A Question about Torque Used for Static Equilibrium
In summary, for the problem of the diving board in static equilibrium, the forces are analyzed using the formula ∑τ = F(normal from the support)*1.00m + ( - F(diver)*3.00m) + ( - F(diving board)*1.50m(center of mass)) = 0. This is because the diving board is not undergoing rotational acceleration and is restrained from rotating. The use of ∑τ(z) = I(cm)*α(z) is reserved for bodies undergoing rotational acceleration. The equivalence principle of acceleration and force does not apply in this case.
student34
639
A diving board 3.00m long is held down at the left end and is supported underneath at a point 1.00m to the right of the hold. A diver weighing 500N stands at the other end. The diving board is of uniform cross section and weighs 280N. Find (a) the force at the support point, and (b) the force at the left-hand side (the hold).
From the hold, ∑τ = 0
I know that the answers are 1920N and 1140N respectively. I think that we are suppose to use the formula, (refering from the hold)
∑τ = Fn*1.00m - 500N*3.00m - 280N*1.50m = 0
Fn = (500N*3.00m + 280N*1.50m)/1.00m = 1920N
So my issue is that we were taught the chapter before to use ∑τ(z) = I(cm)*α(z) for rigid bodies with uniform mass density. So why don't they use I(cm)*α(z) for the diving board, where α(z)= g/r ? This of course gives a much different answer.
I checked similar problems like this from other sources, and they don't use I(cm)*α(z) either.
Because the diving board is 'held down' in static equilibrium. ∑τ(z) = I(cm)*α(z) is used for bodies undergoing rotational acceleration, which is clearly not the case here.
Yes, but I thought that Einstein's equivalence principle implies that acceleration is equivalent to force. For example, I thought that a body accelerating at 9.81 m/s^2 in space is equivalent to the body on Earth at rest.
If that is true, then how is the force of g on all particles of the diving board different than angular acceleration of a moving diving board driven by the support force?
The diving board may deflect locally under the action of the forces applied to it (i.e., the board is not a perfectly rigid body), but it is not able to rotate bodily since it is restrained from doing so. This is a simple problem in statics: there is no need to drag Einstein into it.
N.B.: a body accelerating at 9.81 m/s^2 in space is an example of rectilinear, not rotational, motion. You analyze rectilinear motion using different equations than those for analyzing rotational motion. The equations for the two types of motion may be analogous, but they are not the same.
Likes 1 person
It is correct that the formula for torque, ∑τ = I(cm)*α(z), can be used for rigid bodies with uniform mass density. However, in this specific problem, we are dealing with static equilibrium, which means that the diving board is not rotating or moving. Therefore, the sum of torques must be equal to zero, as stated in ∑τ = 0. This means that the diving board is in a state of equilibrium, with no net torque acting on it.
In this case, the diving board is being held down at the left end and supported underneath at a point 1.00m to the right of the hold. This creates a lever arm of 1.00m for the force at the support point, and a lever arm of 3.00m for the force at the left-hand side (the hold). By using the formula ∑τ = F*1.00m - 500N*3.00m - 280N*1.50m = 0, we can find the forces at each point, which are 1920N and 1140N respectively.
In summary, when dealing with static equilibrium problems, the sum of torques must be equal to zero, and the formula ∑τ = I(cm)*α(z) is not applicable. We must use the formula ∑τ = 0 and consider the lever arms of the forces acting on the object.
1. What is torque and how is it related to static equilibrium?
Torque is a measure of the rotational force applied to an object. In the context of static equilibrium, it is the force that causes an object to remain stationary and balanced. This means that the net torque acting on the object must be equal to zero.
2. How do you calculate torque?
Torque is calculated by multiplying the force applied to an object by the distance from the axis of rotation. This can be represented by the formula: T = F x d, where T is torque, F is force, and d is distance.
3. What is the principle of moments in static equilibrium?
The principle of moments states that for an object to be in static equilibrium, the sum of all clockwise moments must be equal to the sum of all counterclockwise moments. This ensures that the net torque acting on the object is zero.
4. How is torque used to determine the center of mass of an object?
The center of mass of an object is the point at which the object is perfectly balanced. To determine this point, torque can be used by hanging the object from different points and finding the point at which it remains stationary. This point is the center of mass.
5. What factors can affect the stability of an object in static equilibrium?
The stability of an object in static equilibrium can be affected by the weight and distribution of the object, the surface it is resting on, and any external forces acting on the object. A wider base, lower center of mass, and evenly distributed weight can increase the stability of an object.
