- #36
atyy
- 3,374
Andrew Mason said:I am having difficulty understanding how the compression could be isothermal. How does the rapid initial compression (which, it seems to me, has to occur) not increase the temperature of the gas to more than an infinitessimal amount higher than 300K?
It seems to me that the process must involve a rapid compression until Pgas = Pext followed by a slow compression as the heat flows out of the gas to the surroundings.
AM
I'm guessing that there is friction that has some maximum strength (analogous to static friction in classical mechanics). So most of the finite pressure difference simply balances the friction, and the friction is only exceeded by an infinitesimal amount. Because the excess is infinitesimal, the motion is still quasi-static, and because it is in thermal contact with a heat bath, it is isothermal. The irreversibilty is due to friction not changing sign if the external pressure is infinitesimally reversed. For the surroundings, the effect of work done in the forward direction against friction is the same as frictionless work plus reversible heating, since the environment can't "tell the difference" between heat from friction and heat from reversible heating.
There are other forms of irreversible compression which are not quasi-static, and so definitely not isothermal. I think it is only in the quasi-static irreversible case that one can use this trick of replacing irreversible work against friction with frictionless work plus heating.
