Not only is the symbol daunting, but the words are too
  • Thread starter flyingpig
  • Tags
    Symbol
In summary, the homework statement is to check that F_2 is a field. The Attempt at a Solution states that 1 + 1 = 1 + 1 and that 1 has no additive inverse. This can be confusing because if 1 + 1 = 1, then 1 has no additive inverse. A2 states that 1 + 1 = 1 + 1 and that 1 has no multiplicative inverse. This means that 1 + 1 = 2 for this field. The definitions for the field, F2, are through 2.45 through 2.52. All that is required to show that F_2 is a field is to verify A1 to A4.
  • #36
micromass said:
And how would you evaluate (1+0)+1 ?? Is it also 1??
(1 + 0) = 1 from 2.46
so I get 1 + 1 = 0 still
Also RedBelly I was actualyl going to post my answers lol and then it said "Sorry! the thread is locked!"
Flyingpig to Redbelly (unrelated to this thread) said:
Never mind d) is 375. They all move up by 75...each. Stupid question.
This was solutiuon they gave me
[PLAIN]http://img849.imageshack.us/img849/4906/unledhsb.png
Which just means the answer is a multiple of 5, I thought they meant the contours are "5M units apart"
  • #37
OK, so that is indeed correct. We indeed have that
1 + (0 + 1) = (1 + 0) + 1 = 0
But that is not were the error was. The error is in the following
1 + (1 + 0) = (1 + 1) + 0 = 1 + 0 = 1
So can you calculate
1+(1+0)=...
(1+1)+0=...
again and see where the error is?
  • #38
1+(1+0)=...
(1+1)+0=...
But they all arrive at the same answer
1 + (1 + 0) = 1 + 1 = 0
(1 + 1) + 0 = 0 + 0 = 0
But 1 + (1 + 0) from A2 says 1 + (1 + 0) = (1 + 1) + 0 = 0 + 0
I don't see the error
  • #39
Indeed, they are all 0. But before you said that it was equal to 1. So now you have the correct answer.
  • #40
Impossible I had 0! It was in post#29!
Oh well at least I got the other 7 right! ahahhaah
Wait, does that mean I will have 8 x 8 = 64 lines to write for all the other ones...?
  • #41
Correction * 64
  • #42
Yes, now try to do the other ones. This should be quite easy if you understood this one.
  • #43
oH MY GOD, Please stay with me in case I made a silly mistake. With 64, I will...
  • #44
A1 done, A2 speaks for itself.
A2 said:
x + y = y + x
Let x = 0, y = 0
0 + 0 = 0 + 0 = 0
Let x = 0, y = 1
0 + 1 = 1 + 0 = 1
Let x = 1, y = 0
1 + 0 = 0 + 1 = 1
Let x = 1, y = 1
1 + 1 = 1 + 1 = 0
OKay probably not 64 then
A3 said:
I sense danger from this one...
x + 0 = x
Let x = 0
0 + 0 = 0
Let x = 1[/tex]
1 + 0 = 1
A4 said:
x + (-x) = 0
Oh boy
Let x = 0
0 + (-0) = 0 + 0 = 0
Let x = 1
1 + (-1) =...
Stuck already...I am an idiot
DOing M1-M4 D in another post.
  • #45
OK, for A4, you need to use that -1=1 and -0=0. You define this to be so.
  • #46
M1 said:
Damn it, 8 cases again
(xy)z = x(yz)
Let x = 0, y = 0, z = 0
(0*0)0 = 0(0*0) = 0*0 = 0
Let x = 0, y = 0, z = 1
(0*0)1 = 0(0*1) = 0*0 = 1
Let x = 0, y = 1, z = 0
(0*1)0 = 0(1*0) = 0*0 = 0
Let x = 1, y = 0, z = 0
(1*0)*0 = 1(0*0) = 1*0 = 0
Let x = 1, y = 1, z = 0
(1*1)0 = 1(1*0) = 1*0 = 0
Let x = 1, y = 0, z = 1
(1*0)1 = 1(0*1) = 1*0 = 0
Let x = 0, y =1, z = 1
(0*1)1 = 0(1*1) = 0*1 = 0
Let x = 1, y = 1, z = 1
(1*1)1 = 1(1*1) = 1*1 = 1
M2 said:
xy = yx
Let x = 0, y = 0
0*0 = 0*0 = 0
Let x = 0, y = 1
0*1 = 1*0 = 0
Let x = 1, y = 0
1*0 = 0*1 = 0
Let x = 1, y = 1
1*1 = 1*1 = 1
M3 said:
Other than 0, there is a 1 such that x * 1 = x
Let x = 0
0 * 1 = 0
Let x = 1
1*1 = 1
M4 said:
Other than 0, we have an inverse for x
Oh wait...should I just do x = 1 case...?
D said:
NOOO ANOTHER 8 CASE. I'll be back on this one...
Need water...be back in 2 mins.
  • #47
The second of M1 is incorrect.
  • #48
Yes because 0*0 is not 1...!
0(0 + 0) = 0*0 + 0*0 = 0 + 0 = 0
0(0 + 1) = 0*0 + 0*1 = 0 + 0 = 0
Let x = 0, y =1, z = 0
0(1 + 0) = 0*1 + 0*0 = 0 + 0 = 0
1(0 + 0) = 1*0 + 1*0 = 0 + 0 = 0
1(1 + 0) 1*1 + 1*0 = 1 + 0 = 1
1(0 + 1) = 1*0 + 1*1 = 0 + 1 = 1
Let x = 0, y = 1, z = 1
0(1 + 1) = 0*1 + 0*1 = 0 + 0 = 0
1(1 + 1) = 1*1 + 1*1 = 1 + 1 = 0
I am pretty confident in this one
  • #50
Now just imagine I have to put all of this on paper.
  • #51
SammyS said:
For this field, -1 = 1 . This is because the thing you need to add to 1 to give you the identity element for addition is 1.
I overlooked something. since WHEN DID I DEFINE -1 = 1?
  • #52
Well, you need to find for each x, an element y such that
x+y=0
By definition, this element is -x.
So, for x=0, you need an element such that 0+y=0. When you look at the axioms, you see that y=0 is the only possibility. So -0=0.
Now, what is -1?
  • #53
Oh is it from 1 + 1 = 0, that 1 = -1? oh okay
  • #54
Yes.
  • #55
I am still stuck on M4...
  • #56
Take x in your field. How would you define [itex]x^{-1}[/itex]??
  • #57
[tex]xx^{-1} = 1[/tex]
[tex]x^{-1} = 1/x[/tex]
That doesn't change the original definition...
I still can't use 0.
  • #58
Oh wait, M4 actually states for all x in R, without 0, the axiom holds, I don't even need to test x = 0 right?
Ah shoot for M3, I put 0 * 1 = 0, that's wrong isn't it? Because it says x without 0
  • #59
Sigh...
For each x nonzero, you need to find a y such that xy=1.
If x=1. What can you take as y?
  • #60
Right.
  • #61
This is probably another stupid question.
Since M3 states the same condition, it would be wrong/unnecessary to even do 0*1 = 0 because it contradicts M4 \ {0} right?
  • #62
M3 does not state the same thing as M4...
  • #63
But they have a similar condition...
  • #64
Oh wait you know what, never mind. I was looking at 2.49 and I thought [tex]0^{-1} = 0[/tex] and I had to test [tex]0*1 = 0[/tex].
So yes I do need to test 0*1 = 0 for x =0
  • Linear and Abstract Algebra
