Intuition behind Green's function (one dimension)
In summary: Green's function. In summary, Green's function in one dimension represents the response of a free particle to a localized source and its amplitude is affected by the particle's momentum and position, while in three dimensions it is affected by the number of degrees of freedom and displacement from the source.
Ravi Mohan
196
I am studying scattering from these notes.
There I came across Green's function in one dimension which is computed as
[tex]
\langle x|G_o|x'\rangle = -\frac{iM}{\hbar ^2k}\exp(ik|x-x'|)
[/tex]
I understand Green's function as a sort of propagator from [itex]x'[/itex] to [itex]x[/itex]. There are two observations that can be made for this Green's function (leaving aside the oscillatory dependence)
1) More the momentum, less the amplitude to traverse from one point in space to other.
2) Amplitude is independent of the displacement.
Whereas in 3 dimension it is quiet opposite. The amplitude is independent of the momentum but inversely dependent on displacement.
Why is this so?
As a scientist studying scattering, I can offer some insights into the observations you have made about Green's function in one dimension versus three dimensions.
Firstly, it is important to understand that Green's function is a mathematical tool used to solve certain types of differential equations, including those involved in scattering problems. It represents the response of a system to a localized source, in this case a particle at a specific position. The Green's function in one dimension that you have mentioned is specifically for a free particle, meaning there is no potential or force acting on the particle.
Now, let's look at your first observation - that in one dimension, the amplitude of the Green's function decreases as momentum increases. This can be explained by considering the wave nature of particles. In one dimension, the particle has a single degree of freedom - it can only move back and forth along the x-axis. As the momentum increases, the wavelength of the particle also decreases, meaning it is more localized in space. This leads to a decrease in the amplitude of the Green's function, as the particle is less likely to be found at a specific position.
In contrast, in three dimensions, the particle has three degrees of freedom - it can move in any direction. As the momentum increases, the particle has a longer wavelength and is more spread out in space. This results in a larger amplitude for the Green's function, as the particle is more likely to be found at a specific position.
Your second observation, that in one dimension the amplitude of the Green's function is independent of displacement, can also be explained by the wave nature of particles. In one dimension, the particle can only move along the x-axis, so its position is always known. This means that the amplitude of the Green's function is independent of the displacement between the two positions, as the particle is always located at a specific position.
In three dimensions, however, the particle can move in any direction and its position is not always known. This means that the amplitude of the Green's function is inversely dependent on displacement, as the particle has a greater chance of being found at a position closer to the source.
In conclusion, the differences in the amplitude of Green's function in one dimension versus three dimensions can be explained by the wave nature of particles and the number of degrees of freedom they have. It is important to note that these are general observations and may vary depending on the specific problem being studied. it is always important to carefully
1. What is the purpose of a Green's function in one dimension?
The Green's function in one dimension is a mathematical tool used to solve differential equations in physics and engineering. It represents the response of a system to an impulse or point source. It allows us to find the solution to a differential equation by breaking it down into simpler parts that can be easily solved.
2. How is a Green's function related to the impulse response of a system?
A Green's function is mathematically equivalent to the impulse response of a system. This means that they both represent the output of a system when an impulse or point source is applied as the input. In other words, the Green's function tells us how a system will behave in response to a specific input.
3. Can the Green's function be used to solve any type of differential equation?
No, the Green's function is specifically used to solve linear, homogeneous differential equations with constant coefficients in one dimension. It is not applicable to non-linear or non-homogeneous equations.
4. How is the Green's function derived or calculated?
The Green's function is derived by solving the differential equation with a point source as the input. This results in a solution that includes an arbitrary constant. The Green's function is then calculated by setting this constant to 1 and taking the limit as the point source approaches zero.
5. What are some practical applications of the Green's function in one dimension?
The Green's function has many applications in physics and engineering, such as solving problems in electromagnetics, heat transfer, and quantum mechanics. It is also used in signal processing, acoustics, and image processing. In addition, the Green's function is essential in understanding the behavior of linear systems and their response to different inputs.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Other Physics Topics
