New Reply
How can water do this?
Share Thread Thread Tools
Feb20-13, 05:57 PM   #18
I think what you are observing is this:
http://www.youtube.com/watch?v=grUOHeKm19I
This video has more but please ignore everything they say, it is wildly misleading:
http://www.youtube.com/watch?v=W9yWv5dqSKk
They claim it is an air film separating the drop from the water (Probably due to the laminar flow Prandl layer which prevents mixing and slows down air movement)
Feb20-13, 06:51 PM   #19
I have noticed these 'antibubbles' too. I noticed these antibubbles when I was washing dishes. Thinking they might be due to the soap, I tried to reproduce them using normal water. They could be reproduced both using normal water and with a thin film of water on top of a stainless steel surface (the sink).
A few interesting properties of these antibubbles: Their refraction index is much larger than normal bubbles, indicating that the bubbles are completely water. The bubbles move fast over the surface over the water and deflect off each other, which is characteristic of spinning tops.
So it looks to me like these are tiny balls of water which are spinning very fast, fast enough to have friction greatly reduced and for the water to float easily on top of the other water.
So my question is this:
If you can have this sort of effect with tiny balls of water, whats to stop a solid which has a great amount of spin from doing the same thing. Furthermore, if this kind of effect is possible with fluids, couldn't we use the same idea to make something float in air?
Feb21-13, 05:59 AM   #20
Recognitions:
Homework Helper Homework Help
I notice lots of these balls of water running everywhere when I'm hosing the car when washing it.
New Reply
Thread Tools
Similar Threads for: How can water do this?
Thread Forum Replies
If an ice cube floating in a glass of water melts, won't the water level decrease? Introductory Physics Homework 3
Cooling hot water by adding in cool water and draining out the hot water - Formulae General Physics 5
Heat power needed to partially evaporate water from a water container Introductory Physics Homework 1
Basic question regarding triple point of water and physical properties of water Introductory Physics Homework 9
