- #36
Dale
Mentor
- 35,319
- 13,537
Einstein never mentioned anything about "truly or absolutely synchronized" clocks in the cited material. Furthermore, he never presented a competing method for synchronizing clocks. My original question to you remains completely unanswered:BluMuun said:As Einstein said, the clocks of classical physics were truly or absolutely synchronized, if only on paper. (That's how Einstein's observers got the results c and c - v for light's one-way speed.) http://www.bartleby.com/173/7.html
How would you suggest synchronizing the clocks in your proposed "direct" experiment?
This is a key question. You are surprised that such an experiment has not been done. This is a key part of the experiment, and understanding why may help you understand why the experiment hasn't been done.
That is true but irrelevant and non-responsive. The reference never claimed that ALL theories are indistinguishable from SR, only that there exists "a large class of theories in which the one-way speed of light is anisotropic" with some specified other characteristics and that "these theories ... are experimentally indistinguishable from SR".BluMuun said:I noted that not all theories are indistinguishable from SR
This is important to your question. Think about it a bit. What does the existence of a theory in which the one way speed of light is not c and which is experimentally indistinguishable from SR imply about your desired experiment?
I deleted the rest of your reply because I didn't want my response to it to detract from the rest of the exchange, but since you continued to press the issue I will respond.BluMuun said:and you deleted my reply, which was the fact that Einstein said that a theory that contains the absolutely synchronous clocks of classical physics would yield c variance. (See above site.) Are you saying that Einstein was wrong here?
You must stop misquoting and misattributing statements from Einstein (or anyone else). In the references you have provided Einstein never says what you claim he says. Stop misrepresenting his comments. Such behavior is not tolerated on this forum.
True, but not relevant. Clock synchronization is not part of nature, it is a purely man-made convention.BluMuun said:But nature cannot be forced by man.
Also true but irrelevant. The source independency of the one way speed of light is an experimentally testable fact which does not require clock synchronization. It is a different physical question from the value of the one way speed or its isotropy. The fact that synchronization is not necessary to answer one question in no way implies that synchronization is unnecessary to answer the other.BluMuun said:As Einstein said, it is not coordinates that we are talking about, but the simple law of the constancy of light's speed in space. (See above URL again.) This law is controlled by one fact, the fact of light's source independency, just as Einstein noted (when he mentioned De Sitter).
The bottom line remains the question that I posed to you which you have not answered. You are surprised at the lack of a direct experiment, but you are not the first person to be interested in doing this type of experiment. All those before you abandoned the attempt. Why? Because of this one issue. If you want to resolve your surprise, then you must confront the issue of synchronization, not avoid it.
