One shaft two diameters angle of deformation
In summary, to compute the angle of twist of a steel bar with a torque of 200 N*m at the free end relative to the fixed end, the formula is (torque)(length) / (shear modulus of elasticity)(J of shaft). The J of shaft formula is (pi x d^4) / 32, where d is the diameter of the shaft. In this problem, the diameter on the left side is 0.04 m and the diameter on the right side is 0.02 m. The values for J1 and J2 are calculated to be 2.513 x 10^-7 and 1.571 x 10^-8, respectively. Plugging these values into the formula
togo
106
Compute the angle of twist of the free end relative to the fixed end of the steel bar:
200 N*m, 80 x 10^9 GPa (shear modulus of elasticity)
(Length 1: 1.2 m, dia of .040 m on left, length of .4 m dia of .020 m, on right)
angle = (torque)(length) / (shear modulus of elasticity)(J of shaft)
(200 n*m)(1.2 m) / (80 x 10^9)(25.1 x 10^8) = 1st section of shaft
(200 n*m)(0.4 m) / (80 x 10^9)(1.5 x 10^8) = 2nd section of shaft
= 0.012 + 0.0064 = 0.018 rad
Book answer: 0.0756 rad
Thanks!
no idea?
togo: Exponent or units on G (shear modulus of elasticity) listed wrong in section 1 of post 1, but listed correctly in section 3. Exponent on J listed wrong in post 1. J values rounded or truncated too much. Generally always maintain at least four significant digits throughout all your intermediate calculations, then round only the final answer to three significant digits. Unit symbol for Newtons is uppercase N, not lowercase n. Lowercase n means nano. Numbers less than 1 must always have a zero before the decimal point. E.g., 0.4 m, not .4 m. Try again.
rounded or truncated too much. Did you run the calculation yourself? I've been using about 4 sig figs throughout the book with accurate results up to this point. G is correct afaik.
ps.
.040^4 = 25.1 x 10^-8 according to my calculator with no additional figures
.020^4 = 16 x 10^-8 also, no additional figures
togo: That is not the correct formula for J. Check your book to find the relevant equation for J. Try again.
J = (pi x d^4) / 32
Right.
that's the formula I used, thanks
answer is still wrong
togo: Try it again, correcting the mistakes explained in post 3. Show your work.
.020^4 = 16 x 10^-8
J1 = .04 x 10^-8 x (pi/32) = 2.513 x 10^-7
J2 = .02 x 10^-8 x (pi/32) = 1.571 x 10^-8
(200 n*m)(1.2 m) / (80 x 10^9)(2.513 x 10^-7) = 1st section of shaft = 0.0119 rad
(200 n*m)(0.4 m) / (80 x 10^9)(1.571 x 10^-8) = 2nd section of shaft = 0.0636 rad
=0.0756 rad
togo: The formula you listed for J1 and J2 in post 10 is currently wrong, and does not match the right-hand side. Also, review the information in post 3.
(1) The unit symbol for Newton is uppercase N, not lowercase n. Lowercase n means nano.
(2) Numbers less than 1 must always have a zero before the decimal point. E.g., 0.04, not .04. See the international standard (ISO 31-0). Or see any credible textbook.​
thanks for that nvn. please don't respond to my help threads anymore
I will be seeing an instructor about this one
you will note that the correct numbers are in the final formula and you've neglected getting to the heart of the matter for half a month now
1. What is "One shaft two diameters angle of deformation"?
"One shaft two diameters angle of deformation" refers to a mechanical engineering concept where a shaft with two different diameters experiences a change in angle when subjected to a load or force.
2. Why is the angle of deformation important in mechanical engineering?
The angle of deformation is important because it affects the performance and functionality of a machine or structure. It can impact the accuracy, stability, and efficiency of the system.
3. How is the angle of deformation calculated?
The angle of deformation can be calculated using trigonometric equations or by utilizing specialized software and tools. It takes into account the diameter, length, and material properties of the shaft.
4. What factors can affect the angle of deformation?
The angle of deformation can be influenced by the material properties, dimensions, and shape of the shaft, as well as the magnitude and direction of the applied load. Environmental factors such as temperature and humidity can also play a role.
5. How can the angle of deformation be minimized?
The angle of deformation can be minimized by using materials with high strength and stiffness, optimizing the design and dimensions of the shaft, and properly distributing the load along the shaft. Additionally, proper maintenance and regular inspections can help prevent excessive angle of deformation.
14K
  • Mechanical Engineering
