Evaporation of gold circuit
In summary, you need an adhesion layer between gold and copper oxide to prevent lift-off. Silicon-oxide can be evaporated to create this layer, but it's not a trivial matter. Titanium can also be used as an adhesion layer.
Erikve
Dear all,
I have a quite easy plan: W want to evaporate a gold circuit on a Brass plate. Between this copper and gold I need to make an isolating layer to prevent short-currents. i thought to make this layer of Silicon-oxide. Is the possible to evaporate and what source can I use this for best?
PS. I know that between the gold and SiO2 should be a small layer of Titanium.
This is not a trivial matter, unfortunately. The whole reason you need an adhesion layer is to prevent lattice and/or temperature coefficient mismatch from causing your films to lift-off of whatever you're trying to deposit it onto. Will amorphous SiO2 stick to bronze? How about if you used a chrome or titanium adhesion layer? For thin layers, the following discussion may help:
http://www.finishing.com/368/90.shtml
How thick of gold are we talking about here? Could you use a flex PCB instead?
EDIT: You can evaporate SiO2 (pretty much stochiometricaly) or sputter, or CVD it. With varying levels of built-in stress.
Okay, we are talking about brass (copper+small amount of zinc), I cannot replace this component. In principle the isolating layer could be everything, if you have better idea, please tell me!
Titanium I normaly use as adhesion layer of the gold, so maybe this can be used indeed also on the copper.
Erikve said:
Dear all,
I've personally found that evaporated silicon dioxide (really SiO2-x; it's not at all stoichiometric) is pinhole-filled and a poor insulator (base evaporation pressure of 10-7 torr). PECVD oxide is better, but for you it depends on the brass having micron-level smoothness and no defects, or the oxide won't coat it suitably. How about an low-outgassing resin or other polymer coating that might be sprayed on to the brass and then evaporated upon?
An adhesion layer is needed because gold doesn't form a chemical bond with copper oxide or zinc oxide.
I think it's possible to get near stoichiometric with enough process tuning / e-beam evaporation; no idea of how porous / non-insulating the resulting film would be. To the OP: if someone else at your university / microfab has this figured out, great! If not, you probably want to go with something else. Again, a flex PCB may be ideal, assuming it suits your purposes. If you can put tapped holes in your bronze thing, that'd be even better.
I suppose that (good) bonding with lattice / thermal coefficient mismatch would cause warping / fracturing of the materials in question, rather than having a deposited film pop off.
MATLABdude said:
I think it's possible to get near stoichiometric with enough process tuning / e-beam evaporation; no idea of how porous / non-insulating the resulting film would be. To the OP: if someone else at your university / microfab has this figured out, great! .
E-beam evaporated SiO2 is essentially an amorphous mess with lots of defects and pin-holes (and SiO2 regardless of evaporation method is never a good dielectric, there are lots of two-level fluctuators etc).
Whether or not SiO2 (or anything else) would be good enough really depends on the requirements. What kind of resistance do you need?
Also, are there any requirements when it comes to dielectric constant/loss tangent?
This gold circuit will serve as a calibration coil on a capacitive moving plate. So in principle I want as less as possible loss between coil and plate, the same for dielectric loss, since this influence the capacitive value. Best would be if I have totally isolated surface between copper plate and golden coil.
is there not something more easy chemical coating where I do not have problems with pin holes in the surface?
1. What is the process of evaporation of gold circuit?
The process of evaporation of gold circuit involves heating a gold circuit to a high temperature, causing the gold to melt and evaporate into a vapor. The vapor is then deposited onto a substrate, forming a thin film of gold.
2. What is the purpose of evaporation of gold circuit?
The purpose of evaporation of gold circuit is to create a thin film of gold on a substrate, which can be used in various electronic and optical applications such as microchips, sensors, and solar cells. It also allows for precise control of the thickness and purity of the gold film.
3. What are the factors that affect the evaporation of gold circuit?
The factors that affect the evaporation of gold circuit include temperature, pressure, rate of evaporation, and the properties of the substrate. High temperature and low pressure can increase the rate of evaporation, while the properties of the substrate can affect the adhesion and quality of the deposited gold film.
4. What are the advantages of evaporation of gold circuit compared to other deposition methods?
Some advantages of evaporation of gold circuit include the ability to deposit high purity gold films, precise control of film thickness, and the ability to deposit on a wide range of substrates. It also does not require complex equipment and can be easily scaled up for mass production.
5. Are there any potential drawbacks to evaporation of gold circuit?
One potential drawback of evaporation of gold circuit is the high cost of equipment and materials. It also requires a controlled environment and skilled operators to ensure uniform and high-quality deposition. Additionally, the process may not be suitable for certain complex substrate geometries or sensitive materials.
  • Atomic and Condensed Matter
  • Materials and Chemical Engineering
11K
