Is it possible to build an op amp with BJTs instead of MOSFETs?
In summary, an IC is made up of MOSFETs. BJTs are a better choice for op amps than FETs because they have lower noise and are more predictable.
aeftimia
I am trying to understand how some of the standard ICs work in terms of simple components I understand, i.e. transistors, resistors, capacitors, and inductors (although I doubt there are any inductors in an IC.)
I was trying to build and op amp from transistors, resistors, etc, and I noticed that all of these ICs are constructed with MOSFETs. In hindsight, that should have been obvious from the start.
In any case, is there anyway I can use my cheap BJTs instead of buying 10 MOSFETs?
Most op-amps are built with BJTs! Where did you get that idea that they are built from mostly FETs?
There are very very important factors that you need BJTs to build op-amps. BJTs has much lower low frequency voltage noise, low 1/f noise than all FETs. There is no way out of this. I am currently working on electronics using in guitar. I have been looking for low noise op-amps and the noise in audio range is staggering between BJT and FET.
Also BJT is so much more predictable that the most precision amps has to be BJT. MOSFET is good for wide band op-amp where it work from 1MHz to 100s of MHz. That you stay away from low freq noise and people usually don't care about precision. If you really want precision, you can piggyback a precision op amp in an easy design to get the stability at low frequency.
Yes, and they do it all the time. The input transistors are simply connected in a common-collector configuration so that the input impedance is high.
Have you tried JFET opamps, like TL072? I've been looking at them recently as I needed to make a very high impedance sensor pre-amp.
I just looked at it, If noise is not a problem and you need low bias current, JFET is the way to go.
It all depends what is the requirement, that's the reason there are so so many op amps made by so so many manufacturers. If you post more of the requirements, I might be able to help you. I just spent 4 days looking at a lot a lot of op amps for my needs.
Thanks. I've got a feedback amp circuit working on discretes, so looks like I've got a solution now.
I did a lot of discrete op amp design in my days because there weren't any in the market at the time. I think it is a good practice to do discrete op amp design so you really learn transistors.
I designed some quasi op amps with GaAs transistors and dual gate MESFET to get sub-nano seconds rise and fall time in the late 80s and early 90s where it was unheard of in IC op amps. We had no choice but to do that. Also very high voltage op amps of +/-750 volts supply voltages. And later we even had +/- 2.5KV op amps to replace expensive bi-polar lens power supplies using optical drive and cascade MOSFETs.
1. Can an operational amplifier (op amp) be built using only BJTs instead of MOSFETs?
Yes, it is possible to build an op amp using only BJTs (bipolar junction transistors). However, it may not be as efficient or perform as well as an op amp built with MOSFETs (metal-oxide-semiconductor field-effect transistors).
2. What are the main differences between an op amp built with BJTs and one built with MOSFETs?
The main differences between these two types of op amps are their construction and performance. BJTs are made of three layers of semiconductor material and are current-controlled devices, while MOSFETs are made of a single layer of semiconductor material and are voltage-controlled devices. This results in differences in their input impedance, output impedance, and speed.
3. Are there any advantages to using BJTs instead of MOSFETs in an op amp?
In some cases, using BJTs in an op amp can be advantageous. For example, BJTs can handle higher voltages and temperatures compared to MOSFETs. They can also have lower input bias currents and offset voltages, which can be beneficial in certain applications.
4. What are some potential challenges of using BJTs in an op amp?
One potential challenge of using BJTs in an op amp is their higher noise levels compared to MOSFETs. They also tend to have lower gain bandwidth products, which can limit their frequency response. Additionally, BJTs require a dual power supply, while MOSFETs can operate with a single power supply.
5. Are there any applications where BJTs are preferred over MOSFETs in op amps?
Yes, BJTs may be preferred over MOSFETs in certain applications such as audio amplifiers, where their lower noise and distortion levels can be beneficial. They are also commonly used in instrumentation and measurement circuits due to their high input impedance and low input offset voltage.
  • Electrical Engineering
