falls towards the Earth with a noticeable acceleration. Although the Earth DOES move up towards Daniel, its acceleration when it does that is so tiny that you can't tell it's happening.
Luckily, or I would be bouncing up and down and the solar system would probably get disrupted every time someone in Australia (hey guys!) jumps up and down or someone takes an elevator from the basement to the 20th floor.
PS Taharok, it might be "fun" for you to actually calculate the acceleration of the Earth due to Daniel falling, and its (relative) change in velocity if this fall took, say, half a second. :)
What is the concept of gravity?
The concept of gravity is a fundamental force of attraction between two objects with mass. The larger the mass of an object, the stronger its gravitational pull.
Why do people fall towards the earth?
People fall towards the earth because the earth has a much larger mass and therefore a stronger gravitational pull compared to the mass of a person. This force of attraction between the earth and the person causes the person to accelerate towards the ground.
Can people fall towards other objects besides the earth?
Yes, people can fall towards other objects besides the earth. The force of gravity exists between any two objects with mass, so if there is another object with a large enough mass, a person could fall towards it.
Why do people fall at the same rate, regardless of their mass?
This is because the force of gravity is proportional to the mass of an object, but the acceleration due to gravity is not. This means that although the force on a heavier object is greater, it requires more force to accelerate it at the same rate as a lighter object. Therefore, all objects, regardless of their mass, accelerate towards the earth at the same rate.
Can people ever stop falling?
Yes, people can stop falling when an equal and opposite force is applied to counteract the force of gravity. This is known as the normal force, which is the force exerted by the surface the person is standing on. When the normal force is equal to the force of gravity, the person is no longer accelerating and is considered to be at rest.
