3D Graphene foam from glucose by chemical blowing
In summary, the author has found a method for producing 3D graphene foam, but is facing difficulties with two issues. The first issue is that the pressure needed for the synthesis is not specific, and the second issue is that the conversion of glucose to meldonin and melanoidin is done in ambient conditions. Additionally, the author has emailed Dr. Yoshio Bando but has not received a response.
trujafar
I'm a third year physics undergraduate and I want to make 3D Graphene - without spending a fortune.
This is my background:
I found this review article by Jiang and Fan (Design of advanced porous graphene materials: from graphene nanomesh to 3D architectures) to be very helpful. From what I've understood, the main methods are hydrothermal and CVD. CVD involves using nickel foam, and at $250 a sheet Marketech Intl, Inc. - Nickel Foam is a no-no. However, hydrothermal methods such as this one Porous 3D graphene-based bulk materials with exceptional high surface area and excellent conductivity for supercapacitors which use graphene oxide and surcose seems more promising.
In line with this, I've done research on graphene oxide (a precurser to many graphene-based products), and have read about the Hummer's method, the Improved Hummer's Method (http://pubs.acs.org/doi/abs/10.1021/nn1006368) and have also watched Robert Murray-Smith's videos (www.youtube.com/user/RobertMurraySmit[/URL]).
Now for my question:
I read this article [URL="http://www.nature.com/ncomms/2013/131216/ncomms3905/full/ncomms3905.html"]Three-dimensional strutted graphene grown by substrate-free sugar blowing for high-power-density supercapacitors[/URL] which has a seemingly simple and interesting method for synthesis of 3D graphene foam, which I would very much like to make. But upon reading the article, I'm facing a couple of problems:
1) In the Methods section of the paper use argon gas is used for the ambient gas in the tube furnace. Under what pressure does this take place? Does it have to be a tube furnace, or will any other furnace with programmable temperature work?
2) Is the glucose mixed directly with amonnium salt, or is it dispersed in a solution?
3) In the diagram, glucose is converted to meldonin at ~250C, then it is heated to ~1350C. Is the melanoidin conversion carried out in ambient conditions, and then the sample cooled to room temprature, or is this a one step process? What exactly happens? Can I carry this out in lower temprature, say ~ 900C at the cost of lower quality?
[URL]http://www.nature.com/ncomms/2013/131216/ncomms3905/images/ncomms3905-f4.jpg
I've sent a email to Dr Yoshio Bando a couple of days ago, but I haven't yet got an answer. I'm worried that I wasn't very polite.
I'm sorry you are not generating any responses at the moment. Is there any additional information you can share with us? Any new findings?
The pressure is 1 atm. There is nothing special about a tube furnace, but the fact that it is easy to create a specified atmosphere. This is really important since for the pyrolosis of carbon to take place, an inert gas is needed, otherwise the glucose will burn. According to their paper, 4C/min is the optimal temprature ramp for strutted graphene production.
Both are in solid form, and the solid white glucose powder is directly mixed with the amonnium salt in a 1:1 ratio in weight.
The shown diagram states that in the while it is being heated to 1350C, glucose is converted to meladonin, and then graphene. However, as far as the experimental procedure needs to cencern itself, it is a one-step process. What exactly happens is not known. At a lower temprature, to quote directly from Dr Wang "will be something similar to strutted graphene, just with a lower crystalline degree, lower conductance and lower specific surface area."
My understanding of the above is thanks to Dr Xuebin Wang. Any errors are due to misunderstanding on my part.
so regarding 2), do you mix glucose and ammonium salts in solid form and bring them to 200 deg 4deg/min to form the foam, and that is done at room atmosphere?
Would you get a brown "caramel" foam or a white glucose form? at around 160 deg glucose start caramelizing.
any recipes to get white glucose foams?
The synthesis of the grapheme foam is a one-step process from room temperature to 1350C with a temperature step of about 5C/min.
It is important that it is performed in a inert atmosphere. A tube furnace is generally used for these purposes.
However, the heating element, tube material and thermocouple will limit the maximum temperature that you can go up to. Due to these limitations, I was only able to go up to 1000C. Below is the sample.
I'd suggest that you would take a look at Dr Wang's recent papers. He has further optimized and examined the bubbling process. Of particular interest is his paper titled "High-throughput fabrication of strutted graphene by ammonium-assisted chemical blowing for high-performance supercapacitors". Study the section titled "Growth process of ammonium-assisted chemical blowing for SG". It will give you a greater insight into the process.
  • jiang2015.pdf
1. What is 3D Graphene foam?
3D Graphene foam is a porous, lightweight material made from graphene, a type of carbon with a unique 2D structure. It has a high surface area and excellent mechanical, thermal, and electrical properties, making it useful in a variety of applications.
2. How is 3D Graphene foam made from glucose?
The process of creating 3D Graphene foam from glucose involves a technique called chemical blowing. Glucose, a type of sugar, is mixed with a strong acid and heated. This causes the sugar molecules to break down and release carbon atoms, which then form into graphene sheets. These sheets are then stacked and compressed to create the 3D foam structure.
3. What are the advantages of using glucose to make 3D Graphene foam?
Using glucose as a starting material for 3D Graphene foam has several advantages. It is a renewable resource, making it more environmentally friendly than using fossil fuels. It is also less expensive and easier to obtain than other carbon sources, such as graphite. Additionally, glucose-based foams have been found to have better mechanical properties compared to foams made from other materials.
4. What are the potential applications of 3D Graphene foam?
3D Graphene foam has a wide range of potential applications due to its unique properties. It can be used in energy storage devices, such as batteries and supercapacitors, as well as in electronic devices, such as sensors and transistors. It also has potential uses in water purification, catalysis, and as a lightweight and strong material for construction.
5. Are there any challenges in producing 3D Graphene foam from glucose?
While using glucose to make 3D Graphene foam has many advantages, there are also some challenges to consider. The process is still in its early stages of development, so there is still room for improvement in terms of efficiency and scalability. Additionally, the quality and properties of the foam can be affected by factors such as the purity of the starting materials and the specific chemical conditions used in the process.
