Tropical latitudes have remained relatively undisturbed
  • Thread starter Swetasuria
In summary: Is that what you're saying?In summary, the tropics have remained relatively undisturbed for millions of years, which gives enough time for species diversification. However, there is skepticism about the time and area hypothesis, which suggests that tropical climates are older and historically larger, allowing more opportunity for diversification. The three mechanisms proposed to explain the latitudinal gradient of diversity- ecological, historical, and evolutionary- all suggest that dispersal is a significant factor in the rate of diversity.
Swetasuria
48
"Tropical latitudes have remained relatively undisturbed for millions of years. Undisturbance gives enough time for species diversification." I read this in my school textbook.
For diversification, shouldn't there be evolution and speciation. And for that shoudn't there be some disturbance. If there isn't any disturbance how will that support species diversification.
Biology news on Phys.org
Speciation usally is referenced with selective pressures...so it would seem the term undisturbance in a literal sense is inaccurate. "Undisturbance" may be dialect in evolutionary biology I have not heard of though.
Here is the time and area hypothesis. The tropics are older and more stable, so there is more time for new species to evolve. This is the hypothesis that you and I are skeptical of. However, our skepticism doesn’t guarantee that it is wrong.
http://www.ncbi.nlm.nih.gov/pubmed/17355570
“A latitudinal gradient in biodiversity has existed since before the time of the dinosaurs, yet how and why this gradient arose remains unresolved. Here we review two major hypotheses for the origin of the latitudinal diversity gradient. The time and area hypothesis holds that tropical climates are older and historically larger, allowing more opportunity for diversification.”
Here is someone who thinks dispersal is the big reason for the rate of diversity. The organisms don’t evolve quicker in the tropics, or go extinct faster at the poles. Organisms just migrate to the tropics. I doubt it, but who know?
http://wolfweb.unr.edu/~ldyer/classes/arita.pdf
“If speciation and extinction patterns alone cannot fully explain the latitudinal gradient of diversity, dispersal must play a significant role (Goldberg et al. 2005; Jablonski et al.
2006; Roy & Goldberg 2007). The stochastic model generates processes that are contrary to those proposed by the _out of the tropics_ hypothesis, which postulates a
tropical origin for most clades, with a net dispersal to temperate areas (Jablonski et al. 2006). In our simulations, dispersal into the tropics can by itself generate the latitudinal
gradient of diversity, as a consequence of the mid-domain effect (Fig. 2b). Stochastic dispersal, combined with random processes of speciation and extinction, generate strong
latitudinal gradients of diversity (Fig. 4) and particular patterns for surviving species (Figs 6 and 7). Only a small proportion of species originating in the tropics disperse to
extratropical areas, and in fact a very high percentage go extinct within the tropical band (Fig. 5b).”
This link lists three types of mechanisms related to the diversification in the tropics.
http://www.bio.puc.cl/caseb/pdf/prog4/Rivadeneira%20et%20al%20GEB%202011.pdf
While there is an ongoing debate about the underlying mechanisms driving the LGR (Rohde, 1999;Willig et al., 2003), there is growing recognition that ultimately the richness in a region should be determined by a balance between the rates of
extinction, migration (i.e. range dynamics) and origination of species (Wiens & Donoghue, 2004;Mittelbach et al., 2007). This balance can be achieved by different mechanisms that can be broadly classified into three types of hypotheses, as proposed by a recent synthesis (Mittelbach et al., 2007): ecological, historical and evolutionary. Ecological hypotheses suggest that tropical areas harbour greater species richness due to environmental
effects enhancing productivity, carrying capacity or niche breadth (Currie, 1991; Rosenzweig, 1995; Evans et al., 2005). Historical explanations (also referred to as biogeographical; Mittelbach et al., 2007) invoke the tropics as sources of evolutionary novelties (i.e. clades originated in the tropics, but overall
diversification rates are not variable across latitude) and that the LGR is the result of a limited dispersal towards the temperate zones (Wiens & Donoghue, 2004; Wiens & Graham, 2005; Jablonski et al., 2006). Finally, evolutionary hypotheses suggest that the LGR is the result of a latitudinal variation in the diversification rates (although novelties appear evenly across latitude),
with higher speciation and/or lower extinction rates in the tropics (Evans et al., 2005; Weir & Schluter, 2007). Despite the differences between historical and evolutionary hypotheses, they both highlight the importance of long-term dynamics explaining the LGR, so we will refer to both of them as historical/evolutionary hypotheses.
I don't think time and area model can be correct. As you said, disturbance should lead to more diversification. However, there are other theories.
As I understand it, the rate of speciation increases the closer one gets to the equator. However, there often seem to be an increase in individuals of any given species as one approaches the poles. Paleontologists and other biologists can determine these correlations, but can't yet figure out a cause.
As an armchair biologist, allow me to speculate why the correlation.
Maybe the increase in speciation toward the equator is due to the direct sunlight.
Direct sunlight stimulates the growth of plants. There are fewer seasons near the equator, so the sunlight doesn't change that much during the year. However, there is geographical variation due to the attenuation of sunlight in the ocean and the tree canopy's on land. So the plants have to adapt to all these solar environments. Animals differentiate to take advantage of the differentiating plants.
The tropics are warmer. Oxygen is less soluble in warm water. So animals are competing for oxygen in the tropical regions. The variation in oxygen levels may speed up diversification of animals.
I think the number of individuals is often limited by the amount of oxygen available in the water. The solubility of oxygen in water decreases with temperature. So animals in the water have less oxygen to live on near the equator. So there are fewer individuals on the equator, but more species.
At the poles, there is less direct sunlight. However, plants hibernate during the winter because it is also cold. So there is less differentiation between plants.
There is more oxygen in the water. The animals don't have to compete as much for oxygen.
just speculating, but there does not seem to be much diversification of large fauna at the tropics - in rainforests there are few large animals relative to temperate regions, but there is a huge diversity of smaller animals, who are often extremely specialized, which the age and stability of the climate would tend to favor
I would like to clarify that while it is true that disturbance can lead to speciation and evolution, it is not the only factor that contributes to species diversification. In fact, tropical latitudes have a high level of biodiversity, with a large number of species coexisting in a relatively undisturbed environment. This is due to the constant and stable environmental conditions found in these regions, providing a wide range of niches for different species to evolve and adapt to. Additionally, the long periods of undisturbance allow for gradual changes and adaptations to occur over time, leading to the development of new species.
Furthermore, it is important to note that disturbance can also have negative effects on species diversification, such as causing extinction events or disrupting established ecosystems. So while some level of disturbance may be necessary for evolution and speciation, it is not the only factor and must be balanced with undisturbed periods for a diverse and stable ecosystem to thrive.
In summary, while disturbance can play a role in species diversification, it is not the sole factor and the relatively undisturbed tropical latitudes have provided a unique and stable environment for diverse species to evolve and coexist over millions of years.
1. What does it mean when it is said that tropical latitudes have remained relatively undisturbed?
When tropical latitudes are referred to as being undisturbed, it means that there has been minimal human interference or disruption to the natural ecosystems and habitats in these regions. This includes both human development and activities such as deforestation, agriculture, and urbanization, as well as natural disturbances such as wildfires and hurricanes.
2. Why is it important for tropical latitudes to remain undisturbed?
Tropical latitudes are home to some of the most diverse and unique ecosystems on the planet, including rainforests, coral reefs, and mangroves. These ecosystems provide essential services such as carbon storage, water filtration, and habitat for countless species. It is crucial for these regions to remain undisturbed to maintain their ecological balance and preserve biodiversity.
3. Have tropical latitudes always been undisturbed?
No, unfortunately, tropical latitudes have not always been undisturbed. Human activities such as deforestation and land-use change have been occurring in these regions for centuries, but have significantly increased in the past few decades with the growth of global trade and development. This has resulted in the loss and degradation of many tropical ecosystems.
4. What are the potential consequences of disturbing tropical latitudes?
The consequences of disturbing tropical latitudes can be severe and far-reaching. Deforestation and land-use change can lead to loss of habitat and extinction of species, as well as contribute to climate change. Development and urbanization can also lead to pollution and environmental degradation, impacting both human and animal communities. Furthermore, disturbing tropical latitudes can disrupt the delicate balance of these ecosystems, leading to cascading effects on their functioning and resilience.
5. What can be done to protect and preserve the undisturbed nature of tropical latitudes?
Protecting and preserving the undisturbed nature of tropical latitudes requires a multi-faceted approach. This includes implementing sustainable land-use practices, promoting conservation and restoration efforts, and supporting local communities in their efforts to live in harmony with their natural surroundings. Additionally, policies and regulations must be put in place to limit destructive activities and promote responsible development in these regions. Ultimately, it will take a global effort to ensure the long-term protection of tropical latitudes and their invaluable ecosystems.
  • Biology and Medical
  • Science Fiction and Fantasy Media
  • Astronomy and Astrophysics
