Nano-amp amplifier - 1nA to 1V
  • Thread starter Wapochief
  • Tags
    Amplifier
In summary: V noise on the input, this is not good.In summary, you have two problems with your amplifier. First, it has too much bias current and secondly, the noise is too high. A low value capacitor across the feedback resistor will limit the band width to 1kHz.
Wapochief
27
Hi Guys and Gals,
I am trying to linearly amplify a 1nA-10nA current to 1V-10V. I need at least 10KHz bandwidth. I have tried using a 3 stage amplification (negative feedback) system using an lt1012 op-amp (1 nA to 1mv, then 100,10 gain), but the noise is very high (-30/40 db). I need at least -50 db.
I have built the circuit with surface mount components on PCB, with a ground plane and enclosed in a grounded metal box. I have voltage regulators, as well as capacitors to reduce supply voltage noise.
Another strange thing is that the gain increases (yes, increases!) with frequency, and I expected the gain to be flat and then roll off as frequency increased. The real world behavior of this circuit in no way matches any of the simulations I have done.
Is there any other way to amplify that small of a current with low noise? I have found transimpedance amplifiers, but they are for uA up.
Thanks,
Wapo
You have two problems. First, for 1nA to 10nA range, your amplifier has too much bias current at 100pA. Here is two that I find from a few minutes of checking. You might find much better. You want max of 1pA input bias current.
http://cds.linear.com/docs/Datasheet/1052fa.pdf
http://cds.linear.com/docs/Datasheet/146465f.pdf
Second You don't want to use too many stages as noise is dominated by the first stage. If you follow the first stage with a gain of 1000 in your case, you multiply the noise of the first stage by 1000. That's the reason you see a lot of noise. I designed a lot of transimpedance amp like this kind even much lower current. Go look up information in transimpedance amp. For 1V/nA, you need a transimpedance resistor of 1GΩ.
10KHz is not high frequency for this kind of amp. You can do the first stage using 100KΩ feedback resistor, then a gain of 10 on the next stage. For 10KHz, I personally would even try using a 1GΩ resistor and do it in one stage. Make sure you put a small cap across the said feedback resistor, do calculation so the C=1/[2∏Rf] where R is the feedback resistor and f is say a little above 10KHz.
This design will give 100mV/nA on the first stage. You'll find noise going to be a lot lower. If you need any more detail, post back. Don't be afraid to use big resistor. Only precaution is make sure you clean the board really well as a little dirt residue will have enough leakage to cause error. But reading 1nA is not pushing in any sense. If you need suggestion, I can even draw one or two circuit for you.
Thanks for the reply. I agree with what you are saying, but I am worried that stray capacitance will limit the band width, especially with the 1Gohm resistor. Under simulation and according to your equation, a low value capacitor (a couple of pf) across the 1Gohm resistor will limit the band width to 1kHz. That is why I chose multiple stages with lower gain. Do you think that will be a problem?
I don't know what is the input device. I did a lot of photo detector that has capacitance. This will cause a poll at the input and raise the noise and cause instability. You have to tell me what is the input to determine. Usually the small feedback cap is for lowering the noise. As I said, put a cap that give you a little over 10KHz. When making small cap, I use those wire wrap wires and solder on both side of the resistor, I then twist the two together to form a cap, twist tighter to get more cap and looser to get less!. Or you can get even smaller cap. Those day, I also use Johanson(spelling) adjustable cap that you can get sub pF adjustable caps.
BUT, I thought we are talking about 100K for first stage and gain of 10 at the second. This will already improve the noise drastically. My original suggestion is using two stages, but I put as much transimpedance gain as possible on the first stage. You don't need three stages, two stages are plenty. I only did two stages for measuring sub pA!
Make sure you look for another amp, what you have don't cut it. the bias current is over 50 or 100pA, you introduce 5 to 10% error by default!
Thanks again,
The input impedance is about 1Gohm/200pf. I need 1nA input, 1 Volt out. Thats a gain of 10^9. So I would need a 100M and a 10. (is that a typo above?)
Just ran some numbers and the lt1052/lt1464 won't cut it. The gain rolls off around 2KHz with a 1pf cap and 100Mohm. 0.5pf just gets 10Khz, but won't the board have more capacitance than that?
I can't seem to find a op-amp that has high enough bandwidth/gain and low input base current.
Wapochief said:
Thanks again,
How do you get your numbers? I did the calculation for you below.
The amp has plenty of bandwidth. You are limited by the input capacitance. For two stage with first stage feedback resistor of 100K, the feedback cap that give zero frequency at 12KHz is C=1/[2πRf] = 132pF where R=`100KΩ and f =12KHz. So for 1GΩ feedback resistor, the cap is 1/10 which is 13pF. I don't know how you get 2pF.
The 1GΩ input resistance is not important. The 200pF input capacitance to the ground is the gating factor as when frequency going up, the reactance goes down and your closed loop gain of the first stage goes up as 100K divided by the reactance of the 200pF input capacitance. At 12KHz, the reactance of the 200pF is Z=1/[2πfC]=-j66.4KΩ. So your noise gain using a 132pF would be about the real number of (100-100j) divided by j66.4. It is not too bad. The total noise gain is 10 times as you have a gain of 10 following. That's the reason you try to avoid high gain in the following stage after the transimpedance amp.
If you use the 1GΩ feedback resistor and 13.2pF cap, the noise gain is 10 times less.
You should read up how to get the noise gain of transimpedance amp. I think you have plenty of BW using those amps. You might find a lower noise amp though as I only spent 2 minutes on DigiKey to look for it. The amp has never been a factor, it is the feedback cap that limit the BW. But you need the feedback cap to limit the noise gain as I explained in detail above. You might want to look for a lower voltage noise amp or even lower bias current op-amp. Your requirement is not high, you should be able to find something good.
It is a dance between BW vs acceptable noise. What I calculated for you is BW of 12KHz, it should be better than your requirement.
1Gohm. = 10^9
100Kohm = 10^5
1Mohm = 10^6
I think you are mistaking Gohm for Mohm
Using 100Mohm I calculate a 0.132 pF cap at 12 KHz. I don't see how to control this small of a capacitance.
I have since read about how noise with amplifiers works - subsequent stages amplify the noise of the first stage, and the subsequent stages insert noise to some degree, but I still can't figure out how to get the gain and bandwidth I need with only 1 or 2 stages.
thanks for your help,
Wapo
Wapochief said:
1Gohm. = 10^9
100Kohm = 10^5
1Mohm = 10^6
Excuse me, you are right.
For 100M follow by gain of 10, you use a 1.2pF and it will be close to my original calculation. The noise gain from calculation is a lot higher, but that's life. It is going to be a lot lower than your original 3 stages with post gain of 1000. With 100M tranimpedance, post gain is 10 so the noise is 100 times less. If you use 1G, you have to use 0.13pF. I think you might be able to find a Johanson tweek cap that go this low. Theory of the post before still stands, I just make the mistake from M to K! It's only 1:1000 error!:rofl:
There's always the option of using wire wrap wire. It work like magic! I even use it on RF amplifiers!
Sorry.
Still a decimal place off :wink:
Have not found 0.13 pf variable caps...so I guess the only option is to make a cap. About making the cap, does it look like this?
Code:
       Wire 1           Wire 2
                R
Then twist the two wires together? Do you use 30 gauge wire?
Would that level of capacitance already be present on the board?
Code:
       Wire 1           Wire 2
                R
Yes, again! I don't know what happened, maybe I was at the same time helping someone in solving grounding problem in a guitar amp and I was bouncing between here and there! Hey compare to 1000:1, this is only 10:1, what's the big deal!:tongue2:
Yes, that's the idea of the cap, I twist the two ends together, the tighter the turn, the more cap. Another way is to twist together, then use a cutter and cut off a little at a time to get the right response! I believe is 30 gauge common wire wrap wires. The capacitance on the board is not across the feedback resistor. You need the cap to control the noise gain and stability for the 200pF input cap.
Wapochief said:
I got 0.13pf for 100Mohm.
What do you think of this op-amp?
http://www.ti.com/product/opa656
Low noise, typically 1-2 pA base current, better gain.
Quick look and it look good. I mainly looking at the low frequency noise and is less than 100nV/√Hz @ 10Hz which is good, also 7nV/√Hz at higher frequency is very good. Be a little careful on the layout as this is 5MHz amp. 2pA is slightly high, but it's not the end of the world. I don't know the production number you are aiming, if it is small run, I would bend the -ve input up in the air and solder the stuff on it. This will prevent flux residue causing leakage. I don't think it's a good idea to use surface mount resistor for the 100M resistor, even 0805 is very short. Unless you can experiment with the surface mount resistor without the cap. Maybe the cap across the body is good enough as the feedback cap! If you have to use surface mount resistor for this, cut a slot on the pcb right under the resistor to open the path of the potential leakage and is easier to clean the under side of the resistor. Flux residue is a big problem for us, we actually had an ultrasonic freon bath for cleaning!
Thanks a bunch yungman. I will keep you posted.
Oh! I take back on what I said about the 100M first stage will have 100 times lower noise as yours. I based on the wrong calculation of the 100K to 100M and concluded the noise gain was low. But with the corrected noise gain. you are not going to see the noise lower by 100 times. It is going to be lower, but you need to do calculation to find out exactly the improvement. With my track record on numbers the last two days, you better do it than me!
Can you point me to a good resource for learning exactly how to calculate the noise?
Here are some articles that I pull up really quick:
http://www.analogzone.com/avt_1204.pdf
http://www.analog.com/static/imported-files/tutorials/MT-050.pdf
The first one is more basic noise model of op-amp, the second is what I am talking about the noise gain due to the input capacitance that cause the noise gain to go up. Youer 200pF is causing the noise gain to go up. If you look back to my post when I made the mistake(yeh yeh yeh!) on the K to M, the noise gain calculation is quite low of like around 2, that's the reason I said the 100M first amp is going to be about 100 time better in noise than yours. Now that we know my mistake ( Again...yeh yeh yeh!) the noise is very high. The advantage is going to be much less because in your case you first stage has a much larger feedback cap and the noise gain is very much reduced in you first stage. But the one with 100M first stage is going to be lower. But you have to really get down and calculate the numbers using the info from the articles as it get tedious.
As you can see, the voltage noise of the amplifier is very important and I think you choose one with very low noise this time so I even let it go on the 2pA input bias current. Also as the noise gain goes up, you need a higher speed op-amp because as you can see from the second article that the closed loop gain got bended up and intersect the open loop graph at much lower frequency. The opamp you chosen is quite fast.
Usually there are articles from op-amp manufacturers. I studied the old PMI application notes at the time.
Keep me inform on the result.
Looks like the large feedback resistors will limit the noise floor...
The key noise equation for our system turns out to be the thermal noise of the resistor.
En_r = sqrt(4*k*temp*req*BW) = Vrms
V = 6 * V rms
Noise rms = (Rf/R1+1) * dominating noise source
k = boltzmans
temp = degrees in k
req = Rfeedback // Rsource
BW = 10kHz
I calculated 181uV rms of noise for the opa656 and a 100Mohm input and feedback resistor. This is about 1mV of noise or a -60dB (voltage) noise floor first stage, 10 mV or -40 dB after the second stage (gain of 10). I need to do better!
Now you are using 100M and gain of 10. The only way to do better is 1GΩ my friend! Then you have to massage the BW and see what you can give. You are getting to the end of the road. The next is to do Nitrogen to lower the temperature as you find the thermal noise dominates! I don't know nitrogen, that's the end of the road for me too!
Sorry.
Here is another link by Skeptic2:
http://www.ti.com/lit/an/sboa061/sboa061.pdf
If you do decided to try 1G, use wires with thicker coating than the wire wrap wire for capacitance, that will lower the capacitance per turn. I don't worry too much about the 1G limiting the speed, it is your 200pF diode impedance that's the killer. Your noise gain is sky high for the speed you want.
That design has a bandwidth of 30Hz. :'( I should have a test setup soon and I'll let you know what goes down.
I think I can lower the resistance noise by using a current divider in the feedback loop. Even then, I'll need a tiny capacitance across the feedback loop.
Can you show me what you mean by current divider?
Are you stuck with the diode detector? Can you find a smaller one or you need the big area diode? 200pF is very high.
You can limit the BW to 30Hz? That would help.
I still need at least 10 kHz...the design you showed me has only 30 Hz bandwidth. I am not using a photodiode...its for a "black box" that I can't change.
I found a way to "trick" the amplifier into thinking the feedback resistor is very large, when in fact it is small. On the output, put a resistive divider to ground. The top resistor is R1, the bottom is R2. Then place a resistor (R3) from the inverting to the middle of the resistive divider. The gain is about R1/R2*R3. You can place the capacitor across R3 to limit the BW.
No, not working, the voltage divider is the same as having gain on the second stage. No difference. Forget this one! Sorry. I was thinking you might have a new trick.
Too bad it's a black box, I was even tempting to suggest making two circuits with smaller diode for detection. Each detect half, you add two, you get back the voltage gain, but the noise is root mean square and is not double. Any possibility of using two transimpedance amp in parallel and sum later?
I don't recall I show you a circuit that only has 30Hz BW! We always talked about the 10KHz and that's where the problem lies. 10KHz and a 200pF input capacitance don't agree!
That would work, but we would need very good linearity. Seems like I would need a LOT of amplifiers to make a difference. The latest link has 30Hz BW.
When you get down to the limit, who said it would be easy. If you can double the signal with 1.41 increase of noise, that's a big gain! If you can do it, don't rule this out. Doing nitrogen is more complicated.
The 100MOhm resistor worked, with the wire wrap I am seeing over 200khz of bandwidth. The noise floor is -70db, and amplifying it by 10 will make it about -50db - not what I need, but close. Overall a good success. Thanks for your help.
I am glad it all work out. The wire wrap wire is nice!
Alan
Any idea where I can get a variable cap that small? (0.1 pf or less) The customer does not like the wire wrap. Couldn't find anything below 0.25 pf and I need around 0.1 pf.
You might have to use one fix and a variable in series. But the question is whether you have any high voltage around?
It is important that there is no high voltage around, If you have two cap in series, the middle floats. In the presence of HV, the open junction will charge up and arc and will burn electronics. This is very important.
If you have HV, you have to use two 50M in series, then you can put cap across each resistor. Now you can use bigger cap. One fixed and one variable....Do you really need a variable cap if you can do the experiment to find the correct value. This value should not change in different amplifiers.
I am not sure how to measure the capacitance, since it is so small... We are using +/-4 and +/-15 volts supply, and the output is only 1v maximum(with 10nA input). I would assume neither is high voltage.
  • #31
  • #32
Have not had a chance to hook this up to the real source, but doing the calculation here:
http://www.analog.com/static/imported-files/tutorials/MT-059.pdf
It does not seem like the 200pf is a big deal. The feedback cap still needs to be very small... 0.0025 pf with a 100Mohm feedback resistor, and a larger feedback cap like we are using only makes it more stable. I think the 500MHz unity gain band width is helping out a lot here.
Edit: Ah I see its the 1+C1/C2 term...
  • #33
0.0025pF is too small, you sneeze on it, it's more than 0.0025pF!
When I said HV, I meant over a few hundred volts, if you only have +/-15V, you are safe.
I am improvising here. If you have the big resistor close the the board, layout so that you put a copper strip that is connected to the output of the op-amp. The strip is placed right underneath the big resistor so it become a capacitor to the big resistor. Then you trim the strip until you get the response. Call me crazy, when you are disparate, you need to think way outside the box....way out! Try using a copper tape as the strip, start trimming and see whether you get the result.
  • #34
I am still not sure how to calculate the effect of source capacitance. I read the MT-050 from Analog Devices, but it still does not make sense. Do you know of any other good resource for this?
  • #35
In MT-059 you posted, look at Fig.1 and equation 1. That explained the noise gain due to C1 with is the input capacitance.
Did you try the copper tape trick to see whether you can get the low capacitance you need?
  • Electrical Engineering
