Any difference on Satellite location between W135 and W075?
In summary, the conversation discussed the differences in satellite location between W135 and W075 and how it affects earth differently. The W135 satellite is located over the Pacific while W075 is over NYC, both in geostationary orbit. The conversation also mentioned the primary purpose of GOES satellites and their limited use for space weather sensors. The x-ray flux data being referenced in the conversation is one of these non-imagery sensors.
junk0
40
Referring to following link, it provides satellite location on W135, I would like to know what difference on Satellite location between W135 and W075, how does its measurement affect the Earth differently.
Does anyone have any suggestions?
Thanks in advance for any suggestions
http://www.swpc.noaa.gov/ftpdir/lists/xray/Gp_xr_5m.txt
Astronomy news on Phys.org
What sort of difference would you expect? That list of datapoints is measuring solar x-ray intensity, position above the Earth is not going to matter. The GOES satellites are all in geostationary orbit, so with instruments looking at earth, the difference is going to be what's below them.
What W135 represents in location?
Do you have any suggestions on what location is difference between W135 and W075?
Thanks you very much for any suggestions
Lines of Longitude. W135 is over the Earth in geostationary orbit at 135deg west, over the pacific about halfway between mexico and hawaii. W075 is at 75deg west, roughly over NYC.
edit: that's how far west.. the satellites are directly over the equator.
Does it mean that?
If there are many Protons charges at W135, but there is no Protons charges at W075, does it mean that the plasma is flowing over the region between mexico and hawaii, and will never flow over NYC, since Earth is moving from west to east direction.
On the other hands,
If there are many Protons charges at W075, but there is no Protons charges at W135, does it mean that the plasma is flowing over the region between NYC, and will flow over the region between mexico and hawaii next, since Earth is moving from west to east direction.
Am I on the right track?
Thanks everyone very much for any suggestions
The particle detector is seeing things trapped in the magnetic field I think.
The file you linked to is the x-ray detector (not the particle detector), and so (obviously) there is no "flow" since it's just radiation. Differences in the particle detector probably come from the shape of Earth's magnetic field at different times of day due to the solar wind. If that's the case then yes, if you saw high values at 075 I would expect the values to rise at 135 later in the day.. but again, I'm no GOES sensor expert.
junk0 said:
Does it mean that?
It means just that. The "G" in GOES stands for geostationary.
No.
The primary purpose of the GOES satellites is to take pictures of the Earth in a number of frequencies. Having the satellites in geostationary orbits means that each is always looking at the same portion the Earth. This is extremely useful for looking down at the Earth. It's not so useful for looking up into space. There are only a few upward-looking instruments on the GOES satellites, and these aren't imagery sensors.
The space weather sensors are amongst these non-imagery, non-earth viewing sensors. Some aren't on all of the GOES satellites. The X ray flux you referenced in the opening post is one of those. Others are replicated, but only one satellite is used as the primary source. The data from the secondary is not used for analysis. It's only there for backup, in case the primary fails.
Thanks everyone very much for suggestions
1. What is the difference between the satellite locations for W135 and W075?
The difference in satellite locations between W135 and W075 is primarily related to their orbital paths around the Earth. W135 is located at a longitude of -135 degrees, while W075 is located at a longitude of -75 degrees.
2. How much distance separates the satellite locations for W135 and W075?
The distance between the satellite locations for W135 and W075 can vary depending on their specific orbital paths, but on average it would be approximately 60 degrees of longitude, which is equivalent to about 4,200 miles (6,800 kilometers).
3. What are the implications of the different satellite locations for W135 and W075?
The different satellite locations for W135 and W075 can impact the coverage and data collection capabilities of each satellite. For example, W135 may have a better view of certain regions or weather patterns compared to W075, and vice versa.
4. Can the satellite locations for W135 and W075 change over time?
Yes, the satellite locations for W135 and W075 can change over time due to various factors such as orbital decay, adjustments made by operators, or the launch of new satellites. However, these changes are carefully planned and monitored to ensure the satellites continue to provide accurate and reliable data.
5. How do the satellite locations for W135 and W075 affect satellite imagery and data?
The satellite locations for W135 and W075 can affect satellite imagery and data in terms of resolution, accuracy, and availability. Depending on the location and capabilities of each satellite, the data collected may differ in terms of quality and coverage. It is important for scientists to consider these factors when analyzing satellite data from W135 and W075.
  • Astronomy and Astrophysics
  • Other Physics Topics
  • Aerospace Engineering
