Question about Neutral Pi-meson and Parity Conservation
  • Thread starter kakarukeys
In summary: So if you want to describe the polarization of a photon, you need to include both the J-current and the parity-conserving transformations... which is why there are initially three polarizations in the state.
kakarukeys
190
I have a question about the neutral Pi-meson.
One of the decay modes of the neutral pi-meson is to 2 photons.
[tex]\pi^0 \rightarrow \gamma + \gamma[/tex]
it seems to me that this electromagnetic process violates parity conservation.
L.H.S. parity is -1.
R.H.S. parity is (-1)(-1) = +1
Is there anything wrong?
No,
The answer is situated in the photon spin and their direction with respect to the photon momentum : check out the bottom of : http://csm.jmu.edu/physics/giovanetti/particlePhysics/parity.htm
Parity IS conserved
regards
marlon
Clue of this story is the fact that in order for the two-photon state to have J = 0 (conservation of J and J=0 for the neutral pi meson because it is a superposition of two quark anti-quark states) we must write it as a superposition of two states A and B. Each state has the two photons with anti-parallel spins and in state A the photonspin is aligned with the photon-momentum, in B photon spin is opposite wrt photon momentum. You can derive these states by using the Clebsch-Gordan coefficients, as is denoted in the text...
A photon has indeed parity -1 but since we are working with a superposition of TWO photonstates, the parity is relative. If you had just a single two-photon state then parity would be -1 * -1 but because of the superposition, it is the parity from state A with respect to state B that determins the actual parity of the entire wavefunction...
regards
marlon
Could one of you please come up with the Feynman diagram...?I have a hunch this process typical SM-type (that is electroweak+quarks).
Daniel.
Daniel.
The Feynman diagram is one page four
http://www.oup.co.uk/pdf/0-19-852913-9.pdf
marlon
Thanks,Marlon.I could have sworn it was a weak process,but it isn't...
Daniel.
Daniel.
So did I...
As a matter of fact the OP asked a very good question and it took me a while to figure it out and find some good resources...
regards
marlon
It definitely took you less than it took me to come up with all sorts of Z,W+-,quarks & photons diagrams...
Daniel.
It is a good question. I took a look at Sakurai's Invariance Principles and Elementary Particles, p. 44-45. The intrinsic parity of the photon is based on the behavior of the polarization vector under parity, and is negative. For the pi0 decay, he says:
"We consider the decay of a spin zero pion at rest into two photons. The final-state wave function must transform like a J=0 system, and it must be linear in each of the two photon polarization vectors. We have two possibilities (even and odd parity):
[tex]
\vec{\epsilon_1} \cdot \vec{\epsilon_2}
[/tex]
or
[tex]
(\vec{\epsilon_1} \times \vec{\epsilon_2} )\cdot k
[/tex]
(k is the unit relative momentum vector of the two-photon system). The first expression is seen to be invariant under P while the second changes sign. In general the final state is expected to be a linear combination of these two forms. If parity is conserved in the decay, however, only one of the two forms is allowed, and we could determine, by measuring the relative orientations of the polarization vectors whether the pi0 is described by a scalar or pseudoscalar field."
Yes, juvenal, and the two formula's that you gave are the only possibilties because they are invariant under the transformations generated by J : ie the rotations
We could also take the tensorproduct of k with one of the polarzation tensors but this option is useless because the longitudinal mode of photons vanishes... only the transverse (two) photon-polarizations remain. In QFT, you can kick out one degree of freedom by imposing a gauge-condition for the A field [tex]\partial^{\mu} A_{\mu} = 0[/tex]
The A field (which is a Lorentz-object with four degrees of freedom) now has three remaining degrees of freedom.
This is very good because spin 1 means that this object will transform as a vector under the 3-D rotation group. The fundamental representations of this group are (3*1)-column matrices with indeed three variables : ie the components.
The reason why there are 'initially', three degrees of freedom for the photon (ie the three polrizations) has to do with the fact that in QFT a photon is described as the excitations of a MASSIVE spin one-meson (denoted by a vectorfield) because this field needs to couple to the vectorcurrent J (this field is disturbed by the J-current which expresses nothing more then the charged particles that will make the spin 1 field vibrate).
The J-current is a Lorentz vector with 4 degrees of freedom (ie the components) but one degree is knocked out because of this equation : [tex]\partial_{\mu} J^{\mu} = 0[/tex] : ie conservation of charge.
This J-current now has three degrees of freedom. Then we let m evolve towards zero and 'hope' things will not get awkward...Well, they do...damn it...In order to solve these problems (the longitudinal polarization will yield a negative expectance value) and Gupta-Bleuler-theory teaches us how to get rid of this third variable : the longitudinal polarization : it will decople from the physics at hand.
marlon
Chapter 13,section 2 of Pokorski's book deals with chiral anomalies linked to [itex] \pi^{0}\rightarrow \gamma+\gamma [/tex] and a computation of the decay rate.
Daniel.
1. What is a Neutral Pi-meson?
A Neutral Pi-meson, also known as a pi-zero particle, is a subatomic particle made up of a quark and an antiquark. It has no charge and a mass approximately equal to that of an electron. It is one of the lightest and most stable mesons.
2. How is a Neutral Pi-meson produced?
A Neutral Pi-meson can be produced in high energy collisions between protons and neutrons, or in the decay of other particles. It can also be created artificially in particle accelerators.
3. What is Parity Conservation?
Parity conservation is a fundamental principle in physics that states that the laws of physics should remain unchanged under a mirror reflection. This means that the properties of a particle should remain the same when its position is reversed.
4. How does Parity Conservation relate to Neutral Pi-meson?
Neutral Pi-mesons are used to test the principle of Parity Conservation, as they are the only mesons that have an equal probability of decaying into two photons or into two electrons. This is because the spin of a Neutral Pi-meson is zero, which means it has no orientation in space and is therefore unaffected by a mirror reflection.
5. Why is Parity Conservation important in the study of subatomic particles?
Parity Conservation is important in the study of subatomic particles because it helps us understand the fundamental symmetries present in the universe. It allows us to predict the behavior of particles and understand the underlying laws of nature. It has also been used to discover new particles, such as the Neutral Pi-meson, and has played a crucial role in the development of modern physics.
  • High Energy, Nuclear, Particle Physics
