- #176
timmdeeg
- 278
That would be great, no doubt. But it seems, there is a lot of scepticism, despite graphene being an extraordinary material in this context. Kindly look here, Utilization controversy. You are obviously very knowledgeable in this field. Therefore I would like to ask, are there any hopeful experimental results?Frank Weil said:My advice is to conjoin the other answers that have been supplied by the mathematicians,physicists,astrophysicists and cosmologists (students or academics) and for you to arrive at your own conclusion(s).
Casimir update:
A sheet of graphene is one atom thick which makes it the first two-dimensional object humans have ever created, seen and manipulated. The uses for such a material are still being investigated. Ultra-high frequency/ switching, transistors/diodes are one application.
The more exiting application is in zero-point energy research which we were working on in Wisconsin, (Quantum fields). Basically, the Casimir Effect is the negative pressure/ energy upon two metal plate separated by a very small distance. Placing and keeping these plates at such a small distance is very difficult due to alignment problems of the gold plates. This is where graphene is useful.
Using four grapheme packing shims on each corner of one of the plates and then bringing the two gold plates together; not only would/is the separation of the plates be precise and stable, but the distance between the plates would/is be only one atomic diameter. Fabrication of a complete monolithic ‘carbon chip’ with billions of these will follow. The chip will ‘sum’ the energy collected by the number of zero-point elements fabricated on the chip and would not require an external power supply.
It would be using energy extracted directly from the zero-point Heisenberg field.
P.S. If I am writing only a few sentences, its because it is very time consuming not to write in my mother language, no other reason, like disregard.
