Is the Empty Set a Valid Vector Space? A Closer Look at the Ten Axioms
In summary, the conversation discusses the concept of the empty set and its role in vector spaces. The empty set is denoted as & and is a subset of every set, as it has no elements to verify. However, it cannot be considered a vector space as it lacks a zero vector or additive identity. The conversation also touches on set theory and the definition of subsets.
HungryChemist
143
While reading text, I had a question which I can not resolve by myself. Please Help me!
it reads, The empty set( a vector space with no elements) is denoted as & (This symbol doesn't matter for the sake of argument, I don't know how to write the Zero with a line in the middle). I can understand what they mean by empty set. It must be somewhat like this; Set V = { }. But can such set with no elements has all the quality of being a vector space? If so, how can one show it does indeed meets all the ten axioms of vector space?
It seems to me that a vector space ought to contain vectors, so the empty set probably doesn't qualify.
The thing with maths is that the empty set can be a FOO since there are no elements of the empty set for whcih the definitions of FOO are false. BUt, that said, I don't think this case is one of them, there is for instance no additive identity. Which text is this?
Hm
Since the empty set is a subset of every set, I think one can still say it's a vector space.
The statement [tex]x\in\emptyset[/tex] is always wrong, so you can derive any statement you wish, in this case the axioms for vector spaces, which will apply to the empty vector space. (In fact, everything can follow from a wrong statement)
Vector spaces need a zero vector (an additive identity) just like groups need an identity element. So empty sets cannot be vector spaces.
Of course, almost every time I define these things for students I declare the underlying set to be not empty and that removes any doubt.
OK, I looked it up.
The definition presupposes that a subspace of a vector space be non-empty. But does a vector space deserve to be called a set then?
of course it does.
This is yet published text which my professor uses for my classes. This class is Mathematical Methods/Numerical Analysis.
symplectic_manifold said:
Hm
Empty set is a subset of every set can't be true. If a set S is a subset of a set V then there should be at least one element of set S that also belongs to a set V but there are no such element if the set S is empty. No?
I'm afraid the empty set is a subset of any set, at least in any (model of a) set theory worth its salt.
HungryChemist said:
Empty set is a subset of every set can't be true. If a set S is a subset of a set V then there should be at least one element of set S that also belongs to a set S but there are no such element if the set S is empty. No?
Well, this is it.
The empty set is a subset of every set exactly because of the fact, that one doesn't need to verify, that every element of the empty set also belongs to a non-empty set.
If we have a property which no elements of a non-empty set have, we obtain the empty subset of this non-empty set:
[itex]\emptyset=\{x\in{M}|x\neq{x}\}[/itex]
...but as I eventually made clear for myself, it has nothing to do with a vector space...nothing can be defined on an empty set...from nothing comes nothing! o:)
Well, this is it.
shoudn't it be [itex]\emptyset=\{x\in{M}|x\neq{y}\}[/itex]?
x not equal x sounds very wrong...
No, it's correct. [itex]x \not= x[/itex] is always false: there is no x which satisfies that nonequality, therefore the given set is empty. You didn't even specify what y is, so your expression has no meaning.
To relieve any doubt, use the following definition of subset:
If A and B are sets, then A is called a subset of B if:
[tex]x \in A \Rightarrow x \in B[/tex]
the notation is [itex]A \subset B[/itex].
Do you see now why the empty set is a subset of every set.
Also note that this property conveniently gives us the property that the intersection of two sets which have no elements in common is still a set, the empty set (since it is a subset of both sets).
Yes! Thank you very much. I am always amazed!
Yeah, as others pointed out, the empty set can't be a vector space because it has no zero vector. However, the empty set does span the vector space consisting of the zero vector, according to the definition of span: The span of a set of vectors is the smallest subspace containing those vectors.
In what sense does the span of the empty set equal the set containing the 0 vector?
"The span of a set of vectors is the smallest subspace containing those vectors."
:tongue2:
Also, the zero vector is the linear combination of no vectors. (i.e. the "empty sum")
the summation symbol is a function from indexed sets of vectors to the vector space, which is additive on disjoint decompositions of the index set. hence it must send the empty index set (which is an indexed set, since the empty set is a set) to zero.
hence the empty linear combination must equal zero. Many many proofs in linear algebra are lacunary without this remark. I just taught it last semester and found out how hard it is to ignore this case without making mistakes, (which however no one noticed except me). Indeed even the book I used made this mistake - although the authors tried hard to give correct statements without pointing out this subtle fact, they did not quite succeed. :rofl:
Hm
Hello all. Ermh, here comes my first post!:
Of course, you can state true sentences about an empty space just beginning your sentence with sorts of "for all elements of...", "for every v in...", etc. Thus, all you axioms for vector spaces which state a general property for all elements, will hold true by an argument of vacuous truth: "for all v, w in V, v+w belongs to V", "for all u, v, w in V, (u+v)+w = u+(v+w)", etc. All of them hold true since there's not any element in {} to contradict these affirmations!
But some axioms involve explicit existence of special elements, and thus they cannot hold validity anymore in the frame of an empty set: "there exists v in V such as, for all w in V, v+w=v", and "there exists u in V such as, for all w in V, w+u=v, in which v is the additive identity element". None of them can exist because your set is empty.
So you cannot have additive identity nor inverse additive in empty set, so it is not a vector space :).
i hope you have some knowledge in "logic". because the answer need it.
Let A and B be two statements.
The statement "if A then B" always TRUE when "A" is FALSE.
so all the axioms for vector space are always TRUE. for example:
(consider V={}, then empty set)
V1. "if x, y in V then x+y in V",
since V={}, "x, y in V" is FALSE and so statement V1 is TRUE.
Why does the empty set satisfy the additive identity? The additive identity states that for all x in X (the vectorspace), x+e=x. Obviously this is satisfied for the empty set.
As stated a few times, "there exists" statements are not true while "for all" statements are always true. This was cited as a reason why Ø is a vector space. However, the statement for all v in Ø, ___, (insert the negation of an axiom) is also true vacuously.
But yeah, there is no zero vector so it's not a v.space.
As also noted earlier, Ø is the basis for {0}. And it is very unlikely that a basis is a v.space as well. At least for finite dimensional spaces over infinite fields.
{0} is the smallest space period and Ø is a subset of {0}, so Ø is the basis for {0}.
isn't everything "vacuously true" about the empty set? i always thought the empty set was the most trivial (& therefore least interesting) example of a ring, group, vector space, module, etc etc.
http://en.wikipedia.org/wiki/Vacuously
No: universally quantified statements (a.k.a. "for all x in {}"-type) are vacuously true. Existential (a.k.a. "there exists x in {}"-type) are automatically false.
The empty set is not a model of a ring, group, vector space, or module, because each of those has an existential axiom. Actually, all of them have the group axioms inside them someplace, so all I really need to mention is that the axioms of a group include the existence of an identity element.
My first post too! But, let's see.
Consider an n-dimensional vector space [tex]V[/tex] spanned by basis vectors [tex]\{v^i\}~i=1,...n[/tex]. Now let's have two subspaces [tex]U, W[/tex], spanned by [tex]\{u^j\},\{w^k\} [/tex] respectively, [tex]j,k = 1,...m, \text{with}~m < n. [/tex]These subspaces are also spanned by [tex]\{v^i\}[/tex] clearly.
Now say [tex]U\cap W=\emptyset[/tex].
Now if [tex]V[/tex] is a set, it has as it's trivial subsets [tex]V~\text{and}~\emptyset[/tex]
Then is there a sense in which the the empty set is a subspace of [tex]V[/tex]? I can't really see why not, but I am happy to be corrected.
The intersection can't be empty for the zero vector is in both.
Oh dear, I hope as a neophyte, I'm not making a fool of myself.
OK look. Grant me that, if the empty set is a trivial subset of V, then it must, by the definition, contain the identity. So, is there no sense, in the case that the set V is a vector space, that the zero vector can be identified with the identity?
It is a trivial subset of V.
It is not a trivial subspace of V. {0} is a subspace of V.
If there is a zero vector or identity in Ø, then Ø is not empty.
  • #31
Thanks for that, I was quite incorrectly equating {0} with { }.
  • #32
No, I won't grant you that! Saying the empty set is a subset is not the same as saying it is a subspace!
  • #33
You're welcome.
Have fun here at PF!
  • #34
Ha! Be careful what you say, I have a zillion half-assed questions up my sleeve!
1. What is the empty set in mathematics?
The empty set, denoted by ∅ or {}, is a set that contains no elements. It is a fundamental concept in set theory and is used to represent the absence of any elements in a set.
2. Is the empty set considered a vector space?
Yes, the empty set is considered a vector space. This is because it satisfies all ten axioms that define a vector space, including the existence of an additive identity element and closure under scalar multiplication.
3. Can the empty set be a subspace of a larger vector space?
Yes, the empty set can be a subspace of a larger vector space. This is because it satisfies the three requirements for a subspace: it is non-empty, closed under addition, and closed under scalar multiplication.
4. What are the ten axioms for a valid vector space?
The ten axioms for a valid vector space are: closure under addition, closure under scalar multiplication, existence of an additive identity element, existence of an additive inverse element, existence of a multiplicative identity element, distributivity of scalar multiplication over vector addition, distributivity of scalar multiplication over scalar addition, associativity of scalar multiplication, associativity of vector addition, and commutativity of vector addition.
5. Why is it important to study the empty set as a vector space?
Studying the empty set as a vector space allows us to better understand the fundamental concepts and properties of vector spaces. It also highlights the importance of the axioms in defining a valid vector space and helps us to recognize that even seemingly trivial sets can have important mathematical properties.
  • Linear and Abstract Algebra
  • Differential Geometry
