wj02
- 5
Dear list,
Imagine a table of upper surface area S sitting in an open field, with nothing on it. We know that S is subjected to a downward atmospheric pressure P due to a cylindrical column of air of volume V extending vertically from S to the end of the terrestrial atmosphere. Assume this column contains n air molecules each of mass m. We know from the kinetic theory of gases that these zillions of molecules are moving around in a Brownian motion at an average speed v. To simplify further, assume that earth’s gravity g is independent of altitude. Then:
1-From a hydrostatic point of view, we know that P = nmg/S; here pressure is due to the weight nmg of the air column above the table.
2-From a kinetic point of view (after many simplifying assumptions), P = nmv^2/3V; here pressure is due to collisions at a speed v between air molecules and S.
Since both point of views are correct, they should both yield the same pressure.
Now assume we cool down the air column to very low temperatures such that the molecules become nearly still (v approaches 0), then theory 1 would still predict the same pressure P= nmg/S. Theory 2 however predicts a pressure P approaching 0!
For the life of me, I cannot answer the following questions:
-How can both theories be correct, yet totally disagree?
-How can one phenomenon of nature (pressure) be the result of two totally unrelated natural phenomena (static molecular weight and dynamic molecular collisions)?
-Why can’t we derive one formula from the other (even when we make some assumptions)?
I am puzzled. Can someone explain?
You can answer if you want offlist to wasjal@gmail.com
thx
wassim
thx
wassim
